What did you mod today?
5466 posts / 0 new
CRX
CRX's picture
Last seen: 34 min 23 sec ago
Wee cousin’s 21st today so I made a brass tritium key fob as part of a present. Going to the party later, damn I feel old LOL
vwpieces
vwpieces's picture
Last seen: 1 hour 14 min ago
Trit tube looks great CRX. Nicely done, spacing looks perfect. Really like the inlay glow spinner too. Hope he has it for the 20+yr trit life.
I was messing with a Convoy BD06 today. added a couple 380mA 7135, bypassed the springs and swapped emitter from 1A tint to a 20mm Noctigon XM-L2 T6 4C.
The T6 came in a Red s2+ I grabbed at a cheaper than host price. Kinda just bought it for the emitter and maybe another project someday.
BD06 is a nice 26650 light and has the 12 mode Biscotti. Has rings in wall shot but not bad for something to use out side. Measures 3.65A at the tail on my DMM and 4.15V KeepPower black. Not sure why its slightly higher than the total of the 7135’s but I’ll take it.
DB Custom
DB Custom's picture
Last seen: 3 hours 40 min ago
I really like how the charging circuit has indicator green/red that show in the main reflector, love that aspect of this and have been wanting to get one for a while now. Just always seem to be spending dough on other things.
Nice work, nice shots of the driver too. I bumped power output on one for a friend so I got a chance to see how this one works and it made me want one! Big Smile
Dale
DB Custom
DB Custom's picture
I think it has been said before that 350mAh 7135 regulation chips will many times come in around 360 or 365, it’s the higher than that select ones that they call 380mAh. So you are more likely to get more from the 350mAh labeled chips than the average 380, if that makes any sense. That would explain why you’re seeing 3.65A instead of 3.56A. Dunno…
Dale
vwpieces
vwpieces's picture
Thanks DB on the 7135 info. For wires I went 22 on the driver spring and 20 AWG on all the others. Plenty of room in there.
There was a deal on the BD06 last week for $19. Worth every penny. I like the build of it for the most part. Plastic spacer under the driver retaining ring could use some redesign to omit. But the 105 minimalist driver that still charges is nice and still using the 1288 as a side SW was a surprise. Side SW push is stout with the little extra spring under the button. Don’t see it getting turned on by accident even if in a tool bag. There are some rings in the spill but a pretty nice spot from the XM. This thing could certainly take a beating for years. With the extra 7135’s it gets warm in hand, I don’t think thermals (timer or sensor) are needed. . I have grown fond of the 26650 and tube size in hand.
lumenzilla
lumenzilla's picture
Last seen: 10 hours 20 min ago
CRX wrote:
Updated the UltraFire UF-10 with a Nichia 319ATE SM655 D440 6500K emitter for a nice hexagonal spot.
MTN FET driver, 16mm Noctigon, reverse clicky, 16500 cell.
Do you mind telling us how do you disassemble the board?
I also have this torch and would like to do some mods but the board seems to be glued.
www.lumenzilla.com
DoNkEyConN
DoNkEyConN's picture
Last seen: 5 hours 10 min ago
wondering if anyone can help, I’ve just done a spring bypass on the driver and tail switch springs on my BLF A6. I now only have high mode, it wont switch to any other modes. Does anyone have any insight as to why this might be??
Thanks
DoNkEyConN
djozz
djozz's picture
Last seen: 3 min 9 sec ago
Thanks
DoNkEyConN
That usually happens when the led-minus connection touches the body somewhere, thus bypassing the driver entirely and the led is directly connected to the battery. It can happen somewhere on the driver board or in the wire (insulation damaged and exposed wires touching the body), or even on the ledboard.
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
DoNkEyConN
djozz wrote:
Thanks
DoNkEyConN
thanks for the info Djozz
I’ve checked all over, resoldered + and – to the led star, checked the wires and nothing sticks out as abnormal. mkght have to try a diffent driver see if i damged the last one somehow.
vwpieces
vwpieces's picture
Test parts out of light. Just dont let the LED lit for more than a second if it is really gone DD.
My guess is the LED MCPCB is twisting as you tighten the head. With the MCPCB twisting it is pinching a wire in the through hole. Sometimes silicone heals the cuts so it is hard to find without bending the wire to open the cut. BLF, Noctigon and similar boards are nice but the edges are sharp.
To help stop the twisting I lube the Oring on the lens and push on the lens and reflector with a thumb as I tighten the bezel.
Also make sure the wire insulation wraps up and over the MCPCB to the solder pad. As I solder the wire I push the Iron on the wire to flatten the connection where the space is limited. Solder blob on the pads may be touching reflector as you tighten it.
And not to be insulting but you do have the plastic spacer around the LED to reflector? I have lost them during assembly or put a light together and then saw the spacer sitting on the bench.
