Tutorial: Rewrapping a battery
55 replies [Last post]
HKJ
HKJ's picture
Last seen: 26 min 52 sec ago
Title: ★★★★★
DSC_1789
The above battery cannot be used anymore, it will short and might explode.
The wrapping will sometimes break, luckily it is a fairly simple operation to fix it.
Tools and parts needed
DSC_1801
I am using shrink wrap to repair the battery, due to the heat gun I uses, I have selected a low temperature type.
When flat it is 29.5 mm wide, the inner diameter is 18.5 mm, it will shrink at 80 Deg. C.
I bought a roll with 25 feet (7.6 meter) on ebay for $11 (Sellers name is atop_authentic_auction). This roll will last for more than 80 batteries. Fasttech has heat shrink in 1 meter pieces for less than $1.
This heatshrink is also fairly thin, this is an advantage for some lights.
Often heat shrink is specified in width of the flat tube, the table below shows the minimum sizes for different battery sizes.
diameter
DSC_1802
As a heat gun I uses a hair dryer, it is not the perfect tool for the job, but it can be used.
DSC_1803
I do also need something to measure with, my digital caliper is fine for that (A ordinary ruler could also be used).
With a caliper, remember to cover the jaws or it will short the battery.
DSC_1804
To cut the heat shrink I uses scissors.
Rewrapping
DSC_1790
I want the heat shrink tube to be about 3 mm longer than the battery at both ends, with a 68 mm battery this means 74 mm tube.
DSC_1792
The new tube for the battery has been cut of the roll.
Unwrapping
I uses the fingers to removing the old heat shrink, using a knife or scissors is unsafe.
If there is two layers of heat shrink, only remove the outer layer.
DSC_1791
The "naked" battery, do not try to bend the protection pcb out to get a look.
DSC_1794
Putting the new heat shrink onto the battery.
DSC_1795
There will be about 3 mm extra at each end.
Shrinking Shrinking2
Applying heat, rotate the battery and swipe the heat gun back and forth. If using a real heat gun, be careful with the fingers holding the battery!
It is possible to increase the temperature by covering part of the air intake on the heat gun (This might also melt the gun if overdone).
The battery must not be heated much (As long as it is possible to hold it, the temperature is fine). This is usual not a problem, the heat shrink will shrink long time before the battery is heated.
Final result
DSC_1798 DSC_1797
DSC_1799
DSC_1800
With a new covering, the capacity information is gone, to fix that I have added a label with capacity. I also included the date I got the battery.
__________________
My website with reviews of flashlights, chargers and batteries: http://lygte-info.dk/
ryansoh3
ryansoh3's picture
Last seen: 1 min 21 sec ago
Title: ★★★★
Awesome tutorial, thank you
Awesome tutorial, thank you very much!
I would just like to add that a very similar or even the same wrap used by HKJ is avaliable at FastTech at 1m units:
http://www.fasttech.com/products/1140200
Richie086
Richie086's picture
Last seen: 1 min 5 sec ago
Title: ★★★★★
Thanks for posting this HJK.
Thanks for posting this HJK. One of my Trustfire 26650 5000mAh cells is starting to loose part of the wrapping. I’ll order this shrink wrap and make the fix.
Also glad to see I’m not the only one that uses labels to print the purchase date on the cell Wink
__________________
Richie
ryansoh3
ryansoh3's picture
Title: ★★★★
Richie086 wrote:Thanks for
Also glad to see I’m not the only one that uses labels to print the purchase date on the cell ;)
I’m not quite sure if the shrink wrap will be able to wrap a 26650 cell, might be too wide… Innocent
Richie086
Richie086's picture
Title: ★★★★★
ryansoh3 wrote: I’m not
ryansoh3 wrote:
I’m not quite sure if the shrink wrap will be able to wrap a 26650 cell, might be too wide… 0:)
Thanks for the heads up. I’ll take some measurements of my cell and find the correct diameter for a 26650.
__________________
Richie
ryansoh3
ryansoh3's picture
Title: ★★★★
No problem, I’m sure you’d
No problem, I’m sure you’d figure it out sooner or later. Tongue
That Ninja Guy
That Ninja Guy's picture
Last seen: 22 hours 27 min ago
Title: ★★★★
Thanks for the great
Thanks for the great write-up!
HKJ
HKJ's picture
Title: ★★★★★
ryansoh3 wrote:I would just
ryansoh3 wrote:
I would just like to add that the same shrink wrap that HKJ used is avaliable at FastTech at 1m units: http://www.fasttech.com/products/1140200
It is not exactly the same, the one I uses is without glue.
