CRX
(CRX)
May 11, 2017, 9:52pm
1
I am looking to put together information about the substrate and actual die sizes of the LED's that we use in our lights.
Any help with this resource would be greatly appreciated and save me some hours of time searching.
So if you know any numbers or have any failed de doming attempts and digital calipers laying around then you can help me put this table together :THUMBS-UP:
Feel free to point out any mistakes or suggestions .
So far we have:
~~~~~~LED.Name~~~~~
~Package.Size~
Diagonal.Max
Total.Height
Substrate
~Dome.Dia~
~Die.Size~mm~
~Die.mm2~
Köf3.Tests
Djozz.Tests
TA.Tests
Cree MT-G2
9.11 x 9.11
12.90
4.85
0.65
8.30
4.47r
15.70
Cree XHP70
7.00 x 7.00
9.90
4.49
0.73
7.00
3.92 x 9.92
30.57
Cree XHP70.2
7.00 x 7.00
9.90
4.34
0.56
7.00
5.61 x 5.61
31.52
Cree XHP50
5.00 x 5.00
7.07
3.58
0.73
5.00
4.67 x 4.67
21.83
Cree XHP50.2
5.00 x 5.00
7.07
3.50
0.65
5.00
4.82 x 4.82
23.22
Cree XHP35 HD
3.45 x 3.45
4.87
2.80
0.65
3.45
2.35 x 2.35
5.52
Cree XHP35 HI
3.45 x 3.45
4.87
1.00
0.65
Flat
2.43 x 2.43
5.90
Cree XM-L
5.00 x 5.00
7.07
3.02
0.73
4.34
1.97 x 1.97
3.88
Cree XM-L2
5.00 x 5.00
7.07
3.02
0.73
4.10
1.98 x 1.98
3.92
Cree XP-G
3.45 x 3.45
4.87
2.00
0.73
2.60
1.40 x 1.40
1.96
Cree XP-G2 (OLD)
3.45 x 3.45
4.87
2.36
0.83
2.60
1.29 x 1.29
1.66
Cree XP-G2 (New)
3.45 x 3.45
4.87
2.26
0.73
2.60
1.47 x 1.47
2.18
Cree XP-G3
3.45 x 3.45
4.87
2.26
0.73
2.90
1.44 x 1.44
2.06
Cree XP-L HD
3.45 x 3.45
4.87
2.68
0.58
3.42
2.03 x 2.03
4.13
Cree XP-L HI
3.45 x 3.45
4.87
1.00
0.58
Flat
1.91 x 1.91
3.67
Cree XP-L2 HD
3.45 x 3.45
4.87
2.68
0.58
3.42
1.88 x 1.88
3.55
Cree XP-C
3.45 x 3.45
4.87
2.00
0.73
2.60
0.66 x 0.66
0.44
Cree XP-E
3.45 x 3.45
4.87
2.00
0.73
2.60
0.92 x 0.92
0.85
Cree XP-E2
3.45 x 3.45
4.87
2.26
0.73
2.60
0.92 x 0.92
0.85
Cree XP-E2 Torch
3.45 x 3.45
4.87
2.26
0.65
2.60
1.41 x 1.41
2.00
Cree XR-E EZ900
9.00 x 7.00
11.40
4.40
6.80 frame
0.85 x 0.85
0.73
Cree XR-E EZ1000
9.00 x 7.00
11.40
4.40
6.80 frame
0.96 x 0.96
0.92
Lumileds Luxeon V
4.00 x 4.00
5.66
2.70
0.50
3.60
Luminus SST-40
4.95 x 4.95
7.00
2.4
0.60
4.52
1.99 x 1.99
3.99
Luminus SST-50
9.00 x 7.30
11.60
4.30
0.75
5.60
2.25 x 2.25
5.00
Luminus SST 90
11.00 x 10.00
14.87
5.40
0.90
8.00
3.0 x 3.0
9.00
Luminus SBT-70
11.00 x 10.00
14.87
1.54
0.68
8.92 frame
3.00r
7.00
Nichia 219A
3.50 x 3.50
4.95
2.00
0.40
2.90
Nichia 219B
3.50 x 3.50
4.95
2.00
0.40
2.90
1.48 x 1.48
2.20
Nichia 219C
3.50 x 3.50
4.95
2.00
0.40
2.90
1.35 x 1.35
1.82
Nichia 319AT
3.50 x 3.50
4.95
2.10
0.40
3.10
Osram Oslon Flat Black
3.85 x 3.65
5.30
0.60
0.40
Flat
1.10 x 1.10
1.05
Samsung LH351A
3.50 x 3.50
4.95
1.89
0.70
2.69
Samsung LH351B
3.50 x 3.50
4.95
1.93
0.43
3.22
Samsung LH351D
3.50 x 3.50
4.95
2.33
0.43
3.65
~~~~~~LED.Name~~~~~
~Package.Size~
Diagonal.Max
Total.Height
Substrate
~Dome.Dia~
~Die.Size~mm~
~Die.mm2~
Köf3.Tests
Djozz.Tests
TA.Tests
Awesome, this should be stickied, hint hint
CRX
(CRX)
May 11, 2017, 11:12pm
3
Maybe once it’s finished, if people help to fill it out
This will be part of my LEDs & Other Stuff thread but should also prove useful as a standalone.
