Hello everyone,
I tried to shoehorn Tom E’s Narsil manual in a table.
It’s called Narsil M Cheat Sheet and you can download the PDF from this Google Drive page.
https://drive.google.com/folderview?id=0B0v3MZNiBWcDQmpwRjRyRFp5SFk
the short link is:
http://bit.ly/narsil-cs
Feedback is appriciated.
Thanks
Joechina
- Tom E’s thread for NarsilM
http://budgetlightforum.com/node/54635
EDIT:
- Found a review with two nice UI-Diagramms for the Q8.
Maybe they are better to understand.
http://www.candlepowerforums.com/vb/showthread.php?443580-Review-Thorfire-BLF-Q8-5K-lumen-designed-by-FLASHAHOLICS!
- Hello,
two new cheat sheets vor NarsilM v1.2 are up
- one for the Q8
only mayor change is a link to a video for beginners to program Narsil.
http://bit.ly/narsil-vid3 from 8min30sec on
Name is: NarsilM CS v12 Q8 2017-12-03
BLF GT
one for the
Name is NarsilM CS v12 GT 2017-12-03
- The Cheat Sheet for NarsilM v1.2 is ready. NarsilM CS v12 Q8 2017-11-23.pdf I also made a Rev. C for NarsilM v1.0
- NarsilM CS v10 Q8 2017-11-23
(only Lazy-R-us must update)
- There is a new cheat sheet for NarsilM v1.0 (for Q8 Rev. B) Narsil M Cheat Sheet 2017-10-25 from
Changes:
- The cheat sheet has now the same values for mode groups as the operation manual that came with the Q8.
- The ? Instead of ° (degree sign) seems to be a glitch on a chinese computer.
- A sentence below the pictures.
- A few words about how to set temperature step down.
There is a new notes section:
- Added examples how to click
- Link to JasonWW’s videos
- The version
*Narsil M Cheat Sheet 2017-07-20 *
is the version sent to thorfire
- I made a new version
*Narsil M Cheat Sheet 2017-07-19 *
The edits are only on the first page
- with corrected links
- and added how to switch off the indicator light.
The sheet is on the same Google folder, but it has now a bit.ly link
NarsilCheat Sheet (PDF): http://bit.ly/narsil-cs
Reserved 1
Reserved 2
Dude, that is slick! Really want to get my hands on a Q8, sounds like it will happen soon!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Wow very nice Joe!
Let’s ask Thorfire to print this at 95% landscape and put it in the box for it has links to the important BLF posts and threads and a clear overview
Awesome, thanks so much!
It is done when it is done
How my BLF Specials generally work, please read before asking Qs
The Q8, Exciting a groupbuy for a Premium BLF special high lumens soda can light!
The GT, A BLF special GIGA thrower
The FW3A, a TLF BLF special small, elegant, powerful triple
Lithium Ion safety 101 important read
Sorry grammarlovers, I am a real King Typo.
Nice, thanks!
I will store it in the Q8.
Got it working, it took changing the printer setting to A4 (it appeared to be in USletter for some reason) and then front and back aligned almost perfectly.
Note to self: always bring your reading glasses when using the Q8
link to djozz tests
@djozz
Whoo, looking good.
I don’t why you had letter format, mine is everything in A4.
I don’t know if it fits, maybe you need verry thin paper.
Cool, I’ve added this to the others
- LEDs & Other Stuff - - UI CheatSheets - - CRX Mods & Builds - - Stuff for Sale -
- The Old Lumens Flashlight Modders & Builders Challenge is Now Open - Link -
Thickness of the stack that I made is 1.6 mm. I will have a look at home tonight how well it fits, but it feels thin enough
link to djozz tests
Thickness of the pack is 1.6mm, the space in the rear of the Q8 proto3 is 2.2 mm. So it fits!
link to djozz tests
Wauw!
That is great!
Also neat that owners can write phone Nr and email on it, ready for a BLF meeting
Thanks djozz for the video and testing!
I guess that’s a unique feature for a flashlight
Are there BLFers using the latest Narsil version who can check this?
Would be awesome for it is about time to email Barry the to be printed manuals.
I can’t check any info contained on the cheat sheet, but nicely done on the actual cheat sheet!
Awesome manual now it is time for Q8.
