Like new Fenix tk35 given as gift not my style asking 70.00 and a dereelight DBS aspheric well used light perfect working condition lens excellent with a dropin from vinz xpg2 driven at 3.1 amps has a mini aspheric lens over the emitter which gives a larger hotspot while retaining the amazing throw from his tests with same light and dropin measure 250,000 lux hate to get rid of it just need funds for another project asking 120.00 I still can’t figure out how to post pictures I’m still trying I can message pictures by phone upon request until I figure out how
Try this one of many.
FYI that “lens” on the emitter isn’t a lens, its the protective dome of the emitter. Every cree emitter has one unless it was dedomed
It was dedomed and has a tiny aspheric lens that colliminates the light smarty pants
Well if thats the case then I’d love to see proof. First time I’ve every heard of that and trust me, I follow Vinh’s mods very close. Double aspheric lens would be counter productive if you ask me
Not vinh but vinz he’s a modder in germany
Do you have any photos of this double-aspheric lens set up ?
Like I said before ill phone message rhem
This is from his thread on cpf . hand selected XP-G2 R5-1A on a copper MCPCB without dielectric. Soldered under slight pressure using best Mundorf Silber/Gold solder (contains silver and gold).
* de-domed the LED and equipped it with an new condenser lens (similar to positive meniscus) with an radiation angle of 75-80°.
* new solid heatsink/pill with 5mm aluminium between the MCPCB and the driver. Polished contact surface.
* self-built circuit with custom modes (1 press - high mode, 3 press - low mode, 4 press - beacon) and voltage control. Optimized for unprotected cells.
* optimiced contacts and bridged spring at the switch to keep the resistance as low as possible.
* IC Diamond thermal grease for the LED-MCPCB.
Seems 100% counter productive to me. Also the reason no one is wanting messages texted to them is since it would cost us way too much in international data message fees
Anyone interested in seeing the original thread: Original thread
Not to someone in europe
I’m in us
Bunch of Ninnies.
What he is selling is represented correctly.
Stay out of his For Sale thread.
Russ
I’d like the DBS, PM sent.
Russ
1 click on high 3 quick clicks and get low 4 quick clicks and get beacon
