F15 button top works on TS10V2, Convoys T3, T4 (2x), Sofirn SP10 Pro and Weltool T1 Pro Tac among those 14500 lights I have. Will not do well on Convoy T3 Ti/Cu due to 5A driver.
Son of a gun it’s 0000-2024-04-20. Thanks Jon for reminding me. Wurkkos service is probably leery of my destructive behavior w/ flashlights so now decide to send something safe.
Despite of the 50% FET restriction, I still don’t plan to let Vapcell H10 come close to this very nice light. Agreed?
great to hear the firmware is the new 50% Turbo variety.
I dont see any harm in using the H10 with firmware 0000-2024-04-20 that has Turbo set to 50%.
the lumen level of the 2024 ceiling is also lower than on the 2023 firmware, and none of the 2024 ceilings are set to 150/150… I think the 50% Turbo firmware is safe to use with H10 batteries
Let me test with the no-name battery first. Still gun-shy after that WT* moment I had with the first TS10 + Vapcell. In my Reylight Pineaple w/ 219b 4500k it gives about 10% less output than Vapcell as measured with TA lumen tube.
I’ve “tortured” about 35 lights, all recent vintage, with Turbo output tests using high CDR batteries; this is the first one that died on me.
2024 50% FET: 0.0000 4100k
2023 100% FET: -0.0028 4300k (not many measurements because LED flamed out at some unknown point during measurements).
Subjectively the beam of 50% FET TS10V2 remains very, VERY nice especially at Turbo. It looks closest (not the same, just closest) to my 519a 4500k Domed in Skilhunt, but less green. (Everything looks green against 219b so I won’t bother you w/ comment.)
Got my Christmas TS10G red snowflake stuck on momentary flicker, starts low flickers faster to high solid and repeats.
Unable to get it to factory reset with 13h or hold button unscrew- rescrew holding button.
What gives?
Quick update/edit.
Changed back to Shockli battery from Keeppower that I had just stuck in it.
Apparently it doesn’t like the longer cell.
Damn metal button on the 10G is way stiffer and hard to operate quickly as well.
that is the Factory reset sequence
caused by the head not making good contact
try removing the battery, and tightening and loosening the head, firmly, a few times. The goal is to get the inner tube to seat and make good contact with the driver.
wipe off any excess lube residue on the end of the inner tube
Do use a stock battery.
let me know if the light works after that
Do Not use button top H10, they are too long and dont let the light close all the way.
if all that fails, contact Wurkkos, they will probably ship you a new one
Yeah, just too long of battery with protection, the battery was in SP10pro which has no problem with it. Of course that light is quite a bit larger/longer.
My Vapcell is button top H10, it does let the light close all the way. Or rather, it lets me close all the way without extra force. It does flicker as you’ve mentioned, and turning it back and forth mostly settles it. The no name battery is also button top, but slightly shorter, and behaves better.
Just curious: Do I understand correctly, that level 150/150 in my 2024 light = 50% FET?
Per spec it is 51.35 mm. I don’t have precise way to measure, but that looks about right. It does act funny with that flickering that goes away by twisting and un-twisting the head.
Preliminary data when I set ceiling to 150/150 - outputs are highest rounded values seen with Texas Ace lumen tube, after multiple runs. It’s interesting to me that setting ceiling 150/150 also changes outputs of all the other levels.
The higher 770 lm output could be that now it’s one click to Turbo, instead of previously it’s one click and then 2 clicks. (I don’t do 2 click hold to Turbo because I am afraid, rightly or wrongly, the aprupt power may kill the LED.)
2023 driver 100% FET at Turbo level 1100 lm: -0.0028 (not many measurements, LED prob died during this measurement) 2024 driver 50% FET with ceiling 150/150
Level 7 @ approx 770 lm -0.0020
Level 6 & 5 0.0000 (dead live neutral )
EDIT 12/29 - with more experience:
Subjectively/imho color rendition is most beautifull at Turbo level of the previous version, 2023 driver, which was around 1100 lm. This new 50% FET version of 2024 driver looks green and not as nice. Beam is even more greenish at lower levels. I set my 2024 TS10V2 to 150/150 ceiling so I could one click to this top level of 770 lm if I want to.
