Yep.
Cheers for that! What holds the silicone ring from the inside, I wonder?
I just got HD12. Cute!
A few random comments:
- I don’t seem to have won the tint lottery - compared it with Flood on HS21 and the latter definitely has more red in the mix, and shows colours better, though the CRI seems reasonably high if a little strawy in tint (the famous hand skin test).
- The UI is a breeze and feels logical - as it should in a headlamp, though it’s surprisingly easy to double-click instead of triple for the Red and blind oneself with Turbo.
- The tube cannot be reversed (to flip the direction of the clip for example) due to different thickness of un-anodised tube edges completing the circuit.
- I bought the Olight Perun 2 Mini head strap, hoping that the groove in it can accomodate the clip, but the groove is too narrow for the clip to fit in. Maybe filing the groove a little larger would do?
- I bought the Vapcell F15 which works with it, hoping to increase runtime on lower levels. Will report, but it seems that despite the light being driven by FET/PWM driver when 14500 battery is used, it’s not that inefficient producing some 230 lm×h of light on OEM battery (taken from @PiercingTheDarkness runtime graph - the only one I could find thus far) - not far off from e.g. H150 using linear driver (multiple reviews) though not quite as flat.
TBC
This review in Russian shows TIR and driver removal.
Still don’t know where the wires are.
Now I know there are no wires, just two boards connected at right angle
But how is that connected to MCPCB and LED?
@TUIG101 could you please shed some light on it? I’m in the process of mustering the courage to open it up.
So there is no wires at all, just traces? Is that common or even good resistance-wise?
Resistance wise it’s good, and I think it’s easier to assemble, but disassembling is quite more difficult than a traditional driver.
The only runtime graph for HD12 I could find is from @PiercingTheDarkness VDO review. Here is a frame at 1:00:
On Turbo, the highest level stays on the max for some 2 min (some 800 lm), then steps down quickly but smoothly to High at around 300 lm and roughly keeps the output above 200 lm for nearly 1 hour (not that noticable change in brightness to me), then drops to about Low and lower for a while longer.
I tried it on Turbo with Wurkkos OEM battery and got similar profile and a little longer timing. With the Vapcell F15 the shape is similar but the runtime at 300-200 lm (the High phase) seems extended by some 60% (a soccer-match long kind of range).
Have you swapped the LEDs in this light?
I just want to add that I begin to understand why people go into trouble of swapping LEDs.
I like the light (though an efficient buck driver for 14500 would be even better), but no matter how hard I try, the tint and the apparent CRI are a little sketchy.
Does the star have right soldering footprints and the TIR lens proper geometry to replace (or more like ask someone to do it for me) these LEDs with Nichias 519a, for instance or similar?
p. s. There are 2 white LEDs. Would mixing 2 Nichias with different CCTs make any sense? I have only seen one 519a (5000K) and I like it, but its unromantic…
Not yet, it will be an organ donor for another project. The swap process shouldn’t be any different from other lights, only the disassembly process will be more tedious. The original LEDs have a tall dome so the stock optics should work with any 3535 LED.
Just wanted to report that the battery level indicator on HD12 turns from green to read at some 3.6 V and starts blinking at around 3.2 V. The manual states that the cutoff voltage is 2.7 V.
I used the Vapecell F15 discharge plot to relate the above to approximate capacity left.
Assuming that the current draw is somewhere between 1 and 3 amps, it seems to me that red indicates about 50% of useful capacity left (and probably more or less runtime left as well, albeit at somewhat lower outputs because of the unregulated but still relatively flat driver output). Blinking red indicates about 25% remaining, I think. That’s easy to remember.
I just realised I put this comment in a general AA thread, so I link it here to be easier to find as it pertains to the HD12 performance.
From Turbo, single click returns to previous state (last level or off). Double clicking from Turbo inserts Moon in between (i.e. you need another click from Moon to return to previous state as above). Anyone knows what may be the purpose of it?
Speaking of clicking, I just got T6 as well and I find the UI refreshing. I set it to mode 1.5 (1%, 20%, 100%) and no memory and it’s so predictable and simple that that is nerve soothing.
One more thing I discovered with T6 Biscotti when the memory is off:
While short tapping the switch advances the levels in circular fashion, long tap returns the light to the first level (1% in 1.5 mode). Sweet!
I just tried it on my new T8. Works great. A very handy tip. Thanks!
WOW and I have lots of lights with this UI and have for a few years… never figured this one out.
It’s even documented (but not that easy to find if you don’t look for it). Here is the diagram from one of 1Lumen’s reviews:
Thanks for that! But now I don’t have to look for it ![]()
