Modding? a Boruit Z001 - Problem Solved - the build is FINISHED. Beam shots are up too! 10,000 Ebay Lumens! LOL
36 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
I'm attempting a mod on a Boruit Z001. I'm not necessarily going to do a lot of photo work with it, but I will show the mod attempt. I say attempt, because I don't know how this one is going to go.
bz1a
It's already torn down. I may show some more photos of the individual pieces later.
bz1b
This 7 led light needs a new driver and it has some other issues too. It's a light that I am doing for another member and he wants to see it hit 3+ amps per led. I'm not so sure that's a good idea, but, I'll try just about anything once, pass or fail.
My problem right now is the battery holder. It's in series and I want to go parallel with it. Series can't ever hope to do the amps needed for 7 leds in parallel, so I need the holder to be parallel. It looks straight forward. I've done them before, but this one is stumping me.
bz1c
OK, the top three photos from left to right are; (Left) - the top side of the upper contact plate, with the aluminum cover on. (Center) - the top side of the upper contact plate with the aluminum cover off and (Right) - the bottom side of the upper contact plate.
You can see it's in series and one contact goes to the center and is the positive terminal with the brass button on it. The other two contacts just form the crossover path for series. The negative comes up through the three uprights that screw into the three outside holes. Positive and negative are both on top of this holder.
The bottom two photos show the lower contact plate. The one on the left is the bottom side where the switch is soldered and the one on the right shows the contacts. One contact goes to the center and feeds to one side of the switch and the other two are again the crossover for series.
What I did was to just bridge the three contacts on each plate and move all the springs to the lower plate. That makes it parallel. All the negatives on the bottom and all the positives on the top. It should work and by doing all the ohms checks with my meter, it does work. By metering it out, the negative path is connected to all three contacts once I bridge them and the switch still works to make and break the path. The positive contacts all ohm out when I bridge them and when I ohm out the upper positive and negative that mate to the driver, everything works as it should. There is no bleed off anywhere, nothing is crossed.   OK, so I put in three batteries and I get 4.1 volts when I turn the switch on, but when I turn the switch off, I get 1,2 volts WTH?
How can I get 1.2 volts when the switch is off? Well, maybe the switch is bad. OK, so I remove the switch and I still get 0.6 volts. No switch now, just a blank spot with no way to complete the circuit from the bottom, to the top of the holder and it should read absolutely nothing, but it reads .6 volts.
But, when I remove the batteries, I get no reading of stray ohms through the meter. Circuit is incomplete, so how are the batteries getting power through when the circuit is not complete? I don't get it and I don't see how it could be a low voltage. If there was a short wouldn't the voltage read 4.1 volts? Why only .6 volts without the switch and 1.2 volts with the switch.
These are circuit boards, with defines paths and layers and they are very visible, as to the circuit paths, so anyone got an idea about what's going on here?  The only thing I can figure out is that somewhere the layers are so close that the current is jumping. Something like a faulty circuit board, or one that was designed wrong. I can't see any other reason for it, but it must take current to complete, because just metering it with the ohm meter shows absolutely no bleed anywhere.
Anyone seen this type of thing before, or have any suggestions as to how to overcome it? My only options right now, would be a new holder, or make one and I don't like either of those options.
Problem Solved! I went back and removed the copper foil from the areas highlighted in Purple, on the photo below and put the springs and bridges back on. No more bleed of voltage any more. Works like a Champ!
bor1a
Now it's on to the rest of the build.
bor1b
So, I'm looking over the led shelf and the driver housing and I notice that the major OD of the driver section is smaller than the body ID at the same point. I would rather it was at least a friction fit, so that heat could be transferred to the head. It's too deep for me to measure with my calipers, so I have to sort of hit or miss judging the ID, so I started with some .015" shim. but that's too thick and .010" shim is also too thick, so I will have to go find some .006" and .004" shim. I want to wrap the section, like a sleeve, so that it's a friction fit, or as close to it as possible.
bor1c
I thought about metal tape and I even wrapped some around the driver housing, but I really don't like the idea much. This light is going to be HOT and I don't trust the adhesive. I figure it will degrade and it's not a good heat transfer medium, so I will have to find some metal stock thin enough.
