Test / Review: Keeppower 18650 3400mAh (Black)
59 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 42 min ago
DSC_2588
Official specifications:
  • 18650 3400mAh Protected Rechargeable Battery
  • Cell: Panasonic NCR18650B 3400mAh
  • Min Capacity: 3250mAh
  • Typical Capacity: 3400mAh
  • Normal Voltage: 3.6V
  • Quality Lithium Ion rechargeable cell
  • In Built Safety Circuitry
  • Protection Circuit (Against overcharge, over discharge, over current and short-circuit.)
  • 4.2 volts max voltage and 3.6 volts nominal voltage
Keeppower%2018650%203400mAh%20(Black)-info
This is the latest cells from Panasonic with the highest capacity.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
DSC_2586
DSC_2589 DSC_2590
DSC_2591
DSC_2592
Keeppower%2018650%203400mAh%20(Black)-Capacity
These batteries are good at both low and higher current.
Keeppower%2018650%203400mAh%20(Black)-CapacityTimeHours
Keeppower%2018650%203400mAh%20(Black)-Energy
Keeppower%2018650%203400mAh%20(Black)-PowerLoadTime
Keeppower%2018650%203400mAh%20(Black)-TripCurrent
Keeppower%2018650%203400mAh%20(Black)-Charge
Conclusion
This battery has higher capacity and better high current capacity than its predecessor (3100mAh/NCR18650A).
With the added protection from Keeppower it is a very good battery.
Notes and links
Keeppower is a OEM manufacturer, i.e. many of the batteries they produce is sold with other names on them.
The batteries was supplied by Keeppower for review.
Edited by: sb56637 on 08/26/2014 - 17:45
scaru
scaru's picture
Last seen: 3 years 1 month ago
Thanks HKJ! Do you know are those for sale yet? I can't find them on the website.
HKJ
HKJ's picture
Maybe they are waiting until I publish this test Smile
NightCrawl
Last seen: 3 years 10 months ago
They are for sale if you want to buy 100pcs.. Silly
Great reviews HKJ, I'll give you a cumulative "thank you". Smile
bose301s
bose301s's picture
Well, I didn’t think they would be all that much better than the 3100mAh version, I was wrong, they are quite a bit better in absolutely every regard.
Woody
Woody's picture
Last seen: 6 days 29 min ago
NightCrawl wrote:
Great reviews HKJ, I’ll give you a cumulative “thank you”. Smile
+1 Thank you HKJ, much appreciated.
SashiX
SashiX's picture
Last seen: 5 years 9 months ago
Another WOW cell from them Shocked (well, from Panasonic :bigsmile: ) Best 18650 out there?
Thanks for the review, Henrik Wink
sb56637
sb56637's picture
Last seen: 13 hours 49 min ago
Thanks very much for the excellent review! Frontpage’d and Sticky’d.
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 1 year 4 months ago
I was told by a person at Keepower that this battery is just a sample, and that it will be mass produced in about 2 months.
Great review nonetheless.
torchythebatteryboy
scaru wrote:
Thanks HKJ! Do you know are those for sale yet? I can’t find them on the website.
Apparently NCR18650B are in short supply just now. I’ve tried a few suppliers.
Yellowhorse
Yellowhorse's picture
Last seen: 4 years 6 months ago
Am I reading the information right? 11 amp draw before the protection circuit kicks in? If that is right, I will be getting a few of these to replace some of my IMR AW’s. For safety’s sake.
As usual, nice review. Thanks.
HKJ
HKJ's picture
Yellowhorse wrote:
Am I reading the information right? 11 amp draw before the protection circuit kicks in? If that is right, I will be getting a few of these to replace some of my IMR AW's. For safety's sake. As usual, nice review. Thanks.
That is correct, but at a continuous load it will probably trip at a lower current (Maybe around 10A).
Running a battery this much above the rated current will also reduce the lifetime significantly.
torchythebatteryboy
HKJ wrote:
Yellowhorse wrote:
Am I reading the information right? 11 amp draw before the protection circuit kicks in? If that is right, I will be getting a few of these to replace some of my IMR AW’s. For safety’s sake. As usual, nice review. Thanks.
Sounds like faulty pcb, you would be better off with the bare cell.
HKJ
HKJ's picture
It is not a faulty PCB, but it probably has 3 transistors. Many 2900/3100mAh batteries has the current limit at around 11A.
agedbriar
Last seen: 9 months 2 weeks ago
Kudos for the Battery Comparator, HKJ !
wesco
Last seen: 7 years 4 months ago
Hey I know these are only available in large quantities I.E. 100 pieces. I don’t have any need for that many batteries… yet Sad
I’ve made an inquiry as to price for 100 pieces.
My question to y’all is if I make a purchase of these batteries direct from source at 100 pieces would anybody be interested in buying excess batteries off of me. I don’t yet know what the cost is seing as I just sent the inquiry 5 minutes ago. But I will keep y’all posted.
Chicago X
Chicago X's picture
Last seen: 6 years 6 months ago
Due to the limited availability, I would opine that you would have little difficulty getting rid of them – at a reasonable price, of course.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
Yellowhorse
Depending on the price – yes.
wesco
Well it looks like I can pick up 50 or 100 pieces and sell what I’m not going to use at about 8.50 a piece plus S&H and make a small amount back in my pocket. If enough of y’all are interested ill buy some and share the love with this new incredobat. PM me if you think you’d like to buy some pending a purchase from keeppower.
monanoke
monanoke's picture
Last seen: 3 months 4 days ago
For that price I’d be in for 4 or maybe more. Smile
C
Yellowhorse
I’m in for 4 of them.
wesco
Lol I figure that’s a lot cheaper than than you can buy lesser quality batteries. We’ll see how bad they are going to stick me for shipping. That price has some shipping from them built in. It might go up a little if they hit me hard for shipping. :~
JaredM
JaredM's picture
Last seen: 9 hours 25 min ago
I plan to purchase 3-5 depending on finalized pricing :bigsmile:
wesco
thread 1
thred 2
those are both active on this topic they should cover the info on price per unit and cost of shipping by location.
Let me know if you have any more questions. Smile
raccoon city
raccoon city's picture
Last seen: 30 min 21 sec ago
Welcome to the madness, JaredM!
Best0270
JaredM
Price
Last seen: 4 weeks 1 day ago
HKJ,
Are these on the market yet?
Prisoner 6-2-7
HKJ
HKJ's picture
Price wrote:
HKJ, Are these on the market yet?
I believe that only a small batch was released onto the market. Keeppower got some of these and send a couple of them to me for test.
When next batch is released is an open question.
Price
Thank you HKJ!
Prisoner 6-2-7
Jell
Last seen: 3 years 6 months ago
Hi HKJ, I don’t understand, what does this mean? Sorry I’m a newbie.
HKJ
HKJ's picture
Jell wrote:
Hi HKJ, I don't understand, what does this mean? Sorry I'm a newbie.
Lights needs some voltage to function and many lights will reduce brightness or even turn off, before the battery is down to 2.5 volt.
Here is an example from one of my reviews:
The light needs 4 volt to get full brightness, when the battery voltage is down to 3 volt you will only get about 30% of full brightness.
Jell
I think I get what you mean now. Thanks a lot. Smile
