Sure, and welcome to BLF.
So, I just received my flashing adapters from @thefreeman (thanks again for acommodating my rather unusual shipping requirements!), and just posted a review of them, including a comparison with my other flashing adapter which I got from @gchart; here it is: [Review] @GChart and @TheFreeman UPDI flashing kits: a tale of two adapters
Hope itâs helpful! ![]()
Thanks for doing additional optimizations for the FC13 and TS11 firmware (which previously shared the same firmware model â0715â as the TS25 and TS30S Pro).
I would like to ask which firmware would be more recommended for the TS30S Pro (I understand, you may not have a TS30S Pro), but the TS30S Pro is a bigger light that uses a single SBT90.2 LED. It is very similar to the FC13 in that it has a side button switch is RGB aux-LED.
I have tried flashing the TS25 firmware on the TS30S Pro and it works, but the side button LED has some different behavior compared to the FC13.
For instance, on the FC13, the RGB button LED color appears to track the battery voltage, so that at higher brightness, the button LED color will indicate a lower voltage (voltage sag since the LED uses more power.
If I use the TS25 firmware (which has RGB aux-LEDs on the head instead of the side button) on the Wurkkos TS30S Pro, the side button LED seems to be OFF while the main SBT90.2 LED is turned ON. (TS25 has model 0715 and the TS30S Pro also had model 0715, so this was the firmware I tested flashing the TS30S Pro)
By the way, Iâm currently using the latest pre-compiiled firmware hex files on your repository dated 2023-10-01 (matches rev 769 in the âlaunchpadâ website).
It uses the FC13 firmware.
Interesting! No specific tuning needed for the TS30S Pro? From what I hear, its sbt90-2 led is a very different beast when compared to the SFT40 in the FC13. Did Wurkkos somehow made them âequivalentâ when viewed from the Anduril angle (eg, different resistors, etc)?
100% output is 100% output. Thereâs no difference from Andurilâs perspective. Only difference might be the thermal regulation.
No doubt. But I was not referring to 100%.
Beyond thermals, I think different lights benefit from tuning at least for ramping, otherwise Andurilâs ramping âinfrastructureâ would be much simpler (no need for level_calc.py, ditto PWM1_LEVELS/PWM2_LEVELS/PWM_TOPS specific for each light, etc).
Or am I missing something?
HI guys, I require a bit of help. I would like to update the firmware on some of my TS10. I have the flashing adaptor from @thefreeman. I have a Macbook Pro, running on Ventura 13.3.1 (a), which has avrdude on it, and I have been succesfully using this setup to update some Hanklights with Hanks flashing adaptor. Works fine also with SOIC8 Clips, have used those for a D18, a FW3C, and a FW4A. However, I am not successful in using this setup for my TS10s. Can I use avrdude for that at all, or do I need a different setup? I am not educated with these things, I am the âlearning by doingâ kind of guy - so I require some suggestions, âhowtoâ instructions, or similar. Anybody here who could help me? Thanks in advance!
The command with serialupdi is different: Adventures in TinyAVR 1-Series - #294 by gchart
Thatâs on Windows, there might be some Mac specific stuff.
HI, many thanks for your input. I had read that, and tried a few times, but it seems I did not get the right input kind of instructions, sequences, on the keyboard, what ever. OK, I will try again. Has anybody done this maybe, and knows what exactly to tell the Mac?
Pinging @bole5 since he said in MP he successfully used it on Mac.
Super, thanks.
By the way, discussing this subject - one question. The latest relevant AndĂșril revision (including TS10) seems to be rev767. There are hex files offered by ToKeeper, and also by Wolfgirl42, thanks to both of them. For both TS10, and TS10V2. The latter also include the 8C mod from @dmenezes . Would the newer things such as Post-off-Voltage-Display and Soft Start also work on older TS10s? I tend to think so. Any experiences here?
To explain the reason for this question: I just learned by chance that my new TS10-V2-TI can do a lot more things than the Wurkkos manual tells. I am using @containerfan âs latest diagram now, âtry and errorâ, to find out what it does do and what not - just experimenting with this.
This is also my impression. There has been a few releases since then (the latest being 774) but Iâm not sure how stable any of them is, and for my own lights Iâm sticking with rev.767 for now.
