What Legoes with What?
I’m not sure how common these tins are around the world, but the plastic lid of my Lavazza coffee tins are a perfect fit as a protective cap for the Wildtrail WT90. But although it clamps, I will use two bits of cellotape as well because the WT90 bezel has no rim around the outside of the bezel for a firm clamping action, like the coffee tin.
V10r Ti+Al lol
Wow, look at that things pocket clip!
I made the handle myself, but now you mention it, it does not work so bad as a pocketclip :slight_smile:
:person_facepalming: :smiley: :+1:
Nice work!
Does anyone know if there are 18350 tubes for the S6? I clicked the link that edeekeos posted in this thread but it looks like the black tubes are no longer being produced. There are silver versions available but I would prefer the black.
There seems to be identical items on AliExpress but the seller ratings are pretty poor so I would like to avoid going that route and avoid the headache, even if it’s just items which are a few dollars.
Are there any other options I can look to for an 18350 tube for the Convoy S6?
If not, I guess I might try my luck on the silver tubes on Banggood…
Just found out that the switch of a Convoy S2+ fits into the Mateminco FW2 /Astrolux WP4.
Indeed! I swapped a forward clicky switch into my FW2 using a Convoy 16mm PCB & spring. I swapped the weird salmon boot for a black one from an SC31T.
Sofirn LT1 Mini & Sofirn C8L’s tailcaps can be swapped.
LT1 Mini’s tailcap on C8L requires the tailcap to be loosened/tightened to turn the light on/off. I suppose it does allow tailstanding though, which is an improvement.
The C8L tailcap on LT1 Mini prevents tailstanding because the button protrudes, and Anduril does not turn on automatically when connected to power so the switch just serves as a mechanical lockout.
Does anything Lego with an IF25A? Say if I wanted a magnetic tail on it, what would work?
It will probably be easier to glue a magnet in the tail!
This is a very minor Lego but the tailcap from Skilhunt M150 threads directly onto the Sofirn SP10 Pro. It’s a much better design and also magnetic.
Hi guys, I messaged Simon to check if the S2+ 18350 tubes work with the S6 and they do! He said to use the new square or rectangular cut threads. The previous trapezoidal threaded tubes don’t work but the ‘newer’ ones do.
Here is the S6 with shorty tube next to a regular-sized S2+
I can confirm the fit is correct and it works perfectly! I’m very pleased.
I need info on that cool pocket clip please?
Looks like a thyrm switchback or similar
It is a clone of a Thyrm Switchback 2.0. The quality is not quite as good as a real one but I have both and the clone is still plenty good, especially for the price of less than $2.50.
This seems like an appropriate thread to share this information.
The Wurkkos TS21 Pocket Clip fits a Convoy M21B PERFECTLY!
Also, the pocket clip from an Olight Perun 2 (which I believe is identiacal to the M2R Pro Clip) also fits the M21B 99% perfectly, as well as fitting the TS21 if you wanted a slightly longer clip with slightly deeper carry.
Below is a photo of M21B with TS21 Clip.
You can see the part of the clip that grabs the flashlight is exactly wide enough to fit perfectly.
Below now is a photo with the Perun 2/M2R Pro clip.
You can see here the part of the clip around the flashlight is slightly thinner than the groove it sits.
Its not bad at all, but the TS21 is just perfect.
Although, this one is deeper carry which is nice.
You’ll also notice that the other end of both clips land in the same spot on the battery tube.
Here is the TS21 with short tube using the Perun 2/M2R Pro clip.
Not much to be gained but slightly deeper carry.
For comparison, heres the TS21 with short tube using its own clip.
QUESTION
Does anyone know if the head of the Foursevens Mini Turbo MKII fits and works with the battery tube of the Foursevens Quarks (16340/ 16650)?!
The best images I can get from these models (well, their recent versions) are here, but I can’t really say if they fit and work :zipper_mouth_face:
Can wurkkos ts11 use sofirn sc31pro 18650 body?
The Convoy S16 tube with tail switch fits Pionemam K36 and Convoy M21E, so you can avoid Pioneman boring hold for off, and make both tacticool.
I believe the Pioneman k35 will also fits both.