leaftye
(leaftye)
May 12, 2017, 1:23am
4
I suggest adding XB-D. We don’t use it in our flashlights, but many automotive lights use them.
Can you change the colors? I seriously can’t read that! Good dataset!
MRsDNF
(MRsDNF)
May 12, 2017, 3:29am
6
Looks good CRX. Maybe include the voltage of the leds as well?
FlashMax
(FlashMax)
May 12, 2017, 11:13am
7
Hi all, I found this and seems interesting at least to me, but maybe the experts he can go further.
http://www.unistars.com.tw/download/1515_WH.pdf
Jerommel
(Jerommel)
May 12, 2017, 11:21am
8
Die size in mm² would be nice.
1.5*1.5 LED
0.6*0.75 die
luminous flux 120/110 @350mA
3.3V
5000 and 5700K
djozz
(djozz)
May 12, 2017, 11:54am
10
Nice project!
At least the XP-G die size is not correct yet, it is very close to 1.5 x 1.5 mm.
When I have time I will measure some leds for the table
Measured DIE-sizes of many well known LEDs can be found here (it's in German) and in other threads/posts of sma (he is also a member here on BLF). He even subtracts the area of the DIE where the Bond-Wires are.
Here are some interesting ones (all without dome):
Cree XR-E EZ1000: 0.92mm^2
Cree XR-E EZ900: 0.73mm^2
Cree XP-C: 0.44mm^2
Cree XML: 3.9mm^2
Cree XM-L2: 3.94mm^2
Cree MT-G2: 15.7mm^2
Cree XP-E2: 0.85mm^2
Cree XP-G2 (old 1st version 2012-2015): 1.66mm^2
Cree XP-G2 (2nd version, 2015, the ones that luminarium iculator likes so much): 2.18mm^2
Cree XP-L: 4.13mm^2
Cree XP-L HI: 3.67mm^2
Cree XHP-35 HI: 5.9mm^2
Nichia 219B: 2.2mm^2
Also some are easy to find elsewhere.
Luminus SST-50: 2.25mm x 2.25mm = 5mm^2
Luminus SST-90 & SBT-90: 3mm x3mm = 9mm^2
Luminus SBT-70: circular, 7mm^2
Luminus CBT-140: circular, 14mm^2
Some guesses from me:
Cree XHP-70: 4 x XP-L
Luminus CSM-360: 4 x 3mm x 3mm = 36mm^2 (largest power led array?)
Didnt know that sst-90 is such that big
I always thought it’s same size of mt-g2
The SST-90 ist much smaller than the MT-G2…
Agro
(Agro)
July 25, 2017, 2:47pm
14
So XP-L HI and HD have different dies?
Seems to contradict exactly the same voltage characteristic…
CRX
(CRX)
July 26, 2017, 1:27am
15
Always looking for better information…
Lothar
(Lothar)
August 22, 2017, 10:41am
16
Here are some of the SST-40 properties I could find. Still looking for die size though
Package Size: 4,95 x 4,95 mm
Diagonal Max: 7,00 mm
Total Height: 2,86 mm
Dome Diameter: 2,26 mm
Die size: ???
Source: http://www.luminus.com/products/Luminus_SST40W_Datasheet.pdf
Agro
(Agro)
August 30, 2017, 1:58pm
17
The SST-40 datasheet above actually specifies die size. It’s called “LED Emission Area” and it’s 4.0 mm.
Enderman
(Enderman)
August 30, 2017, 2:18pm
18
4mm squared .
The die size is 2mm x 2mm.
Agro
(Agro)
December 5, 2017, 9:29am
19
CRX, could you add SST-40 to the first post?
CRX
(CRX)
December 5, 2017, 9:49am
20
Yeah I’ve been meaning to update this.