Not only the TS10 and TS10V2 â actually, I put up a ZIP for rev.767+8C_Quick_Aux_Switch with HEXes for all the lights that build, see here: Anduril ... 2? - #1685 by dmenezes
Hereâs a listing for that ZIP, showing all the HEXes in it (rightmost column):
Archive: anduril_-_multi-channel_-_767-8C_quick_aux_switch+undef_USE_MANUAL_MEMORY_fix+undef_USE_SIMPLE_UI_fix.zip
Length Method Size Cmpr Date Time CRC-32 Name
36623 Defl:N 14347 61% 2023-10-02 13:54 49a1adb8 anduril.emisar-2ch-fet.hex
35273 Defl:N 13974 60% 2023-10-02 13:54 4fe4c9de anduril.emisar-2ch.hex
21769 Defl:N 9070 58% 2023-10-02 13:55 25f5736d anduril.emisar-d4-219c.hex
21769 Defl:N 9064 58% 2023-10-02 13:55 07cf2ffd anduril.emisar-d4.hex
39843 Defl:N 15767 60% 2023-10-02 13:55 24517704 anduril.emisar-d4k-3ch.hex
22857 Defl:N 9511 58% 2023-10-02 13:55 491b7836 anduril.emisar-d4s-219c.hex
22857 Defl:N 9523 58% 2023-10-02 13:55 20cce3d8 anduril.emisar-d4s.hex
31759 Defl:N 12602 60% 2023-10-02 13:55 cc17355d anduril.emisar-d4sv2-219.hex
31759 Defl:N 12608 60% 2023-10-02 13:55 cf32890b anduril.emisar-d4sv2.hex
31039 Defl:N 12439 60% 2023-10-02 13:55 a3a071f8 anduril.emisar-d4v2-219.hex
31039 Defl:N 12442 60% 2023-10-02 13:55 febd61ff anduril.emisar-d4v2.hex
30172 Defl:N 12234 60% 2023-10-02 13:55 77441120 anduril.emisar-d4v2-nofet.hex
22571 Defl:N 9343 59% 2023-10-02 13:55 b6cb323b anduril.ff-e01.hex
22906 Defl:N 9506 59% 2023-10-02 13:55 072fd6a6 anduril.ff-pl47-219.hex
22869 Defl:N 9499 59% 2023-10-02 13:55 d21428d1 anduril.ff-pl47g2.hex
22906 Defl:N 9515 59% 2023-10-02 13:55 9fb368b9 anduril.ff-pl47.hex
30413 Defl:N 12281 60% 2023-10-02 13:55 0880766a anduril.noctigon-dm11-boost.hex
31342 Defl:N 12519 60% 2023-10-02 13:55 29f13a5b anduril.noctigon-dm11.hex
30442 Defl:N 12314 60% 2023-10-02 13:55 06a8c4f4 anduril.noctigon-dm11-nofet.hex
31260 Defl:N 12511 60% 2023-10-02 13:55 3256916b anduril.noctigon-dm11-sbt90.hex
29276 Defl:N 11893 59% 2023-10-02 13:55 db2ef940 anduril.noctigon-k1.hex
36623 Defl:N 14366 61% 2023-10-02 13:55 e9191305 anduril.noctigon-k9.3-219.hex
36623 Defl:N 14361 61% 2023-10-02 13:55 b83e592f anduril.noctigon-k9.3.hex
35273 Defl:N 13973 60% 2023-10-02 13:55 0d80bf9d anduril.noctigon-k9.3-nofet.hex
31256 Defl:N 12528 60% 2023-10-02 13:55 98a7cf52 anduril.noctigon-kr4-219b.hex
31256 Defl:N 12527 60% 2023-10-02 13:55 57aeff69 anduril.noctigon-kr4-219.hex
35007 Defl:N 13897 60% 2023-10-02 13:55 747de7de anduril.noctigon-kr4-2ch.hex
31256 Defl:N 12527 60% 2023-10-02 13:55 707d6935 anduril.noctigon-kr4.hex
30360 Defl:N 12268 60% 2023-10-02 13:55 1b5fff64 anduril.noctigon-kr4-nofet.hex
35408 Defl:N 13970 61% 2023-10-02 13:55 fb7d5186 anduril.noctigon-m44.hex
35202 Defl:N 13906 61% 2023-10-02 13:55 ab9e8ff3 anduril.sofirn-lt1s-pro.hex
29452 Defl:N 11881 60% 2023-10-02 13:55 45daed0c anduril.sofirn-sc21-pro.hex
32025 Defl:N 12909 60% 2023-10-02 13:55 51ad5e5d anduril.wurkkos-fc13.hex
29313 Defl:N 11853 60% 2023-10-02 13:55 651bc984 anduril.wurkkos-ts10.hex
31792 Defl:N 12819 60% 2023-10-02 13:55 6b6bcbb9 anduril.wurkkos-ts10-rgbaux.hex
32025 Defl:N 12909 60% 2023-10-02 13:55 8764ed2c anduril.wurkkos-ts11.hex
31796 Defl:N 12798 60% 2023-10-02 13:55 134fb9c8 anduril.wurkkos-ts25.hex
1125411 452454 60% 37 files
Yes, soft start/stop works perfectly on my 1st-gen TS10. Post-off-Voltage-Display canât, as it depends on controlled-RGB LEDs which only the newest TS10 V2s have.
Hope this helps!
Yes, correct, sorry, I did not fully analyze this. Fixed color Aux LEDs of course cannot display a multi color voltage info. ![]()
774 has the smooth steps fully working in smooth ramp ( before it didnt from ramp to turbo for example).
Thanks for the info @thefreeman. This wouldnât be useful to me as I have Turbo disabled anyway, but anyone wanting rev.774 + 8C_Quick_Aux_Switch, just give me a holler and I will get down to it!
I finally managed to get this done. My problem was to identify the right name/description for the serial port that my Mac had used/allocated to the serialupdi programmer. COM3, this is what Ghart used in Windows, obviously does not work on a Mac. The way to find out what to put in instead is: use the terminal and type in as follows
ls /dev/tty.usb*
It will come back with the identification of the port used, in my case
/dev/tty.usbserial-1420
Put this - the eqiuvalent your Mac returns after you did the enquiry - into the avrdude command, all of it, and off you go. Took a couple of hours to find out âŠ
Now my TS10 Brass has rev767 on it, works fine. My other TS10s will follow soon. ![]()
Congrats!!! ![]()
Congrats to you
