On behalf of WildTrail I like to announce two new flashlight models, WT1M and WT3M.
A short disclaimer: The driver is custom-made by Lexel, the flashlight developed by WildTrail. I assisted with the development in an advisory capacity and wrote the manuals. Tom E kindly reviewed two samples and measured lumens and candelas. Big thanks to Tom for his great support.
| Specifications | WT1M | WT3M |
| Driver | 3-channel FET+5+1 driver, Atmel ATtiny85 MCU, USB-C charging, reverse polarity protection, low parasitic drain (< 120 μA), Lexel custom design | |
| Charging parameters | USB-C, max. 5V 2A (works with type A to type C cables) | |
| Emitter | 1x Luminus SST40 5000K 70CRI (DC chromaticity bin) or 1x Cree XHP50.2 3V 6000K 70CRI (1D chromaticity bin) |
3x Luminus SST40 5000K 70CRI (DC chromaticity bin) or 3x Cree XHP50.2 3V 6000K 70CRI (1D chromaticity bin) |
| Reflector | Single SMO reflector | Triple OP reflector |
| Lens | Glass with doubleside anti-reflective coating | |
| Body | Hard black anodized or clear oxidized aluminum alloy | |
| Button | Tactile electronic side switch with back-lit boot | |
| Ingress Rating | Equivalent to IPX-8, do not immerse in liquids | |
| Impact Resistance | 2 meters | |
| Weight | 163 grams without battery | 128 grams without battery |
| Dimensions | Length: 125.6mm / head diameter : 44.7mm / tube diameter: 28.5mm / tailcap diameter: 29.7mm | Length: 103.5mm / head diameter: 39.6mm / tube diameter: 28.5mm / Tailcap diameter: 29.2mm |
| Luminous Flux (confirmed by Tom E) | SST40: up to 2200 lm XHP50.2: up to 3500 lm |
SST40: up to 5500 lm XHP50.2: up to 6800 lm |
| Intensity (confirmed by Tom E) | SST40: up to 93000 cd (ANSI throw up to 610 m) XHP50.2: up to 40000 cd (ANSI throw up to 400 m) |
SST40: up to 44.000 cd (ANSI throw up to 430 m) XHP50.2: up to 22.500 cd (ANSI throw up to 300 m) |
| Firmware | Open source software called Andúril, distributed under the terms of the GPL v3. The source code is available from http://tiny.cc/TKAnduril, Firmware revision: 2019-12-03 | |
| Battery | 1x 21700 rechargeable lithium-ion battery, Battery length must be within 70mm and 72.5mm, diameter below 21.6mm. Protected cells or batteries like Molicel P42A or LG M50 with 21.7mm diameter may not fit. Battery is not included. | |
| User Manual Download | >>> Click here <<< | >>> Click here <<< |
| Additional Notes | Flashlight comes factory-calibrated for optimum performance |
Prices and order links
There is no groupbuy coupon code here. All prices are public and available to everyone. Please note that below mentioned prices are calculated without VAT. AliExpress will usually add VAT to your shipping location, so you might be seeing different prices depending on your country.
WT1M (black / clear version)
https://www.aliexpress.com/item/1005003204766035.html
SST40: as of $ 29.00 incl. shipping (shipping is stated separately)
XHP50.2: as of $ 33.00 incl. shipping (shipping is stated separately)
WT3M (black / clear version)
https://www.aliexpress.com/item/1005003203699107.html
SST40: as of $ 37.00 incl. shipping (shipping is stated separately)
XHP50.2: as of $ 43.00 incl. shipping (shipping is stated separately)
Customers who purchased WT90 from WildTrail‘s Aliexpress shop or Banggood may apply for additional 5% off. Please use discount code WT13MM with you order.
