I’ve been on a quest lately to find the perfect EDC light. For me, it is a light that fits comfortably in my left pocket, has a pocket clip, and uses a latest generation emitter (XM-L2, XP-G2, 219, etc). To be comfortable, it needs to be small both width and length wise, as well as fairly light weight. For me, I try and keep the light under 26mm wide and 100mm long. Rechargeable is preferable, yet not a requirement. This limits my options mostly to AAA, AA, CR123, and 16340 powered lights.
Right now I have the following:
Fenix PD22 G2
Crelant V31A XM-L2 U2
I have these on the way:
DQG 18650 (barely fits my dimensional requirements, might exceed weight…Will find out on Tuesday when I pick it up)
Sunwayman R10A
Sunwayman R10R
Zebralight SC52w
I also have the following but I don’t use them for EDC because of the listed reason:
Maratac Copper CR123 (no pocket clip)
L3 Illumination L10 XP-G2 white (pocket clip does not stay attached, scratches white paint very easily)
Thrunite Saber Saber 1A T10 BLF Edition (no pocket clip)
So far the Fenix PD22 G2 is my favorite because it hits almost every mark. It has a nice neutral tint, is small, well built, has an excellent mode selection interface, as well as an impeccable beam (much better than the PD22 S2). My only complaint is that it does not support 16340’s, so it rotates with my Crelant V31A, which does support 16340’s. I dont like the construction of the Crelant as much. It is larger, yet it weighs less than the PD22 G2, which gives me the impression it is more cheaply made. I understand this is not supported by any fact, yet it always lingers in my mind. I also am not a fan of the switch and mode selection. The switch does not protrude out very far from the back of the light and the raised bezel around the switch makes it slightly less accessible. Once the DQG, Sunwaymans, and the Zebralight come in, I will have more lights to play with and rotate with daily use. I have a feeling the PD22 G2 is still going to come out on top, but the search shall never end.
So back to my original question: What lights do you carry with you every day? What do you look for in an EDC light? If you had to choose one EDC light based on your own criteria, which one would you carry?