Richie086 wrote:
Thanks for posting this HJK. One of my Trustfire 26650 5000mAh cells is starting to loose part of the wrapping. I'll order this shrink wrap and make the fix.
You have to get something that is slightly above 26 mm in diameter
Richie086 wrote:
Also glad to see I'm not the only one that uses labels to print the purchase date on the cell ;)
My experience with pens is that the markings does not last, with these labels it will last.
__________________
ryansoh3
ryansoh3's picture
Title: ★★★★
HKJ wrote:ryansoh3 wrote:I
Thanks for pointing that out.
Do you know how different it will be with the adhesive?
That Ninja Guy
Title: ★★★★
HKJ wrote:Richie086
I use an industrial Sharpie for all my cell writing, haven’t had issues with it yet…
HKJ
HKJ's picture
Title: ★★★★★
ryansoh3 wrote:HKJ
ryansoh3 wrote:
Thanks for pointing that out. Do you know how different it will be with the adhesive?
I have not tried with adhesive, but I will not expect any different when rewrapping, the final result will probably be a bit stronger.
__________________
Werner
Werner's picture
Last seen: 16 hours 39 min ago
Title: ★★★★★
ryansoh3 wrote:Awesome
I would just like to add that a similar wrap used by HKJ (this one with adhesive) is avaliable at FastTech at 1m units:
I have ordered this shrink and it is without adhesive glue whatever…just blue plastic which is a tight fight on a 18650.
pictures in another thread:
http://budgetlightforum.com/node/17907#comment-314389
I also rewraped a 16340 with the fasttech shrink, this worked but the wrap doesn’t get perfect plain…
ryansoh3
ryansoh3's picture
Title: ★★★★
Werner wrote:ryansoh3
Thanks for the confirmation!
Streamer
Streamer's picture
Last seen: 10 hours 52 min ago
Title: ★★★★
Nothing but red x’s…can’t see
Nothing but red x’s…can’t see the pics.
HKJ
HKJ's picture
Title: ★★★★★
Streamer wrote:Nothing but
Streamer wrote:
Nothing but red x's...can't see the pics.
Looks like the server is down, it will probably not take very long before it is up again (I uses a hosting service).
__________________
CheapThrills
CheapThrills's picture
Last seen: 6 hours 15 min ago
Title: ★★★★★
Cannot see pics at the
Cannot see pics at the moment.
HKJ
HKJ's picture
Title: ★★★★★
CheapThrills wrote:Cannot see
They are back again.
__________________
CheapThrills
Title: ★★★★★
Nice, thanks! I have
Nice, thanks!
I have re-wrapped some batteries, did not bother to measure the wrapper before cutting. Just estimated it by eye.
I think after re-wrapping it feels at least as much if not more durable than before.
stevetexas
Last seen: 1 hour 9 min ago
Title: ★★★
As Usual
HKJ gives good advice.
I use a Laundry Marking pen from the Office Supply to mark cells. This is better than the so called “permanent marker”. The Laundry Markers are the ones that never wash out of clothes, even in hot water. Don’t get it too oily before you mark it.
If you mark it….better check your spelling first, you ain’t gonna change it.
ek9cv5
Last seen: 7 hours 24 min ago
Title: ★★
Thanks for the tutorial
Don
Don's picture
Last seen: 29 min 54 sec ago
Title: ★★★★★
I have several metres of
I have several metres of green shrinkwrap suitable for 18650’s – anyone in the EU who wants some – PM me – the cost will be the postage plus a few pennies. The cells I needed to rewrap have been rewrapped. Happy to supply it in 75mm chunks. And don’t pay till it arrives. Experience there.
__________________
The numbers from my light tests are always to be found here.
Google Docs
Brted has done a good job of cleaning this up here. You can easily sort by any parameter. Good job Ted!
Badge
arjay
Last seen: 5 weeks 1 day ago
Title: ★★
Thanks for the
Thanks for the tutorial!
Question, isn’t the heat shrink too tight? I know that you need your heat shrink to be 3-5mm wider than what you intend to wrap. If the typical diameter of a 18540 is 18.5mm, how does your 18.5mm shrink wrap fit with a bit of room to spare? I was wondering if I should go a bit bigger by 3-5mm to be safe.
Don
Don's picture
Title: ★★★★★
The internal dimeter
The internal dimeter (unshrunk is 18.78mm). “Circumference” of the flat stuff is 59mm. So 59/pi gives the “diameter”.