bor1d
bor1e
The batterey holder is finally done and will run 3x18650 in parallel now.
bor1f
bor1g
The original leds are going to be replaced. I have a feeling that this light had to have seen some real heat somewhere. Four of the leds in the light have cloudy domes and that is usually from excessive heat. New leds on copper stars are coming though.
bor1h
The reflector was cloudy on top and even the lens had a cloudy film that I could not clean off with any normal cleaner or even alcohol. It was a thick film and it was like it had been baked on. You can't do diddly with a reflector, but I did manage to clean most of the cloudy film and even though it will have some haze from cleaning, it still looks better than it did.
bor1z
The lens came out great and I managed to get all of the baked on film off it. I used Mothers Mag & Aluminum polish on both the reflector top and the lens. It's the gentlest polish I have ever seen, as far as lack of abrasives, but it cleans most anything I have used it on so far.
mmalpo
I am waiting on Seven Qlite drivers to arrive, as well as Seven leds on stars. It may be later on in the week, or the week-end before I have everything.
I'm still waiting on parts, but I figured I need to address the contact plate that the battery holder butts up to. Actually, it was the driver plate, but now it will just be a contact plate. It's a nice design, but it's not really made for high amps and I am modding it a little, but I don't see it will ever handle 21 amps.
bor2a
The outer spring is not hefty at all. I found I could wrap it with copper braid and solder the braid to the spring.
I also put braid down in the center spring too.
bor2b
bor2c
Even with the braid, the outer metal covers fit and the springs still work as intended.
As I say, this set up is not conducive to running 21 amps. There's way too much resistance in it and the heat will be what does the damage. I am realistically looking more at 2 amps per led, for about 14 amps. That might work, for a little while anyhow...
Let's get this thing wrapped up now.
bor3b
From the pics above and below - 7 drivers in master/slave configuration. Qlite 3 amp drivers, but I took off some chips on them. Yes, you heard it, I removed chips. On 4 of the drivers I removed 2 chips and on the other three I removed three chips, to get the amp draw down under 15 amps.  Since three of the drivers have a lower output, I wired them to three of the six outer leds. So the six outer leds are now 2280mA, 1900mA, 2280mA, 1900mA, etc. You get the idea. Really, you can't even tell a difference in brightness when they are all on.
bor3c
The bottom right side driver is the master. I will hook power to it and ground to the two bare wires that ground all of the drivers thru the holes in the edges.
bor3a
7 XM-L2 leds on Noctigons, sent to me by the owner of the light. They must be 1A, because they have a blueish tint when turned on. Just a slight blue/white.
bor3d
What a mess! It's all wired up to the leds now. Talk about 10 pounds of **** in a five pound box. The aluminum sleeve will go right over and screw onto the led plate.
bor3e
Wiring up the contact plate for positive and negative.
bor3f
Testing... It works!!!
bor3g
Buttoning it all back up.
bor3h
Yes, the reflector is a mess, but with all that output, you can't see any inclusions in the beam.
bor3done
Looks stock. No one will ever know.Wink
OMG Beam Shots
bbs1a
The owner wanted to use the four mode set (4th. Star on the driver). The modes are supposed to be 5mA - 2% - 25% - 100%. Well, at 5mA it does not even turn on. I think that is all eaten up from dividing to 7 drivers. So, this is supposed to be the second level 2%, Really? 2%?
bbs1b
This is supposed to be 25%. Hell, it's as bright as a stock SRK. 25%..... Really??
bbs1c
The OMG 100% mode. Yep, it's BAH!  (Bright as Hell!) 10,000 Chinese Ebay LumensTongue Out
bbs1d
I have never seen that area lit up that bright. Notice all the trees in the background are lit up too. Remember, with the small cups in this reflector, it's just about all flood. Well, it sure as heck is a flood of light. I'm getting sunburned standing behind the derned thing!
bbs1e
Still looking good, but it really does not throw well. Look at all the light out on the ground and surrounding area.
bbs1f
Yep, it's a flooder. By 120 yards out, it's done. It can barely light up the back of the pond... Of course, it's lighting up the WHOLE pond and the trees and the grass and it's drying up the earth right in front of it. By this time, it's very hot and getting dim.