DoNkEyConN
Thanks, VWpieces,
all good ideas, have checked everything you mentioned. I did find the MCPCB was twisting as I tightened but couldn’t find any cuts in the silicon wire. when I had the bezel off I placed the reflector on with the spacer and the solder wasn’t touching but resoldered and flattened out as you mentioned. Put it back together but still, high mode only Crying
No offence taken at all mate, im fairly new to this so any suggestions are appreciated.
ive got some drivers on the way so will replace and test when they arrive.
18sixfifty
18sixfifty's picture
Last seen: 1 month 4 days ago
Thanks, VWpieces,
My first guess is that you fried the FET with heat from the solder while doing the spring mod. Whenever working on any of these drivers try not to let the driver get too hot for too long. If your solder doesn’t stick the first time let it cool down for a bit before trying again.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
CRX
CRX's picture
Thanks vw Beer
lumenzilla wrote:
Do you mind telling us how do you disassemble the board? I also have this torch and would like to do some mods but the board seems to be glued.
The original mod was done a while ago so I can’t remember for sure but the LED MCPCB is probably glued with some cheap compound that should come off fairly easily by twisting slightly with long nose pliars in the wire holes.
There might be a plastic retainer ring in there too.
KyleGates
Sunwayman P25C converted to triple xp-g2 s4 2b on a noctigon. Carclo 10507 and stock driver.
DoNkEyConN
thanks for the suggestion, ill keep that in mind next time.
DB Custom
DB Custom's picture
Direct drive only is usually a short to the negative lead, bypassing the driver and going direct drive. This is typically because the reflector is touching the negative lead or the negative lead is shorting on the MCPCB. I like to use Arctic Alumina Thermal Adhesive to glue the MCPCB in place so it can’t twist. If you’ll check the negative lead path, it could be shorting on the side of the pill at the driver, or pinched/cut at the emitter shelf or the edge of the MCPCB. Given your lights symptoms I’d be tracing the negative lead. Fix that and if it still acts up, well then it’s time to dig deeper. Wink
Dale
DoNkEyConN
Thanks DB Custom,
I have tested the light with the reflector and bezel off, the still high mode only, so don’t think its shorting on the reflector/bezel
maybe I should try with a new Negative wire, don’t think I have any spare right now though.
lumenzilla
CRX wrote:
The original mod was done a while ago so I can’t remember for sure but the LED MCPCB is probably glued with some cheap compound that should come off fairly easily by twisting slightly with long nose pliars in the wire holes. There might be a plastic retainer ring in there too.
Thanks CRX, will try! Beer
www.lumenzilla.com
g_damian
Last seen: 55 min 16 sec ago
I have built Jaxman E2L with Nichia 219C sm503-D240-L1-R9050 and LD-B4 9Amp 17mm constant current LED flashlight driver. The biggest challenge was to solder everything on MCPCB, especially a small transistor. Also I had to sand the MCPCB to get it to fit in the light. After first try I checked MCPCB with multimeter and there was a short, so I sanded it “upwards” (so top black layer is folded towards leds) and it helped. The hole in the shelf was also drilled to fit more wires. Everything togheter produces a beautiful tint. According to this review it should make around 2400 lumens at 9 amps and 2000 lumens at 7 amps. At 7A (2000 lumens) stepdown occurs after 70 seconds in room temperature. It’s a bit dimmer than D4, but at least output can be sustained for over a minute and even longer outside in lower ambient temperature. There are beam shots and skin (?) shots in the album.
vwpieces
vwpieces's picture
Very cool build g_damian,
did you do any thermal sinking to driver?
and good find on the MCPCB conductive layer and sanding it back.
I got some LED4P stuff for the single Luxeon V on 9A in S2+ build
g_damian
Thank you Smile
I’ve used “B” version of the driver, so the mosfet is on MCPCB, not on the driver board. According to the data sheet, additional thermal sinking in that case is not necessary.
I’m also going to build Luxeon in S2+, also with thermal enhancement kit.
vwpieces wrote:
Very cool build g_damian, did you do any thermal sinking to driver? and good find on the MCPCB conductive layer and sanding it back. I got some LED4P stuff for the single Luxeon V on 9A in S2+ build
vwpieces
vwpieces's picture
g_damian wrote:
Thank you Smile
OK, I did get the “A” and thermal kit too. Selected the NTC for the driver, luckily that tiny thing is already on the Luxeon V MCPCB. 3 colors of tails too. Need to check the brightmess, had no idea what to select when ordering.
