I tested some non Easywhite binned 4000K XP-L2s a while back and found the CRI90 versions to be green/yellow in tint while the CRI70 versions were quite alright. Both suffered from the tint shift within the beam i.e. the Cree rainbow.
The 2-step CRI90 XP-L2 in the Zebralight SC64c should guarantee a nice tint, but several reports from users have indicated otherwise. Fortunately a fellow flashlight enthusiast loaned me his SC64c for testing. He has already decided to return it as he was spoiled by the much nicer H600Fc.
Beam and tint
Turns out that the 2-step means squat. The light doesn’t measure inside the 2-step quadrangle at any point in the beam. So obviously it doesn’t do it integrated either. For this single reason, I would return the light. The 2-step offered by Cree is not a reason for Zebralight to not use Nichia and I’ve never seen anything this bad from a 219C or 319C even though they can’t match the luminous efficacy of the XP-L2.
There’s an almost indistinguishable brownish spot in the middle of the hotspot. The corona is a strong yellow/green and the spill again turns cooler. Yellow is probably the best shade to describe the overall tint. Definitely not the prettiest of beams.
Tint within the beam
Tint in different brightness modes
Beam profile
The color temperature stays warm all the way to the edge of the spill. Fortunately there’s no strong purple there.
The duv (deviation from the neutral black body line) stays on the greener side of things throughout the beam peaking in the corona.
Color rendering
The CRI (Ra) is some 2-5 points under the advertised 93-95, but that wouldn’t be a deal breaker for me at least. Color rendering drops on the higher modes which is common for single die high CRI Crees.
Output and runtimes
The Zebralight SC64c was tested with the battery they recommend, a Sanyo NCR18650GA. Button tops or protected cells don’t fit in the light.
The PID thermal requlation hunts a bit in room temperature on H1. If cooled well enough, the light doesn’t step down.
The output falls a bit short of advertised (814 vs. 900 lumens or –10). On H2 or “341 lm” the difference is bigger as I measured it at 283 lumens (–17). This discrepancy is strange as usually their numbers are accurate, though some of the difference can be explained by the sample variance. ZL doesn’t have runtimes listed on their site at the time of writing this.
Zebralight does deserve the usual praise for their amazing driver which offers rock solid output regulation and excellent efficacy. Assuming the emitter used is the XPLBWT-00-0000-000UU640H which is spec’d at 417lm @ 1050mA / 2.90V or ~3W it has an efficacy of approximately 140 lm/W.
The losses from the driver, reflector and lens are very small. I got 117 lm/W on the H2 mode. This is the highest I’ve ever tested for a CRI90 flashlight. 80 lumens for over 21 hours is also quite a feat.
Just give the ultimate EDC light to us with a decent emitter, please.
Flicker
There’s some ripple on L1, but because of the limited modulation depth and high frequency it isn’t visible. On higher modes the flicker is non existent.
Flicker on H1
Flicker on H2
Flicker on M1
Standby drain
There’s insignificant parasitic drain on the battery when the light is switched off. I measured the standby drain at a minimal 26µA.