Man i wished it could happen, imagine a BLF gathering but i am living too far away. How many lumens in total if we switch on all the lights we have at the gathering
Reviews: Astrolux MF01s, Haikelite SC26, Fitorch P30R, Nitecore TINI, Amutorch JM70, Utorch S1 Mini, Nitecore TIP, Haikelite MT09R, XTAR OVer 4 Slim Charger, Vollsion MR12-D, Nitecore HC33, Nitecore EC23. Lumintop SD Mini II XPL, BLF Q8, Astrolux MF-01 Nichia, Convoy C8 Clear, Convoy S2+ Desert Tan, Nitecore Concept 1, Emisar D4, Haikelite MT01. Nitecore Tip 2017, Imalent DN70, Haikelite MT07 Buffalo, Haikelite SC01, Haikelite MT02, Haikelite MT03
Probably a lot! I EDC probably 4k lumens. But for special occasions I bring bigger lights.
Whew. This could be a new competitive maze-type game.
Starting off at one setting — find the minimum number of clicks to end up at a different setting.
Hello,
I need proofreaders.
I hope the new notes help to start with NarsilM.
I edited the OP:
Changes:
I feel like the dumbest guy alive. I can’t figure out how to program from ramp to modes. I’ve read the directions 20x and I know I’m missing something simple
Hold down the switch for about 8 seconds until the light flashes. When it does click the button one time and it will disable ramping or two times to enable it. After you do this hold down the button til the light shuts off. Don’t worry about what the light is doing(flashing or whatever) just keep to this direction and it should change for you.
It appears I am the only one that is going to say this, but I decided not to buy a flashlight with Narsil now that I have seen this. Honest.
About CRI_Grade
My Spectrometer Tests:
SST-20 4000K
219b R9080 4000K
COBs_5700K_CRI95+
E21A R9080 5000K
D-C-Fix Diffuser Film
I show going from ramping to mode sets and then back again in my video.
https://youtu.be/xrwP3gG0I_A
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
Seen what?
Once you try Narsil you will want all your lights to have it. It’s a simple ramping up and down. Just leave everything at default levels and enjoy. Lol
Cool... Thanks...
Believe it or not mine printed out correctly the first try lol... Even I didn't expect that as my printer skills change with each printer model upgrade.
Thanks again.
Terry White
Skype terrywhite1@live.com
Hm, have you an idea where you get stucked?
Switch from RAMPING to MODES
(you hold for a long time, if you ramp down it’s easier on the eyes)
- hold for 8sec,
- after two short blinks and one blink, — do a single click (1x).
- The lamp continues to blink out configuration for MODES.
(Basically it is holding the button till it blinks 2x and 1x and than a double click shuts RAMPING on.
Or a single click shuts it off.)
- Now you can wait till the lamp is gone through the rest of the config menu.
- The lamp will blink four times short when finished.
Or if you don’t want to wait you do a click and hold till the lamp blinks four times.
Sorry, I can’t explain it better.
If you tackle the hurdle can you please report back what the problem was?
Can you please edit the typo?
two clicks enables ramping
And thanks for the help here in the thread!!
Can you tell me why you get the stuff and others have so a hard time?
Oops. It’s fixed:)
JoeChina,
I think one thing that would make the cheat sheet easier to read would be to make one section of it for ramping and another for discrete modes.There is a LOT of information that needs to be communicated in there, but when I’m in ramping, I don’t care in the least about what clicks do in discrete mode, and vice versa.
I’m willing to take a stab at it, do I recall that there is a link somewhere with non PDF version of the data you have compiled?
PS – one typo I did see was in the tip of the the hat to me (thank you) re the larger rolled version – only 1 ‘z’ in Lazy-R-us
Lazy-R-us
I simply love the Q8 UI the way it comes out of the box. Yes, it can take a little playing with it to learn the length of press to turn on or off. I had more of an issue with finding off at first. I absolutely love the ramping and the simple way to change direction. I love it so much I have not bothered to explore the discrete modes option.
BLF Member Map Add your name and location.
joechina is it you intention that in your latest cheat sheet
only version 1.0 is listet under Overview Click Sequences?
Yes, I’m sure. This thread is from July 2017.
Wait, I think I see your confusion. You are mixing up the older Narsil with the newer NarsilM.
Lots of people confuse them because they don’t notice the M on the end. (Blame Tom E for the similar names. I think it was his doing.
The latest version is currently NarsilM v1.0.
NarsilM v1.2 is being tested currently and will be out soon.