__________________
Google Docs
Badge
Werner
Werner's picture
Title: ★★★★★
it is tight but it works,
it is tight but it works, like i mentioned this shrinks not so much thats why my 16340(16mm diameter) is not so tight shrinked than my 18650.
HKJ
HKJ's picture
Title: ★★★★★
arjay wrote:Question, isn't
arjay wrote:
Question, isn't the heat shrink too tight? I know that you need your heat shrink to be 3-5mm wider than what you intend to wrap. If the typical diameter of a 18540 is 18.5mm, how does your 18.5mm shrink wrap fit with a bit of room to spare? I was wondering if I should go a bit bigger by 3-5mm to be safe.
No, as long as it can be pulled over the battery it is fine.
I have added a table with diameter and minimum width of the heat shrink tube for the common battery sizes. If you buy from somewhere where they do not specify that it fits a specific battery, I would recommend to get at least 1 mm extra.
__________________
NightCrawl
Last seen: 1 hour 11 min ago
Title: ★★★★★
The larger the heatshrink,
The larger the heatshrink, the thicker it will get. So for most flashlights its best to use a heatshrink that doesnt have to shrink very much.
arjay
Title: ★★
Thanks for clearing that up
Thanks for clearing that up guys. I didn’t want to end up picking up the wrong ones.
monanoke
monanoke's picture
Last seen: 6 min 52 sec ago
Title: ★★
Thanks!
Thanks for the write up HKJ. Just broke the wrapping on one of my keeppower 18650 and was looking for the wrap to fix it.
a
__________________
C
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 1 day 9 hours ago
Title: ★★★★★
That is actually easier than
That is actually easier than I thought.
kreisler
kreisler's picture
Last seen: 17 min ago
Title: ★★★★★
nice crisp tutorial thanks!
Wink
__________________
*FMI* i have 2 pending orders (=1*E09 +1*USPS).
deletions, **eisl, dis**iminatory, harmless
Pavithra_uk
Pavithra_uk's picture
Last seen: 1 min 12 sec ago
Title: ★★★
awesome tutorial
awesome tutorial
ILIKEFLASHLIGHTS
Title: ★★★★★
Pavithra_uk wrote:awesome
Pavithra_uk wrote:
awesome tutorial
I agree.
Super job!
C-channel
C-channel's picture
Last seen: 11 min 15 sec ago
Title: ★★★
Thanks. An excellent write
Thanks. An excellent write up.
__________________
My flashlight collection.
DarkSide
DarkSide's picture
Last seen: 1 week 2 days ago
Title: ★★★★
Fine tutorial
Fine tutorial
__________________
"Don't sell your a-s for a Flashlight"..
BLF A8
Rufusbduck
Rufusbduck's picture
Last seen: 8 hours 50 min ago
Title: ★★★★★
Nice tutorial and thanks for
Nice tutorial and thanks for all the extra info on supply and sizing. Really helpfull.
__________________
Scott
Old-Lumens
Old-Lumens's picture
Last seen: 29 sec ago
Title: ★★★★★
Thanks for posting this tutorial. Very Nice!
__________________
1.2miles
From the Bowels of the O-L Workshop-   My Youtube Channel
War Dogs, Making it Home - Rescue Dogs for Returning Vets
Suncoaster wrote:
Flashlights are like women. You can't be objective.
Red Green "If the women don't find you handsome, they should at least find you handy."
Nichia 219 Comparison
PyTech
PyTech's picture
Last seen: 4 hours 23 min ago
Title: ★★★
Great info, need to do this
Great info, need to do this on 2 batteries and stop using tape on em. Didn’t think a hair dryer could manage. Now I know. Thanks
__________________
-Sean
HKJ
HKJ's picture
Title: ★★★★★
ILIKEFLASHLIGHTS wrote:That
PyTech wrote:
Great info, need to do this on 2 batteries and stop using tape on em. Didn't think a hair dryer could manage. Now I know.
That was the reason I made this tutorial. It is easy and cheap to make a good repair, instead of doing a unsafe repair.
I did play a bit around with the hair dryer, coving part of the air intake with a hand, did increase the temperature and made it faster to shrink the heat shrink, but be careful with doing it, it can damage the hair dryer.
