I have one of THESE and I love it. I got it HERE .Several times a year, usually around some holiday; they have sales with pretty good discounts. :+1:
Many will not consider this a “budget light” and that is fine. But it has pretty much become my favorite multiple cell AA light …. bar none. I use 4 AA Eneloops and the rest is history. Throw is pretty good as far as I am concerned, and the modes are well spaced to my liking.
Fits nicely in my back jeans pocket also.
Please note, this light is not compatible with 14500 Li Ion batteries.
Battery Power
4x Primary AA or Rechargeable AA or Primary Lithium AA
Specifications
Max Output: 1000 Lumens
Max Runtime: 416hrs Max Beam distance: …………402 m Max Intensity: ………………40,500cd
Impact Resistant: 1.5m
Waterproof: IPX-8, 2m submersible
Dimensions
Length: 170mm
Head Diameter: 34mm
Tube: 33.6mm x 24.55mm
Not a big fan of relatively high priced AA powered lights
TomBrooklyn, you can get a 1x AA powered SK68 off eBay for $3 delivered, or less if you win an auction. They throw quite well due to the zoom feature. It won’t beat lights costing 10X much, but in that price range I would abandon the idea of using AA cells and go 2 x 18650 powered.
Oh, you mentioned nothing about size, budget, or # of AA cells. Insufficient information!
Yep, so you did…………. you boys are both right. :+1: Probably a senior moment on my part……… :person_facepalming: ……
Personally I still am sold on the EA45S because of it’s lighter weight, slimmer design, fact that it pockets easily, and good feel in the hand. But those are personal likes & observations of mine.
However, the ThruNite TN4A with XP-L HI does indeed outdo it in the areas made bold below.
Specifications
LED: CREE XP-L HI LED with a lifespan of 20+ years of run time.
Runs on: 4 x AA batteries (not included).
Working Voltage: 2.75V-8V.
Output mode/Runtime(tested with Four NIMH 2500MAH batteries):
Peak Beam Intensity: 52340cd. Max beam distance: 457m.
Impact resistant: 2 meters.
Waterproof to IPX-8 Standard (1.5 meters).
Weight: 218.6g without battery.
Dimensions: 111.5mm in length, 45.5mm in diameter.
Accessories: Holster x1, Spare O ring x2, Battery Carrier x1(inside the flashlight), Lanyard x1.
