Guess what: Today I received the exact same package again! but this time it was the orignal order, from January 11th.
Lucky me, because it still included a Valentines coupon code :) and some other valentines stuff.... (of course expired)
So Im thinking that maybe I lll still receive my other packages as well.. But its really unpredictable.
got an enlan el-04mct..really like this knife..it seems smaller than my 01 and 02..one of the liners had rust spots on it..was able to feed some steel wool through and get rid of it though..
I got this remote pressure switch from Priceangle. My DX C-2 kit light I built had a really short tail cap switch so protected batteries wouldn't fit and this one has the longer tail cap that allows protected batteries to fit. First impression is fit and finish is flawless very nice coating and threads. The pressure pad is very precise and constant, unlike some other I have purchased. It's going to the range tomorrow mounted on a shotgun to see how it likes recoil.
I got some more atomizers for $2.73 each from Priceangle instead of $16 each from EGO. After burning through ten of these I can report they don't as as long as the expensive ones, but they do give more airflow so you get a better hit and they don't leak. I have been getting about 2 weeks out of them compared to 4 weeks for the expensive ones. So even though they don't last as long I still save a considerable amount of money plus they hit so much harder I really like them better.
I finally got my UltraFire UF-T50 today, looking to mod it already. I have a 16mm board with a 3C T6 XM-L, looks to be the size it needs, now I just need to get the Pill out to mod it.
EOSLAMP SP11 AAA light for a friend (This is my edc - love it!)
King Kong ICR26650 4000mAh battery
16340 to 32650 Li-ion single bay battery charger
18650 to 26650 battery converter case sleeves (2)
Stainless Steel Straight Tweezers
A pair black & blue silicone rubber boot 16*8mm (recessed)
Got my $6 LED lightbulb from New Egg. 30W equivalent (336 lumens), but uses only 5 watts. Cool white, but seems pretty bright. It will probably replace my power-hungry CFL bulb in my porch light which eats up 14 watts for 60 watts worth of light.
This is the knife sharpener I got when I won some Exduct credit during the first Exduct/BLF raffle .
It arrived in about three weeks , pretty standard delivery time for them in my experience .
In a heavily taped package , I got these pieces .
When I went to assemble the product , I noticed some misalignment issues . The guide rod , when fully threaded into the hone stone , was decidedly off-kilter .
Hmmm , let's try the other one .
Oh , boy . Let's see how the clamp and guide rod aligner assembly looks .
Well , to me , this is a poorly machined P.O.S.
I suppose if you remove the knife and reverse it in the clamp , instead of flipping the whole works over as designed , with a great deal of finesse , you may be able to sharpen a knife with it .
Also , the grits of the diamond hones are marked 480 and 800 grit . They both feel much coarser than they are supposed to . If you are going to re-profile a blade bevel , or need an extremely toothy edge to use as a rope knife , these stones may do the job just fine .
