Wurkkos TS10 Ti (v2) much more aggressive thermal stepdown compared to regular TS10?
I take it you mean the H10 battery w 10A CDR
fwiw, this zeroair review shows he got 1345 lumens (initial maximum), from the stock battery w 3A CDR.
With repeated use of Turbo, it is possible to burn up the CSP LEDs at that level, even with the stock battery.
here is the Zeroair Turbo Test… notice the sustainable output is less than 300 lumens:
As a reality check, consider that an HDS with high CRI LEDs is set to a maximum output of 200 lumens. And that light has double the mass of a TS10. HDS lights Never burn up the LED. No matter what battery it is powered with.
1345 lm in TS10? I am interested in the autopsy. :face_with_head_bandage: :slightly_smiling_face:
It seems same reviewer got 855 lm in another review of TS10V2? I wonder why no mentioning is made of this discrepancy.
Yes my Vapcell is the purple H10.
Thanks for very good info re. 6A limit. Now we know why my H10 killed my TS10.
Agreed with 700 lm max limit on this light. And ceiling 115/150, especially if I am to use Vapcell.
Thanks for detailed info. I hope mine comes with latest firmware
I think the link I used was to a TS10 V1.
The link you found is to a TS10V2
The key to all these output variables is the firmware version number, and its defaults.
Anduril has changed over time, such that the default outputs are not the same on different versions of the firmware.
You are lucky to have a way to measure lumens, so you can focus on that metric.
The latest batch of CSP LEDs are easier to burn up, which is why Sammy developed the 50% FET firmware.
We dont know if your Green TS10 used new batch or old batch LEDs. Same question applies to the TiCuTS10V2 that Teppka is waiting to receive.
imo, most likely is that both of those models are using the prior batch of CSP, and not the latest firmware with 50% FET.
received a TS10SG Red w Snowflakes
firmware is 0713-2023-07-29
3C battery check gives 3.9V
Default ceiling is 750 lumens in Advanced stepped ramping and it is set to level 130/150. Advanced smooth ramping has a ceiling of 990 lumens, and it is set to level 150/150 (my meter underestimates at high outputs).
BeAware that Advanced Smooth ceiling is set to Turbo on firmware 2023-07-29
In Simple mode Stepped ramping ceiling gives 735 lumens, which is level 130/150. Smooth ramp ceiling gives 728 lumens, also level 130/150.
I changed the Advanced Stepped ramping ceiling to level 100/150 and it now produces 386 lumens
reflash firmware update:
because this firmware 2023-07-29, has advanced smooth ceiling set to 150, I went ahead and loaded the 50% FET firmware 0000-2024-04-20 from MAO TS10V2 instead. this gives a ceiling of 450 and is using level 130/150 and gives a turbo of 640 lumens (I disable it)
Do you have any information that the SFT-25R isn’t able to handle full turbo on this light?
no, I did not mean to imply that the 1650 Lumen Turbo on the TS10SG is destructive. I do recommend lowering the ceiling to less than 150. I dont think it is necessary to use 1650 lumens, for the TS10SG to be a useful small throwy light. And I dont think there is any harm in using 50% FET firmware on it.
The TS10SG is the only one I have with the 2023 firmware, so I used it to determine what step level the ceilings are set to. This was written to help people with TS V2 lights that use the 2023 firmware, such as the one cannga burned up.
I do consider the 1400 lumen Turbo on the TS10 V2 destructive, in some people’s hands :wink: and I do think that 50% FET firmware is appropriate for this model.
A surprising mistake? I will be able to confirm using the no-name battery when the new light is here.
At 2A each/6A total, ie max current, could Wurkkos tell you what OTF output should be? Is it 700 lumen and that’s why the cap is set at that level with newest firmware?
Very good info. I’ll have some “fun” when the new TS10 gets here, using handicapped battery. :+1:
based on the claimed 1400 lumens, I calculated 50% to come up with the 700 lumen maximum… my measurement is a bit lower at 525 lumens, for my MAO TS10 V2, but my meter is not pro grade
Oh I see, not official Wurkkos number? I thought they knew the number and cap output accordingly?
correct
I have not seen any official info posted for 50% FET outputs, nor any reviews with runtime charts…
I only have my own measurements to go on… Hopefully someone with better equipment will inform us more accurately.
All the changes are confusing but I understand now thank you. This is my understanding, please correct as needed - the latest aluminum TS10V2 that everyone is receiving has:
  1. Advanced stepped Turbo is at 150/150 as expected,
  2. Advanced smooth ramping’s supposed non-Turbo ceiling is mistakenly set to Turbo 150/150. Will fry the LED with high CDR battery.
I do believe you understand everything correctly
fwiw, it may also be possible to fry the LEDs using the stock 3A CDR battery as well… to avoid that, I recommend avoiding repeated use of Turbo, sequentially… even if only for brief moments…
someone on Reddit I recently reported burned LEDs on a TS10 V2 using the stock battery here is the link.
Point being, even with stock battery, some people experience burned LEDs when using Turbo on a TS10 V2… I consider TS10 Turbo a Destructive output level and recommend either disabling Turbo or updating to firmware with 50% FET.
Mine just arrived. I checked firmware and it reads 2024.04.20 am I good to go or should I disable turbo and limit max smooth ceiling to 120/150?
Pretty light too.
TS10V2 Ti/Cu came in at 72,87gr with clip and Vapcell F15 battery
TS10V2 Copper came in at 100,90gr with clip and Vapcell F15 battery
This little thing is gorgeous
congratulations! and thanks for the photos. I agree the TiCu is a very handsome looking light.
Great to hear it comes with the latest firmware: 0000-2024-04-20. That firmware has 50%FET and is imho safe to use As Is, no need to disable Turbo, no need to lower the Ceiling.
Enjoy!
Thanks. I really like this clip I ordered additionally from Wurkkos. I think I’ll use it with this clip.
I agree the HD10 clip is very nice and works well on the TS10
Question about the F15 battery… If you have a micrometer, can you tell me how many millimeters Long it is please?
Its 51mm long and 14mm in diameter for button top F15.
For what’s it worth F12 button top has exact same measurements.
Very nice. My green TS10V2 is here too. Getting the no-name battery ready. Vapcell H10 will not see this light.
very helpful, thank you for confirming a 51mm battery works in your TS10 lights
yay! still the 2023 firmware right? :wink:
