U welcome AndâŠitâs like freefly says, this is an awesome tint for âall-aroundâ!!
I noticed that too When on lower level (the regulated) the âyellowishâ tint is nice for colour rendering at close distance. Then, higher outputs, more âneutral whiteâ are very good for distance illumination without tiring the eyes I completely agree with you !!
Another thing Iâd like to say is that D4 is a nice light for Winter! And we all knowâŠâWinter is comingâ :smiling_imp:
Mine is regulated for 52ÂșC so it doesnât get that hot, but I was using it at a cold night outside: it didnât get too warm (the host) but it warmed a bit my cold hands
I believe that if the host (and internals) are cold, due to cold environment, it will take a bit longer to reach the configured temperature, so it will last a bit longer in highest output (also depending on batteries charge/voltage, of course). Is this thinking âcorrectâ ?
Anyway, this is an awesome flashlight, I wonât get tired of saying this
Yes, in Spain itâs already cold, and Iâve noticed a lot of change, I have it regulated very high, and it shows a lot with cold, hold much more high, it seems another, that if, drinks the jajajj batteries.
Just email Hank.
Heâll send you the tracking # with a Screenshot of the package status and tracking info.
Once it leaves China and enters The USA, youâll be able to track it with USPS using the same tracking #.
My D4 was at JFK within 2 days of shipping.
Itâs then a matter of how long it is in customs, transferred to DHL in my case, then to USPS.
My package went from JFK to LAX.
Go figure as JFK is much closer to me than LAX.
Total time in transit was 13 days from the shipping date, including weekends. I paid the additional $2 for tracking.
Now here my question, should step 4 get me back to turbo or just back to last brightness on the ramping curve(or regulated level in the example above)?
Also, is the double turbo same as the max at the ramping curve?
Anyways this thing is insannneee, can double as a soldering iron.
Yes, the D4 has last mode memory. So if you double click to get to turbo, then click it off, it will return to turbo the next time you click it back on.
However, if you change the battery or simply loosen the tail-cap or head it will reset to the default level, which is 100% of the regulated mode.
less efficient at storing heat by unit of weight - copper absorbs something like 40% more heat while weighing something like twice as much.
Much heavier - an aluminum D4 will vanish into a pocket. Changing the head to copper is extremely noticeable and much less comfortable for pocket EDC. I really feel the extra weight of copper in my pocket. Very uncomfortable.
Much more risk of burning your hand - copper conducts heat more efficiently than aluminum. This means that when you turn the light to turbo the outside of the head where your fingers touch will heat up much faster. Heat will conduct away from the LEDs faster than with aluminum but this isnât helpful if you still canât run the light for long on turbo, unless you want blisters on your hand. The interior components of a flashlight: LED, driver, wiring, and even the battery ⊠can all take MUCH more heat than your exposed hand can. Ideally, Iâd want the interior of the light at the LED to be much hotter than the exterior where my hand sits.
Also note that when it comes to heatsinking, conducting heat isnât everything. Conducting the heat from the LED into the copper body is only part of the problem. The body material also needs to be able to radiate the absorbed heat out of the light to surrounding air. This is called âemissivityâ. If the emissivity isnât high, the material wonât radiate heat. More heat will stay inside the light and it will get very hot.
Emissivity of anodized aluminum: 0.77 (higher is better)
Emissivity of polished copper: 0.023-0.052
The copper head of my Manker E14II gets too hot to touch in seconds ⊠much faster than my D4, while producing half the output of my D4. The problem is the copper head.
I own a couple all-copper lights, plus the copper-head Manker E14 and E14II. Iâve come to the conclusion that aluminum is simply a much superior material for LED flashlight body construction. At most Iâd want a copper star and maybe copper pill in lights that use a pill. Having exposed copper on the exterior of a light is counterproductive.
The biggest advantage of a copper body in a light seems to be the same as for titanium: Bling. Shiny copper looks impressive and makes a light aesthetically stand out from the sea of much cheaper aluminum lights.
It would be better in the sense that it would be brighter for longer, which fits the hot rod design. As you said, it would feel bloody hot. I donât think this is a critical issue since you can hold it by the battery tube, and it could be improved with a coating.
Today I want to share 3 funny but not funny stories at my work.l with my XPL HI 1A in tactical mode (press and instant turbo on hold)
1. One guy want to know if this is a good self defense flashlight so he want me to flash it into his eye on 18650 turbo mode. I told him I wonât do it because this thing will hurt like hell (donât ask me how I know).
So my other coworker took it and blast it at the guy and he canât see things for a few minutes and said it definitely was bright enough to buy times to run⊠and he wanted me to pass a black marker on the table⊠but there arenât black markersâŠ
Him: (reached over and grab my red marker) and said âThis one! It was right thereâ
Me: âmmmm bro⊠thatâs redâ
Him: ââŠâŠ really?.. (few seconds later) Now it looks purpleâ
We all just laughedâŠ
2. This time I had my D4 in 18350 aka âawww cute little thing modeâ I was showing a few coworkers on how small this thing is on my hand with palm facing up and button up. One came over looked at it and tried to press the button and I told him âno donât do it!â He looked at me like âWhat can this thing do? Blinding me?â So he pressed it at point blank right into his eyes⊠he went blind and covered his eyes and laughed at his stupidity. He reported that he saw 4 dots for a very long time and colors are off everywhereâŠ
3. This time coworkers went around and telling others on this D4, one girl came by and my buddy said âHey xxxxx (her name) this thing is so cool! Itâs so bright!â
She had the most unimpressed face and said â yaâŠ? AndâŠ? Show meâ
So I press the button and shine it off my palm, her face went from to âOMG what is this!!â With her eyes wide open (and that blinds her too because she was very closeup and want to see it clearly)
So⊠please donât be like my coworkers⊠and donât let kids play with it.
Keep them in a case so they donât get short-circuited, and be mindful that they can be completely discharged and destroyed. Most flashlights have low voltage protection to prevent this. However, the Emisar D4 will fully discharge the cell if you put it in backwards, so watch out.
