One suggestion, if you want to be sure you get a real high CRI in the actual tint it claims to be, don’t buy from KD.
The two neutral (4500k) nichias are 219A H1 sw45 and the new 219B R85 sw45. Cutter has 219B R85 that tested 5000k, highest color temp available in 92 typ CRI. For tints warmer then 4500k cree has high cri, you don’t need nichia.
Wow, thanks for the warning about KD. I was really close to getting them from there!
If I want to power 3 or maybe 4 of these, how should I do them? I can use an ac adapter to get to 12V. I also have mini adjustable voltage regulators that I could use. Would I set the regulator to something like 10V if i wanted to run 3 in series? not sure how the voltages are divided since the Vf changes
Btw, is there a difference between Nichia 219A and B? the only place selling B’s cost 7$ each which is pretty high ):
The 219A’s are cheaper and more places sell them
I’m considering a similar project. I don’t know much electrical engineering though, so I’m still working out some pretty basic stuff. The LEDs and drivers I’m familiar with are all relatively low voltage (~4V) and high amperage (3A or more) though, and it’s hard to find suitable power bricks for that. So, someone pointed me at this to convert extra voltage into the amperage I might need:
For now, I’m thinking of maybe doing two ~3500K or ~4000K high-CRI XM-L2 emitters at 3A each, with a nanjg or qlite driver to change the brightness via wall switch. All hidden behind furniture for ambient lighting. Or maybe one or two MT-G2 emitters instead, for higher output and cleaner tint. I’m not sure. Later on, I’d like to do either a neutral high-CRI lamp for use while painting, or perhaps a wide-spectrum lamp with multiple tints. And it’d be really nice if I could make some chain-able “puck” style lights out of old heat sinks, each with either a single high-CRI emitter or a wide-spectrum triple XP-G2 star. Again, output level selectable by flipping the wall switch off/on as if I were half-pressing a reverse clicky button.
It might be helpful for me to learn how voltage works in series, and how to handle the changing Vf as temperature and other factors change. This sort of thing is still a big mystery to me.