OK, with my Panasonic 18650s, the light dims in about a minute. With my 20R 18650s, the light dims in about 3 minutes. I can't read the amps properly. The only spot to take the reading is across the switch tabs and I just can't get a good enough contact without slipping, but I did read over 12 amps as it was bouncing around. I would expect around 13-14 amps on start up, but it drops off real fast.
That's all Folks!.....
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 01/18/2014 - 02:21
Old-Lumens
Reserved
wight
Last seen: 2 weeks 2 days ago
High resistance short on the bottom PCB (switchplate PCB)? I’ve circle two places below where solder spills across onto a nearby trace – maybe the mask was damaged slightly in one of those areas?
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
kwarwick
Last seen: 4 hours 45 min ago
Wow, 7 XM-Ls in parallel @ 3A is ambitious I’d say! 21A is going to be very hard to obtain from any driver I’m aware of, are you thinking of doing direct drive? Otherwise wiring the LEDs in series and keeping the batteries in series with a good boost driver might be a better way to go. While an expensive driver, HBFlex could probably do it… it has a maximum 7A input which with 3 good quality 18650 batteries (IMR or NCR18650PD) should be achievable.
wight
kwarwick wrote:
Wow, 7 XM-Ls in parallel @ 3A is ambitious I'd say! 21A is going to be very hard to obtain from any driver I'm aware of, are you thinking of doing direct drive? Otherwise wiring the LEDs in series and keeping the batteries in series with a good boost driver might be a better way to go. While an expensive driver, HBFlex could probably do it... it has a maximum 7A input which with 3 good quality 18650 batteries (IMR or NCR18650PD) should be achievable.
Yeah, I thought about that too... as OL says, 3A is what the customer asked for, not what is practical or usable. Boost is a good suggestion IMO. Assuming a 3.6v vF, that's a wattage of 75.6. TaskLED docs indicate maybe 90%-95% efficiency. You're looking at pulling around 80-84W from the batteries... The highest current will be at the bottom end of the discharge (say 2.8v per cell). At that point you're looking at 10A per cell. IMR's or Panasonic PD's / PF's should be able to do that... so electrically it's doable in series 0:). In parallel, less so: that's at least 7A per cell and still assuming a 3.6v vF at 3 amps... with an AMC7135 based driver it might maintain 3A per emitter for 2 minutes?
Old-Lumens
The solder was just from me wiping all the solder off the contacts, to show everything more clearly.
Not one driver, 7 drivers. Seven NANJG drivers. Yes, there is room.
3 Parallel of the highest rated unprotected 18650s ought to do the amps... for about 30 seconds.Laughing
moderator007
moderator007's picture
Last seen: 12 hours 13 min ago
wight wrote:
Yeah, I thought about that too… as OL says, 3A is what the customer asked for, not what is practical or usable. Boost is a good suggestion IMO. Assuming a 3.6v vF, that’s a wattage of 75.6. TaskLED docs indicate maybe 90%-95% efficiency. You’re looking at pulling around 80-84W from the batteries… The highest current will be at the bottom end of the discharge (say 2.8v per cell). At that point you’re looking at 10A per cell. IMR’s or Panasonic PD’s / PF’s should be able to do that… so electrically it’s doable in series 0:). In parallel, less so: that’s at least 7A per cell and still assuming a 3.6v vF at 3 amps… with an AMC7135 based driver it might maintain 3A per emitter for 2 minutes?
That’s what I thought when I first read OL’s OP, taskled driver. Maybe series might be the easier and more achievable with 3 amps to each led. The taskled drivers are in a class by themselves, and the price reflects that I guess. I would be for using the HBflex and batteries in series, but I have learned to never under estimate the modding ability of OL. :bigsmile:
wight
I understand. So the 0.6v you measured was between the aluminum and brass contacts on the top of the carrier, right? My money is still on a short on the battery side of the bottom board. You didn’t show how you bridged the contacts, possibly a really high resistance short from that? If you want something to try you could re-assemble the carrier with the two contacts marked below aligned with each other. Cleanup the wiped solder, put springs back on, put the switch back on, and see what you get – you only need to install an 18650 between the marked contacts of course.
