There is no XRE copper pcb, right? Wrong!
27 posts / 0 new
NightCrawl
Last seen: 3 years 11 months ago
So shiny. Big Smile
dave_
Last seen: 11 months 1 week ago
Looks great!
Do you have any plans what to do with that thing yet? Smile
djozz
djozz's picture
Last seen: 12 min 45 sec ago
Hey, you're a genius, I have two of those boards unemployed, let's see what the xre really can handle Evil
Nightbird95
Nightbird95's picture
Last seen: 6 days 5 hours ago
I think this is a good mod to further push a Jacob A60.
djozz
djozz's picture
 I will do a test, but the xre has a large heat sink pad , so the transfer to a traditional alu board may be quite good already and not much is gained on copper..
Hikelite
Last seen: 22 hours 11 min ago
You now do not have a dielectric layer that at one point makes it's low thermal conductivity present.
Hikelite
There's a lot of solder there no kidding.
NightCrawl
djozz, I'm really looking forward to your crash test. Smile
It will come to life in my Small Sun ZY-C10 (aspheric thrower).
@Hikelite: I soldered it with some pressure, so there was a lot of solder squeezed out.
bdiddle
Last seen: 1 year 6 months ago
Did it require any work to get in on?
Newb
NightCrawl
Nope, none at all. You just have to center it by hand when reflowing. But the solder pads are almost identical.
Tom E
Tom E's picture
Last seen: 7 hours 27 min ago
Wow - I gotta try this... Mostly have been switching over to XP-E2's because the lack of a copper star for these XRE's.
benz
benz's picture
Last seen: 7 months 5 days ago
Subscribed! Smile
relic38
relic38's picture
Last seen: 2 years 2 months ago
Nice! I was wondering if that would fit, and there it is. Party
I predict some very hard driven XR-E throwers are about to appear Smile
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
GottaZoom
GottaZoom's picture
NightCrawl wrote:
So shiny. Big Smile
Dedoming it and removing the ring next?
janko.hrasko
janko.hrasko's picture
Last seen: 1 year 1 month ago
GottaZoom wrote:
NightCrawl wrote:
So shiny. Big Smile
it would me easier to just dedome xp-e2 Smile
NightCrawl
I tried that, doesn't work with the C10, so the dome will stay in place. Also, it's a rare EZ900. Smile
Rufusbduck
Rufusbduck's picture
Last seen: 11 months 2 weeks ago
Velly interesting.
Scott
djozz
djozz's picture
I did the test, and because the results are not that spectacular, I will not work it into nice graphs, but just give the summary Tongue Out.
I had these XR-E's leftover from two identical small Spiderfire flashlights that I modded, I hoped that they would perform the same:
I reflowed one on the MT-G Noctigon, one on a aluminium 20mm star (I think it went well), screwed the boards on plenty aluminium with Arctic Silver 5 in between. I soldered the +-wires together, so that during testing I could switch between the two leds by just re-clamping the minus:
The rest of the set-up I described in the crash-test threads that I started, basically I connected a power supply directly to the leds. I put identical small OP-reflectors on top of the leds (no glass lens this time) to measure  ceiling bounce lux. The test results ( Tongue Out ) :
Summary:
-Up to 1.5A the two leds perform very similar, so I think (I hope) that any differences between the two boards is mainly caused by the type of board and not by individual differences between the leds. But the differences in the tests are not that huge, so feel free to disagree on that. Oh, and I am not going to swap leds and boards to do the reverse measurement to check it.
-the peak output on the aluminium board is reached at about 2.0 Ampere, and is 300 lumen out the front of the reflector, the peak output on the Noctigon board is reached at 2.4 Ampere, and is 360 lumen OTF of the reflector. That is a gain of 20%. If you compare the output at the same current (at 2.0A which is the peak output current on aluminium) the gain is 10% when using copper.
So according to this quick and not very accurate test the benefit of using a copper board for the XR-E led seems not to be as great as with the XP-E/G or XM-L led. Not quite noticable by eye that is, for the real lumen hunter any gain is good of course Wink.
relic38
relic38's picture
Definitely not the same gains as the modern emitters, but it’s about 20% or so. Significant if you plan on pushing an extreme thrower. I wonder if an XP-E on copper will do better?
I still think XP-G2 on copper at 4.5A ish makes one of the highest surface brightnesses. XM-L2 at 6A+ probably close behind.
Welcome the night.
Tom E
Tom E's picture
Excellent work djozz! This is very helpful - you identified the peak amperage, and bottom line like you said, a 20% improvement at that peak amperage. Of course there will be variations.
Do you know if these are EZ900 or EZ1000's? And if they are Q5's or R2's? Probably Q5's because of what light they came from...
djozz
djozz's picture
They look like EZ1000's and could be any bin (and pretty sure not R2). I just hoped that the bin would be the same between the two, since they came from the same source.
djozz
djozz's picture
If the behaviour of the xpe isn't much different from the xpe2, it does better (see Match's test on the xpe2 on copper vs aluminium).
Nightbird95
Thanx for sharing the results djozz! :bigsmile:
I think I know now how to mod my Jacob A60 and other XR-E lights. Smile
relic38
relic38's picture
djozz wrote:
If the behaviour of the xpe isn’t much different from the xpe2, it does better (see Match’s test on the xpe2 on copper vs aluminium).
Oops, I meant XP-E2. Smile
Welcome the night.
GottaZoom
GottaZoom's picture
NightCrawl wrote:
I tried that, doesn’t work with the C10, so the dome will stay in place. Also, it’s a rare EZ900. Smile
Too bad . . my sinkpad samples didn’t include MTG copper so my de-domed XRE may stay on alum.
Rufusbduck
For it’s die size the XRE has by far the largest heat pad so an aluminum mcpcb is relatively easy to drill for a 12 or 10awg solid wire. Easier than that though is using a Dremel to grind off the plus/minus pads on the bottom and solder it directly to copper. The pads on top are large and accessible for the wires.
Scott
Jerommel
Jerommel's picture
Last seen: 1 week 1 hour ago
And how about cooling an XRE via the metal ring on top?
(Yes, ancient topic about ancient LED, but…)
