Someone mentioned that the new TS10 Ti appears to step down very quickly from Turbo mode, so I did some informal testing.
I have a TS10 Ti (RGB aux) and TS10 (silver-white, not MAO), both 6000k LED.
To keep things more uniform, in the following test, I updated both units to their latest firmware for now (Anduril 2 2023-10-01 from Toykeeper’s Anduril repository)
I also used the same battery (not very high-drain type 14500, so it won’t quickly get too hot), which I charged to full. (was around 4.16v after I got them out from charger.
I also had a small portable fan blowing directly on the TS10 flashlights (I don’t want to accidentally damage the lights)…
I calibratedboth to room temperature (our room temperature is around 31 degrees Celsius accdg to a digital thermomeer, but I cheated a bit and instead set the lights to 27 degrees Celsius) for both units. Then I set the max temperature threshold to +33 (63 degrees Celsius).
I used Zak’s ceilingbounce and positioned one light at a time (light facing the ceiling) to the same position on a small dark room.
I got these results:
Wurkkos TS10 (silver-white, 6000k), set to Advanced UI mode, then double-clicked to Turbo from On:
Wurkkos TS10 Ti (6000k), set to Advanced UI mode, then double-clicked to Turbo from On:
Observation:
On the regular aluminum TS10, there was a gradual drop in brightness which sort of stabilizes at around 50% brightness level, up to 3 minutes.
On the TS10 Titanium, there was a sudden drop somewhere around 45 seconds into the test, and it stayed at a lower brightness level).
While the test was running (near the 3 minutes test I did), I used an IR thermometer (I just had a fairly basic model), pointed at the head of the TS10 (regular), which reads 42 degrees Celsius.
For the TS10 Ti, at the 3 minute mark, the head was reading 33 degrees Celsius (but this was already with lower brightness)… so maybe this isn’t a very correct test. (I don’t have IR thermometer with logging function).
Note the above tests are using a fully-charged but “not-too-high-drain” 14500 battery, and with a small fan pointed directly at the light.