If you are checking for a short in the low ohms range on your meter (like 200), switch to a high range (20M or something).
Old-Lumens
rgbu6
The spots in Yellow, were where I tested voltage.
The spots in purple were where I made the bridges, with copper sheet.
I tested each battery one at a time and the two marked in Red showed voltage leakage, but the third one showed correctly, with no voltage with the switch off, so it's got to be something about the two.
wight
OL: are you saying you did that single-cell testing on your initial assembly with the bridges (before tearing it down for pics), or have you re-assembled the carrier at this point?
Old-Lumens
I did single cell testing originally, with the bridges. I only tore it down to be able to take better photos.
edeekeos
edeekeos's picture
Last seen: 10 months 4 weeks ago
Wait, 7 NANJGs.. WOAH! Shocked
This is gonna be interesting.
MRsDNF
MRsDNF's picture
Last seen: 21 hours 15 min ago
8)
Old-Lumens
The OP is updated. The battery holder problem is solved.
Ouchyfoot
Ouchyfoot's picture
Last seen: 3 weeks 1 day ago
Well. What was it?
Old-Lumens
Ouchyfoot wrote:
Well. What was it?
I do not know, now it works. As I said, I removed the copper film below the areas I marked. All I can think of, if that the current was jumping through the layer somehow, but that's hard to believe. Once I removed the copper under the top coat and put everything back, it works, but I can't give a definite reason for the change. All I did was make sure that there was nothing in the path of the jumpers and nothing close to the spring. That area around the one spring was cleared away, because that pad is smaller than the other two. It was a positive pad and the others were negative. The spring was larger than the pad, but the area around it was coated. It shouldn't have mattered.
bor1a
wight
Glad you’re back in business OL. The resist layer isn’t perfect – I sometimes stab a multimeter probe straight through it to get a reading.
Old-Lumens
Worked on the contact plate today. Photos in the OP. Won't have parts till late in the week, so the week-end will be when I finish the build.
Old-Lumens
Finished and Beam shots are up. See the OP.
unknown00101
Looks like an amazing personal defense weapon. :bigsmile:
Wonder how crazy strobe would look!
edeekeos
edeekeos's picture
LMAO I seriously can’t stop laughing, that is just INSANE!!! Wow, would love to see that in person. Very good work, really hope the owner is happy, I know I would be!
Chazzy
Chazzy's picture
Last seen: 3 months 2 days ago
I’m already blinded from the beamshots. 8)
That is one mean light!
"Whoa that's a bright light!" ... Yea I guess.
DayLighter
DayLighter's picture
Last seen: 2 years 10 months ago
wow.. just wow, your creations is always bring smile to my face Big Smile
The only way to do a great work is to love what you do.
Ricflair
Ricflair's picture
Last seen: 1 year 3 months ago
OL, that is insanity! :Sp I love it. Looks like it could double as a BBQ grill. Might want to wear some sunglass while testing, just to be on the safe side.
RicFlair is on the air with blonde hair & pink underwear!! Whaoooooo!
Ledsmoke
Ledsmoke's picture
Last seen: 11 months 3 weeks ago
Well done (insert roaring audience sound) I love it!
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
blueb8llz
Last seen: 1 day 13 hours ago
geez, that is one bright arse light!
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
Who needs a tanning salon?
Scott
wight
Heheh, one click mobile tanning.
MRsDNF
MRsDNF's picture
Don’t tell me why, I somehow missed the drivers. What an amazing array. Orsm effort. I assume you used Mothers on the reflectors reflective surface as well as non reflective surface. This cleaned the surfaces up without damage and if so have you used it on other reflectors?
TexasLumens
TexasLumens's picture
I thought I seen a glow to the east!! WOW! That would be the ideal search & rescue light... with a flood like that you should find about anything / anyone!!  Nice OL!  The driver image is a keeper! That needs to be a poster on every modders wall!!
Thanks for sharing! Dan.
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
ruffles
ruffles's picture
Last seen: 23 hours 41 min ago
Sweet build! If anyone asks about the cause of global warming, I promise I won’t let your secret slip.
