Sure. Here the solarforce website is. Here the l2 is. The head of the flashlight is essentially a hollow tube that the drop in will fit in. The body screws into the head and holds the battery. The tailcap screws onto the other side of the body and has a switch in it to turn the flashlight on or off.
Everyone else my extended vacation has finally ended. I will shipping some drop ins by the beginning of next week if you are waiting for any and there are quite a few of you, I am sorry for the delay. I am hoping to have everyones drop ins done and delivered by the end of next week.
can you make the driver below? :
Nanjg 105c driver with two extra 7135 chips added giving 3.55 amps max with the custom 3 mode program : 0.001A L, 1A M, 3.55A H, no memory.
if yes how much will cost including shipping to cyprus ?
I just built one with 2 extra chips and it delivered .004 amp low, .9 amp medium and 3.7 amp high, but I charge $10 shipped because I wreck so many drivers adding chips.
nice thanks for the tip ,i have already order this and i will give a try.i’ve done it before with illumination supply (he also sell chips for $0.50-0.55) 3A driver moded to 3,4 but now i prefer to get a really low for first mode.i will just add another chip cause i am going to use it for IMR14500 XENO E03.
edit
some of the comment in kaidomain said that soldering the S3 gives H/M/L ,do you know what to solder to get L/M/H ?
The SOS mode is super slow (12 sec signal, 8 sec pause).
The PWM frequency (for low and medium) is very high at 15000 Hz.
Mode switching
The KD 7135 V2 has four soldering pads (numbered S4,S3,S2,S1 from left to right) on the bottom side to select mode groups by applying a solder blob connecting one or more of the pads to the corresponding ground pad.
Beware of the schematics on KD’s site. It is faulty for the last 4 modes, the mode selection should be:
1: no solder blobs
2: connect S2 to ground with a solder blob.
3: connect S2 and S3 to ground.
4: S2, S3 and S4
5: S3 and S4 (not S2)
6: S4 (not S2 and S3)
7: S2 and S4 (not S3)
8: S3 (not S2 and S4)
Mode Memory
This can be selected by applying a solder blob at S1. The mode memory snaps in about 0.5-1 second after a mode switch. I normally prefers memory after switch-off so I do’nt have to tap twice to shift level.
I’d like to take two of the driver below, $20 total?
“I have the custom programming working, but I have limited options for programs. The 5 mode is very popular .002 moon low, .09 low, .8 medium, 1.75 high, 3.55 turbo with memory.”
Please PM me with your PP info.
PS. based on what you use, 3A V2 8x7135 + two additional 350mA 7135 chip, should be around 3.7A max if use single IMR.
