Hmm, not sure if I found a bug, an exploit, an Easter Egg, a feature, or have I just plain failed to "rtfm".. :|
Ok, so.. basically I guess that all of us around here know that with the Anduril version that's running on this light we have this feature where with the flashlight in lock-out mode, (4 Clicks from Off) if you press the switch you'll get momentary moonlight as long as you keep the button pressed.. as a.. quick and handy emergency operation mode.
Next, we also know that we have two mode group operation modes, Smooth Ramping and Stepped.. So far so good
While having the Ramp configured with the Floor at the min. when the light is locked we'll get min. level of brightness.. Of course, as long as we're not clicking to fast to get 4 Clicks and unlock it by mistake, right.. ?
Basically, as long as we're not unlocking the light, we'll get only the configured Floor level of brightness when pressing and holding the switch. Or so I knew..
Ok, now for some configuring:
Config Smooth Ramping operation mode as a high Floor, let's say around ~ 60 Clicks.. (about half the ramping/brightness) - Configure Ceil to whatever..
After this has been done, 3 Clicks while the light is On to switch to the Stepped operation mode.
Now, config the Stepped operation mode to a low Floor, like 1 Click, the min. should do just fine.. and of course, we do not really care about the Ceil, so either leave it untouched or config as desired.
Next, turn the light Off (still while in Stepped operation mode) and then lock it (4 Clicks) - Press the Switch - No wonder, You'll momentary get the set Floor level of brightness. Which was to be expected.
Now, Double-Click & Hold - Guess What.. ? You'll get the high/er Floor that was previously configured in the Smooth Ramping operation mode.. Yay!..
Basically, Click & Hold - Moonlight, (Stepped operation mode Floor) Double-Click & Hold = whatever you want from Floor all the way up to Ceil! (whatever Floor was set in the Smooth Ramping operation mode)
I guess it might work in reverse as well, switching Smooth Ramping for Stepped operation mode and you'll get a high/er level by Click & Hold and lower by Double-Clicking & Hold..
If this was a feature that I wasn't aware of, then I definitely love it! If not, if it's just a bug, or exploit or whatever, please, do keep it :)
Cheers!
