I just got home from a day at the range, inter school club championship shoot, was a great day, fun had by all.
Anyway, after a snooze in my chair, it got dark. It happens here. So, I went to my bedroom and grabbed my new MarsFire, hit the switch and nothing happened. Clicked a few more times, nada. OK, took it back to the lounge for a closer inspection. Popped the batteries out, one was a bit warm. Hmmm.
Tested both batteries on my DMM, the warm one is under 1 volt! Charger won’t look at it, 3 flashing lights = battery fault. Not sure the other will charge either, it was 2.5 V but its just sitting in charger and doesn’t seem to be taking charge. *just checked with the meter, the cell is taking charge and lights up a torch, may be ok.
I took the battery tube off the torch, and the driver has detached from the pill and the B+ spring has shorted on the inside of the adaptor that the tube screws into in the head. The driver just barely locates on the end of the pill and the solder let go, looks like the pressure on the spring from the batteries pushed it sideways enough to hit the tube.
Don’t know how long the torch has been like that, I tossed it (gently) onto my socks in a washing basket when I went to bed last night and the light was working then.
Neither cell appears to have vented, blue UltraFire 18650 2400Mah from ebay.
I’m feeling pretty lucky I wasn’t roasted in my sleep, or came home to a very large and expensive pile of ashes.
I got it from the ebay seller listed above.
Anyone with their light, please check your driver. Mine was ok when I checked it out initially. It has not been dropped or knocked around.
