Wurkkos TS10 Ti (v2) much more aggressive thermal stepdown compared to regular TS10?
@jon_slider do you know the current drain of the aux LEDs, at low and high settings? TIA
Ra and R9 using amateur-grade Opple LM4 with Smart App:
First light Ra 95, R9 79
Second light Ra 96, R9 84
Similar Ra with LM3
some info here
I have not seen any new measurements since Aux became RGB
3 days on high. Aux brightness going down. :sweat_smile:
Thanks.
@jon_slider the TS10 expert :+1:: Has the latest TS10’s driver remained the same as the one in my 2024 TS10? Max output would remain around 770 lm even with the most capable battery like Vapcell H10 and higher output no longer possible? TIA
higher output IS possible if you reflash with standard firmware, not the one called lowfet:
clic this link to download a folder full of hex files for all Anduril lights:
https://github.com/ToyKeeper/anduril/releases/download/r2024-04-20/anduril.2024-04-20.zip
(I cant figure out how to link the single correct file)
look inside the hex folder, and use the hex file called
anduril.2024-04-20.wurkkos-ts10-rgbaux.hex
to reflash your TS10…
disclaimer: I do not recommend using Turbo with that firmware, the LEDs might burn because the output will double. But if youre feeling lucky, I hope you have fun! :wink:
Thanks Jon. I don’t plan to flash, and don’t need high output from this light (other lights serve the function). Just curious if the high output reduction is a permanent move for all new TS10’s. Seems like it is.
BTW I am testing Wurkkos TS12 and TS15, so tempting but gun shy about testing it with the Vapcell FET-light killer. :joy:
agree
carpe diem? LOL
pretty sure the SFT25 can handle it, but no plans to try
share your success :wink:
I just tried, but no success. For some reason light doesn’t turn on with Vapcell. I did notice that my button top Vapcell is just a bit longer than Wurkkos OEM battery that comes with the light, by 1mm or so. Don’t know if that’s the reason but not going to try again. Yep Friday the 13, no need to test my luck.
good to know
for some reason some Vapcel Button Tops are also too long for some TS10 and D3AA
Turbo is overrated… LOL
The two below shipped to me from China Wurkkos on Nov. 8, 2025:
  • TS10 v2 with CSP2323-6000K, firmware 0000-2024-04-20.
  • TS10 SG with SFT25R-6000K, firmware 0713-2023-07-29
So it confirms that v2 are still shipping with safe 2024 firmware. I assume one uses the Anduril diagram dated 2024 for this.
For SG with 2023 firmware:
– Is it safe?
– Should I use the Anduril diagram dated 2023?
Congrats on your new lights
Welcome to the forum
yes
Turbo is higher than with 2024 firmware, but the SFT25 wont burn on turbo.
Although imo it is better not to use Turbo because it will step down very quickly. My personal preference is to disable Turbo and only use Ceiling
fyi, 2023 Ceiling in Advanced smooth ramping is mistakently set to equal Turbo, level 150/150.. suggest you lower it to 120/150 for convenience
I think you can use the 2024 diagram for both lights.. (the 2023 firmware just does not have smooth steps, item 5 on Ramp Extras menu.)
Thank you for your reply, and your prolific contributions to the flashlight communities.
It is nice that the TS10 v2 firmware 2024-04-20 has an Anduril diagram with the same date, and that it is available at https://github.com/containerfan/anduril2-diagrams
But the TS10 SG firmware 2023-07-29 does not have a date matching diagram, nor a date matching changelog.
  • See anduril/ChangeLog.md at trunk · ToyKeeper/anduril · GitHub
    The changelog for 2023-10-01 is the closest. Some of it applies, some of does not apply, and some is hard to know if it applies.
  • The closest diagram date I have was sent to me this week from Wurkkos support and is dated 2023-08-07. In “Ramp Extra Configs” it does not have step 5, which is good. But it also does not have some clarifications that the 2024 diagram has, so it may be better not to share it. But let me know if you want me to share it here.
When I factory reset the SG it goes to simple mode and the ramp is stepped.
When I factory reset the v2 it goes to simple mode and the ramp is smooth.
Now, with your reply, I feel safe to stay with the simple mode for both. The only change I made was to have the aux lights off when the light is off, by doing 7C (7 clicks) repeatedly. This can be done while in simple mode, as described in the manual under “Extended Simple UI” (but not shown on diagrams).
Thanks to your instructions elsewhere showing that 1H can count as 10 clicks, I may be able to overcome my fear to lower the SG ceiling to 120 as you suggested. I could not do 120 clicks, but maybe I could do 1H twelve times.
the changelog showed:
Model ____MCU ________ Name
0713 _____attiny1616 ___wurkkos-ts10-rgbaux
0714 _____ attiny1616___wurkkos-ts10
In the TS10 v2 firmware version 0000-2024-04-20, do the first 4 digits for hardware model (0000) mean that it is using generic Anduril?
congrats on all your research, and learning how to use Anduril
I hope you enjoy it :wink:
true, it was an unofficial prototype release
Im not sure it was documented with a diagram
you can use later diagrams
ceiling 120 is reached with 30 clics, or 1H 3 times (ceiling counts Down from 150… floor counts Up from 1)
not exactly.. it was a prototype firmware version built to provide 50% FET (which lowers Turbo output by 50%), in order to prevent LEDs from burning..
Just adding some more documentations details: Extended Simple UI is documented on diagrams as well.
For containerfan’s diagrams (source) that you referred to, check the Simple UI chart:
There are also diagrams by myself that document this. Besides a generic diagram up to current Anduril 2 release 2025-07-07 (source):
there is also an exemplary model-specific diagram for model number 0135 (hank-emisar-2ch) for Anduril 2 release 2024-04-20 which explicitly shows Extended Simple UI (source):
Please note that Anduril 2 release 2024-04-20 was the last Anduril 2 release with access to the strobes in Extended Simple UI. This access was removed in Anduril 2 release 2025-04-29.
