- Budget? (How much are willing to spend.)
- Form factor? (1×18650 to multiple 18650s is too broad a range, in my opinion … but that’s your choice.)
Then i’d prefer max 1x 18650 or a big round tube that carries 3/4x 18650
So it won’t be a tall flashlight!
- Intended use? (How will the flashlight be used: EDC, home, work, garage, car, hunting, etc.)
Outdoor use, walking etc. and also for some caving activies (not climbing so no headlight needed)
- Desirable characteristics? (Such as tint, tailstanding, forward clicky, knurling, lock-out, side-switch, pocket clip, crenelated crown.)
tailstand is prefered, tint warm white or neutral white, forward clicky prefered, side switch not neccesary but should be considered as an extra.
also: NO usb ports or charge ports on the light itself.
- How fast do you need it? (Some items may take a long time to ship.)
doesnt matter. i have time.
- What kind of UI are you interested in? (Modes, high-to-low, low-to-high, moonlight, strobe, SOS, beacon, memory.)
Hi Med Low, Moonlight. (with memory)
- Run times? (If you’ve got any special expectations, please state them. Otherwise, we’ll presume that you understand the limitations placed by your form factor choice. A small form will give you relatively short run times. A large form, say a 4×18650, will give you relatively long run times.)
Should be atleast 1hr. more is better
If you provide us with more details, you have a better chance of getting an answer that suits your needs.
does that clear a bit up
