Vapcell U2 charger
Is the charger above any good?
I assume no overly negative experiences, but no cigar either…
There is also SU2 charger, with nice display, but requiring a separate adapter as opposed to regular USB C input.
Would that mean that the U2 charger is a better option? I’m looking for a portable, simple charger.
I would buy the SU2, is way better model, and i used it in Auto mode or at 1A max on Manual mode !
(The “problem” suppose to be at 5A ! )
Just my simple opinion… !
If you disconnect the power (unplug, experience a power outage) while charging one cell at 5A or two cells at 2.5A then the Vapcell SU2 may stop working and the cells could become shorted. This could cause a fire if left unattended while the black wires are smoking.
The design needs to be updated so that the charger doesn’t break when power is disconnected while charging.
