A quick n dirty beamshot
The trees are 200m away
C8 with OSRAM KW CSLNM1.TG (2,8A)
Beautiful
Hello,
I recently made a fixed thrower with a Convy L2 host.
Parts info:
CULNM1.TG 4040die (LED4Power.com)
LD-A4-20 driver 6A (LED4Power.com)
50mm plano apsheric AR coated (marinebeam.com)
Small RLT collar
Convoy L2 host
GOLISI S43 26650
Testing data:
Driver setting: 4.75A
Current measured at cap: 4.94A
Measuring device: Lutron LX-1108
Measuring distance: 5meters
*Without collar: 16700lux@5m@30s (417 Kcd)
With RLT collar: 31400lux@5m@30s (785 Kcd)*
_
Here is my issue:
While using this desmos calculator made by Enderman
Intensity calculator
My theoretical maximum should be 1700Kcd.
However, my result at 800Kcd is half of theoretical maximum! ]:<
Some side notes:
This is my first time ever using a RLT collar.
My collar location should be near optimal because I used 0.10mm shims until I got the highest reading. And also, it is almost double the reading without the collar.
I tried driving at 5.5A and the reading was only a bit higher
35200lux@5m@30s (880 Kcd)
I have only tried one CULNM1.TG. I have another, but I don’t want to change it unless it is highly likely my current emitter is defective.
_
Am I doing something wrong here? Getting half of theoretical max is no fun.
I am already really satisfied with how insane the beam looks. I can see the beam so clearly once it exits the lens.
I will be purchasing the Acebeam W30 because I can’t believe there is something out there with twice intensity as mine!
Try measuring at 20m?
That is an awesome L2 build! Don’t fret about theoretical maximums you got from a calculator. 880 kcd from a 50mm lens is excellent performance!
Very nice!
We really need beamshots from your build
800kcd is unimaginable for such a small head with LED tech. How did you secure the 50mm aspheric to the head?
Are you sure you entered the numbers in the calculator right?
If I base the calculations on this test and use sample 1 as a reference, the calculator gives me 841 kcd. With sample 2 I get 914 kcd.
I enter:
So…your results are OK, it’s hard to tell whether you can improve on that.
You got a really nice light. :+1:
Your numbers are fine, it shows that your build is well-done . Indeed these Osrams do not give same multiplication of a collar that a XP-G2 gives (perhaps because of the shiny finish).
At low currents Enderman reached a multiplier of 1.07. So there’s some saturation going on at high current.
But at low it’s still less than 1.19. I don’t know the reason.
ADDED: at 5A the factor was 0.96 so a little better than likevvii’s.
If I base the calculations on this test and use sample 1 as a reference, the calculator gives me 841 kcd. With sample 2 I get 914 kcd.I enter:
- 290 cd/mm² (or 315 for sample 2)
- note: I calculated that as 969 lm / 1.069 mm² / π
- 50 mm lens diameter
- correct the Wavien collar multiplier to what you actually got (from 1.19 to 0.88)
- note that 1.19 is based on an old test of XP-G2. Osrams respond worse to a collar. Enderman got .887 from CSLNM1.TG, so here you’re right on the spot.
Ohhhhhh!!
Thank you for the info!
I had put in an intensity of (500cd/mm²) because I assumed that the RLT collar would bring it up near there. Just to be sure I am doing it correctly; I need to set the intensity to ~280cd/mm²? Even though the RLT collar would increase it, I need to leave it alone and have the RLT collar multiplier take care of the multiplication?
After changing:
Intensity: 500cd/mm² to 280cd/mm²
RLT collar multiplier: 1.19 to 0.88
I get: 904Kcd! This is much closer to my recorded data.
Could you verify if my settings are changed correctly?
Hmm…with 280 cd/mm² I get 812 kcd.
From the defaults, I changed only the 3 fields that I mentioned above.
I see, I had been playing around with that calculator for over a period of weeks. I messed around with all kinds of values. I just realized I had changed the: Lens clear aperture CA (%) from 0.90 to 0.95 because I had an AR coating. My values match yours now.
Thank you again
For those who messaged me about mounting the lens, I have the link to the album below. I used 3D printed parts to seat the lens perfectly focused. After screwing on the head, the lens would be very secured and unable to move. I was able to adjust the RLT collar easily because the lens comes off very easily. However, it took about 14 iterations of 3D prints before I got the right fitment and focus.
L2 build and beamshot pictures
I really want to reach 1Mcd with the convoy L2 host. The best thing about the L2 is that it is very compact and the cooling is great because the entire head is the pill. The convoy L2 allows for a max ~58mm diameter lens. I am in the process of talking to multiple suppliers in China to produce a precision grounded thin double aspherical lens so the convex bulge wouldn’t stick out of the L2 head.
The calculator takes AR coating into account under “Glass transmission”. The default is a coated lens.
Custom lens….that’s expensive stuff. Maybe getting a stock 60 mm one and grinding the sides would be a better idea? Or opening the head a little more?
Good luck with getting your L2 even better!
Wow, thanks for the album, impressive!
Really need to find someone with a 3d printer or lathe
I finally took my Z1 to the local reservoir… I took my MF02 and modded L6 for comparison, among others.
I know the MF02 should be over 400kcd, but to my eye the Z1 with CULNM1 threw better. Of course it was a pencil beam in comparison, but it is quite impressive. One interesting thing I noticed with my Z1 was that I had to “zoom it out” a little to correct the focus on the CULNM1. At night, the visible beam made it quite apparent that the focus was wrong with the head fully unscrewed.
I thought this might be interesting!
The light on the left is the Convoy S2 that I showed before with SMO reflector + Osram KW CSLMN1.TG + Led4Power driver.
The light on the right is the Acebeam TK16 (AL) with 3 x Osram KW CSLMN1.TG + Carclo 10507.
The farthest tree is at 115m:
Farthest trees are at about 190m:
The house is at 213m:
Conclusion: even below optics, this LED is awesome!
Sorry, the photos show different weather conditions as they were taken in different nights. The distances remain, though
These pictures dont look like the same exposure settings.
Look how much brighter the street is lit in all of the Acebeam shots. Camera is out smarting you
