Well, how am I supposed to get the drop-in in it then? It can't get in from the front if I remove the glass, and the reflector is too large to enter when the headpart is still on.
I am sorry I misunderstood, that is the part I try not to separate but it is an easy fix. Put a couple drops of blue loctite on the threads screw it together as tight as you can get it by hand let it sit overnight and you should be able to get it apart.
Sorry for going a bit offtopic in this thread, but the status right now is that I have glued the head back on, and now I can't unscrew anything. I don't have a vice, but got great grip with an old mousepad, and nothing moves even slightly. I suspect that someone accidentally glued the wrong part of the flashlight together, and now both threads are glued(middlepiece<=> body and middlepiece<=>head). Is this something anyone has ever experienced before?!
i will never again order from pc-link.biz - two months since I ordered a Swiss Tech micro tool, no sign of it, and they do not even bother to reply to e-mails.
I wonder what happened to them .... they seemed reliable in the past.... looks like they kind of dropped the ball. ( got 2 Mammuts here) Perhaps they make enough money with their military LEGO now...
I got a Maglite XL200 today. The brightest of te XL series, with multiple click plus accelerometer brings a better interface over XL100. The tint is slightly bluer than XL100 though.
It's no so much the tailswitch per se as the way it's designed and assembled. Instead of a direct spring from the switch, the spring is separate and not soldered. The spring then contacts a cap, again not soldered. So 2 extra pressure-only connections in a >3A light, which is just crappy design.
Still, I really wish they sold it w/ a OP reflector, I'll just add the dx switch myself.
