What did you mod today?
Ah, darn. I was really hoping to get the newer colors that way, too. Maybe I’ll go bother Simon about it, but there’s probably not enough interest.
idk why you couldn’t just put a rubber boot on a metal switch version (since it just unscrews). Maybe sand down the threads if you really want. Dont quote me on this cause I haven’t tried it but I could later I guess
The switch body of the metal buttons aren’t only threaded but they have a little lip too, which isn’t a big problem except -
The OD of the rubber opening is 16mm, while the actual opening of the threads on the metal button are like 12.5mm I believe
One could bore out the switch body of the metal switch version out to 16mm and use a rubber boot, should work.
True, or use a smaller switch boot possibly if you want to try to make it reversible
Added emphasis mine. That’s my main issue.
I’ll keep in mind that I may just have to get over it and bore them out if I care. More tools added to the “workshop wishlist”…
Thanks! Could you provide a link, please? I found a spare reflector at banggood but they don’t specify the size of the hole.
Thanks! The stock diameter is 6.5 mm though, don’t know if I can find an inexpensive step-bit which includes this size.
And I wonder whether the coating of the reflector survives the drilling …
I’ve used a step bit on reflectors before. Only slight chipping if anything right at hole. Didn’t effect the beam. Ymmv
I have something similar with this: https://www.banggood.com/2pcs-18-12-Inch-And-532-78-Inch-Bridge-Hole-Tapered-Hand-Held-Reamer-Set-p-1116958.html
So you can hand drill it really carefully to the size you need.
If its getting worse, you can buy a new reflector.
https://www.banggood.com/Sofirn-BLF-Q8-Flashlight-Accessories-Illuminated-Switch-Assembly-Copper-DTP-MCPCB-Reflector-For-Q8-p-1452686.html
https://www.aliexpress.com/item/32879434650.html
I used a reamer to open up the reflector holes of the Q8 to fit 5050 leds. It does the job very clean.
I bought one of these last year, its 9mm
Mike asked about a Q8 reflector, this is a C8 reflector?
Reamer/step bit it is then.
We are talking about Q8 reflectors :slight_smile:
Thanks! A quick search showed a lot of tools named “reamer”. Is this what you mean: reamer
Probably, handcrafting is not one of my better skills. :blush:
Sorry, I’ve read your post after I replied to djozz. So I found the right tool. Thanks!
Yes, that one will do. I have this one
It leaves the hole slightly conical, so it matters from which side you do the reaming.
Looks pretty handy, I’ll try to find a similar one.
I use one blade of a pair of scissors to cut out the reflector opening. ALWAYS from the bottom, outside the reflector, so any slip does not mar the shiny inner surface. :wink:
yes, thats what I usedfor 4040 LEDs in the Q8: https://www.banggood.com/Raitool-DT01-Edge-Reamer-Professional-Reaming-Universal-Hole-Drill-Tool-0-14mm-Opener-Reamer-p-922461.html
Yikes, how did i miss that? i was convinced he was talking about a C8 :person_facepalming:
