Hi.
Got my L4 from Banggod. I can say its one beautiful light.
I have problem and maybe you guys can help me. I did some tailcap measurements and I am getting only 1.38-1.40A reading on high. I might be doing something wrong. I used an Efest IMR and a Sony VTC4. Any inputs?
Thanks. I actually just purchased a Thrunite TN12 (2014) EDC light. Amazon only had one left so I couldn’t resist.
This L4 looks to be a good companion to it for those times I want more throw. In fact it will probably be replacing my old 4D Led Maglite. Darn thing eats batteries like crazy anyways I can see myself mostly using it on a high or medium settings.
So far the only things I wish this had was the ability to run CR123s or Primaries as an option.
*edit there’s a thread about it on Fastech
Then maybe a higher medium say 50–60 or more brightness levels available.
But maybe a different driver with custom firmware can help.
I just put some laptop pulls (New old stock) into this light. They’re Samsung ICR 4.3, currently sitting at 4.15v but i’m only getting a tailcap measurement of 1.1a. What’s the reason for that? Normal? Bad battery? I note the OP has close to 3a measurement on high.
Need more info. You tried just 1 battery and it's a laptop pull not fully charged? First use a fully charged known good cell - also can you test in another light? You know your DMM setup is good for measuring 2-4 amps?
Have tried 4 laptop pull batteries. They are new old stock. Charged to 4.17-4.19 measured.
These same batteries have given 2.8a in a 3s and 5+ in 2s 3T6.
The same multimeter was used for both tests.
So I’m a little annoyed realising that my L4 is not being driven anywhere near what it’s meant to go at. Warranty with BG will probably be unfeasible. Would you guys recommend:
-put in new stock driver LD34
-put in some other driver
-other mod?
