I see the cfg header for the SC21 Pro but not for the TS10. What’s the last 4 digits of the version check? I assume it probably piggybacks on another device config/build.
Thank You! this is all over my head
the version check last 4 digits are 0714 if I counted right…
can you confirm the info youre asking for by looking at this list, where I got the hex file I use now:
I use anduril.2022-07-19.wurkkos-ts10.hex
and does this info help confirm the TS10 model number?:
fwiw, the hex I use for the SC21 Pro also comes from gchart:
anduril.2022-10-12.sofirn-sc21-pro.hex
OK, using the configs from Gabe’s repo and also the latest code from ToyKeeper’s I’ve compiled up the HEXs.
I had never compiled for attiny 1616 before so had to get that configured. Also hit a compile error, looks like there’s a typo in the “hwdef-Sofirn_SP10-Pro.h” file (“FUSE_ACTIVE0_bm” should be “FUSE_ACTIVE_0_bm”). Probably a change in the attiny pack. Anyway, not important.
Please note, I don’t have an SP10 Pro or TS10 so this was untested. However, I only had to uncomment 3 lines in 3 separate files to remove the auto reverse direction reset from the ramp, candle, and lightning modes.
Also, you should now have the new tactical mode: 6C from off
More info on tactical mode: ~toykeeper/flashlight-firmware/anduril2 : revision 657
Another option instead of disabling the auto reverse reset is to change the default timeout from 2/3sec to something much higher, like 1 minute (if you prefer). After a minute I’d likely forget which direction I last ramped ![]()
SP10 Pro: anduril.sofirn-sp10-pro.hex - no reset ramp direction after 2/3sec - for jon_slider - Pastebin.com
TS10: anduril.wurkkos-ts10.hex - no reset ramp direction after 2/3sec - for jon_slider - Pastebin.com
Thanks! The TS10 Ramp Reversing works perfectly! ![]()
https://i.imgur.com/8GTyakt.jpg
Brilliant job! ![]()
fwiw, I dont have an SP10 Pro, but thanks for your efforts on that model.
I have an SC21 Pro, if you care to take the time…
and if you would pm me your paypal, I would like to buy you a Pint to express my gratitude
Ha, I misread that as SP10 Pro. I believe the SC21 Pro uses the SP36-t1616 config. Please check before flashing “0614”.
SP36-t1616: anduril.sofirn-sp36-t1616.hex - no reset ramp direction after 2/3sec - for jon_slider - Pastebin.com
Edit: found the proper SC21 Pro config and compiled it, see my later reply
No need; I’m already enjoying a pint at the moment.
As quahog said, there are reasons why it doesn’t work that way. However, it’s really easy to change the code to switch it to D10 style ramping… basically just remove a few lines. Even just 1 line would do it. In ramp-mode.c …
else if (event == EV_tick) {
// un-reverse after 1 second
if (arg == AUTO_REVERSE_TIME) ramp_direction = 1;
Remove that AUTO_REVERSE_TIME line. And optionally remove similar lines in candle-mode.c and strobe-modes.c.
Or, as another option, you could edit the cfg-whatever.h file for your light, and add one line:
#define AUTO_REVERSE_TIME 99999
The internal timer can only count up to 65535 clock “ticks”, so it can never reach a value of 99999. So it would never automatically reset the ramp direction.
Or, even better, change the auto reverse time to a sensible value which suits your preferences. There are 62 “ticks” per second, with a maximum of 65535, so you could set it to wait up to ~17 minutes before it resets the ramp direction.
#define AUTO_REVERSE_TIME 55800 // 15 minutes
The default value is in config-default.h. You could simply edit this one line to set a new value which applies to all hardware models:
#define AUTO_REVERSE_TIME (TICKS_PER_SECOND * 2 / 3)
Anyway, the hard part is getting the compiler environment set up. That depends on your OS, and although it’s usually pretty straightforward, attiny1616 devices like the TS10 require a few extra steps to install some files from Atmel. I’d recommend doing it though, because then you can change all sorts of things and really tailor it to your exact preferences.
Oh, I found the proper config for the SC21 pro “0632”
SC21 Pro hex: anduril.sofirn-sc21-pro.hex - no reset ramp direction after 2/3sec - for jon_slider - Pastebin.com
thanks for trying to help, but, I have neither the hardware nor the comprehension skills to figure out how build my own hex files.
Outstanding! works perfectly… woohoo!
fwiw if anyone else tries to download the file, what worked for me was to display the RAW file and then save it with .hex at the end of the filename
eg: SC21rampmod.hex
It’s been a couple of years since I asked the original question,
Have any of the other manufacturers come out with an 18650 light as compact as the SC65 with a similar UI?
The closest that I’d venture to guess is the Skilhunt M200. Similar UI.
There is the ZL SC65 that replaced the SC64.
True. But the SC65 is so similar to the SC64, it might not be worth the upgrade.
If I lost my SC64 I would get the SC65 - I was just wondering which other manufacturers were doing something similar. I will take a look at the M200. Thanks