__________________
nitro
nitro's picture
Last seen: 13 hours 52 sec ago
Title: ★★★★★
Does anyone have another
Does anyone have another source for different collars ? And I have some 18650 and I need button tops where can I buy them
Shaquille
Shaquille's picture
Last seen: 6 days 21 hours ago
Title: ★★★
excellent ! thanks Hkj
EDCPlus
Last seen: 4 hours 24 min ago
Title: ★★
I’ve heatshrinked well over
I’ve heatshrinked well over 1000 cells, I’m quite good at it now. Smile
I couple additional tips. Heatshrink the positive end of the cell first by rotating the cell 360 degrees in your hand. Then go to the bottom of the cell.
Secondly, heatshrink along the crease from end to end. Use a low enough temperature or point the heatgun at a distance so it shrinks slowly. This prevents a wavy effect.
After this is done, give the entire cell a quick pass over by the heatgun to shrink the rest.
__________________
www.edcplus.com
Shaquille
Shaquille's picture
Title: ★★★
EDCPlus wrote:I've
EDCPlus wrote:
I've heatshrinked well over 1000 cells, I'm quite good at it now. Smile I couple additional tips. Heatshrink the positive end of the cell first by rotating the cell 360 degrees in your hand. Then go to the bottom of the cell. Secondly, heatshrink along the crease from end to end. Use a low enough temperature or point the heatgun at a distance so it shrinks slowly. This prevents a wavy effect. After this is done, give the entire cell a quick pass over by the heatgun to shrink the rest.
how on earth did you manage to heat shrink a 1000 cells ? Do you work in a cell manufacturing factory???
That Ninja Guy
Title: ★★★★
Shaquille wrote:EDCPlus
Shaquille wrote:
EDCPlus wrote:
I’ve heatshrinked well over 1000 cells, I’m quite good at it now. Smile I couple additional tips. Heatshrink the positive end of the cell first by rotating the cell 360 degrees in your hand. Then go to the bottom of the cell. Secondly, heatshrink along the crease from end to end. Use a low enough temperature or point the heatgun at a distance so it shrinks slowly. This prevents a wavy effect. After this is done, give the entire cell a quick pass over by the heatgun to shrink the rest.
how on earth did you manage to heat shrink a 1000 cells ? you work in a cell manufacturing factory???
I was wondering the very same thing, unless he owns and wraps every Redilast??? Laughing out loud
Or maybe has a severe addiction
Big smile
EDCPlus
Title: ★★
:bigsmile:
When I first started Redilast, I would do a good part of the heatshrink work myself. Now days I just do it occasionally… Quality control. Smile
On a side not if you plan to do heatshrinking make sure your heatgun has a low mode. And avoid harbor freight heatguns. I had 2 fail on me in a 2 month period. And not to mention when you first get them, they smell smoke and smell bad… My wagner brand one for $17 from home depot is holding up great and is used several times a week.
__________________
www.edcplus.com
That Ninja Guy
Title: ★★★★
Cool beans.
Cool beans. Smile
feilox
Last seen: 3 hours 11 min ago
Title: ★★★★
Do you use tape or something
Do you use tape or something to hold them together? Cuz I don’t see how they stick together?
HKJ
HKJ's picture
Last seen: 26 min 53 sec ago
Title: ★★★★★
feilox wrote:Do you use tape
feilox wrote:
Do you use tape or something to hold them together? Cuz I don't see how they stick together? !http://lygte-info.dk/pic/BatteryRewrapping/DSC_1794.jpg!
No, heat shrink tube will shrink when heated, this will keep it in place.
__________________
bushwhacked
bushwhacked's picture
Last seen: 6 hours 8 min ago
Title: ★★★
HKJ wrote:feilox wrote:Do you
HKJ wrote:
feilox wrote:
Do you use tape or something to hold them together? Cuz I don’t see how they stick together? !http://lygte-info.dk/pic/BatteryRewrapping/DSC_1794.jpg!
I chuckled at the middle part.
Shaquille
Shaquille's picture
Title: ★★★
LMAO
LMAO
i wrapped a few old eneloops . I used a cigarette lighter so results werent as preety  but are ok Smile . i guess you need a good consistent heat like a neat blower with an udustable heat output to do it really well .
indenial
Last seen: 8 hours 35 min ago
Title: ★★★
Excellent instructions!
Excellent instructions! Worked like a charm after a few attempts to get the measurements/placement just right. Thanks!
__________________
My name is indy, and I've been a flashaholic since 2004.
Old-Lumens
Last seen: 30 sec ago
Title: ★★★★★
Every time I see this thread
Every time I see this thread pop up and see the photos, I think HJK should be wrapping all of our Christmas presents! Such a neat and exact job on wrapping those cells!
__________________
1.2miles
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