g_damian
vwpieces wrote:
g_damian wrote:
Thank you Smile
I ordered 9 amps version, too. Check in this review, 9 amps is max and makes 2400 lm:
EDIT: if you meant tailcap current, here they are:
Quote:
  • GREEN – 120uA
  • RED – 600uA
  • BLUE – 280uA
  • ORANGE – 600uA
  • WHITE – 240uA
  • WARM WHITE/GOLD – 280uA
  • PURPLE/PINK – 400uA
  • ICE BLUE/AQUA – 400uA
vwpieces
vwpieces's picture
g_damian wrote:
vwpieces wrote:
g_damian wrote:
Thank you Smile
Quote:
  • GREEN – 120uA
  • RED – 600uA
  • BLUE – 280uA
  • ORANGE – 600uA
  • WHITE – 240uA
I did mean tail caps. I got Orange, blue and gold. I went 150uA on all. I wanted kinda dim but I messed up.
I have the orange ILC-0 in my Luxeon V S2+ LD-4A 9A w/ thermal kit. Orange at 150uA is just a little too dim. Thanks for the color/current list. It will help dial them all in.
After seeing yours I went to building mine tonight. I like the light but I think the external NTC is a bit too low at highest setting but turned off the light gets too hot. My ext ntc is on the Luxeon V MCPCB and I soldered the MCPCB directly to the brass pill. I think I am going to take it apart again to put some MX4 thermal paste on the pill threads to body too. Overall it was a pretty neat build with all his parts.
Anyway, I will make another post with pics and more details of my 9A single emitter Cell Sucker.
vwpieces
vwpieces's picture
Got the resistor sorted in the tail LEDs. After 5 tries, I was getting good at it. Ended with a 7.5 kΩ. I like it. will be hardly visible in daylight look good at night but not be annoying on the nightstand. Real hard to get pics to make it look as I see it.
Light is done,
Grey S2+, SMO, AR glass, Luxeon V 4000K 70CRI LED On L4P 4040 16mm DTP MCPCB soldered directly to brass pill, 20AWG on spings and LED. LED4P LD-A4 9Amp driver and LD-A4 Thermal Enhancement Kit squashed in there. Orange ILC-0 lighted tail SW with 7.5 kΩ resistor. Pulls initial 8.4A on my DMM with fresh HG2 from a Single Emitter.
OP reflector currently installed.
Best I can do to represent the tail LED indoors or night.
Beam shot with SMO, if the Pic hurts your eyes you see it in person.
Now has OP reflector installed.
djozz
djozz's picture
^ That is a very nice build and at least on the picture it looks like a beauty of a beam!
I’m considering (almost) the same build (with a BLF-A6 driver and selfmade tail-led ring), how do you like the light as it is now?
link to djozz tests
g_damian
vwpieces, good work, nice light, hope that mine build will be as good as yours Smile (still waiting for s2+ host).
vwpieces
vwpieces's picture
djozz wrote:
^ That is a very nice build and at least on the picture it looks like a beauty of a beam! I’m considering (almost) the same build (with a BLF-A6 driver and selfmade tail-led ring), how do you like the light as it is now?
I like the light, Killer LED. it Can compete with a triple. I wish the driver external ntc had a little higher temp range. Shuts off in short time on DD. But when its disabled in UI the light Will get too hot. I think the ntc on the emitter MCPCB is too close to the heat source. Even a large hefty light I think will shut off quick with the ntc on the MCPCB, before the body can soak the heat. The LED can take a beating and survive, I tried to kill it with ext ntc off but the driver on board thermal shuts it down completely. Big Smile I have Fet+1 Nichia triples on Bistro that have a better thermal regulation. I haven’t played in the UI too much on CC, I mean it’s a 9A driver and it’s pulling 8.4A DD. I can also lower the variable CC down to 7A and still keep DD. I gotta play more and maybe I will get it dialed in better.
But, in the back of my mind, I am thinking Fet+1 and Cresendo running that Luxeon V in something other than a Convoy S. Maybe a different light build with the Luxeon too. C8? Nothing built here that I can find except Dales D4 using the L.V. I am curious if it can throw, and considering a C8 first. No idea what it would look like sliced if needed in a C8.
vwpieces
vwpieces's picture
You building a single also?
I wish I would be there to see your first reaction on DD.
I bet it kicks the 9A triple’s butt.
Thanks! I didn’t clean parts up as well as I should have. Glad I didn’t install the driver spring till last. Had to file the solder off the driver spring side from the wire through holes so it didn’t short the retaining ring. I also stuck the wires through the holes with some poking out spring side, fluxed and soldered from the spring side. Cut down excess and filed it flat. Those wire holes are really close to the ring on the S2+, be careful.
I have the driver ring tight too. I trimmed the pads to fit the aluminum perfectly and you can still see the blue oozing into the wire holes. Spacer is a good fit.
djozz
djozz's picture
At least I tried a cold Toluene dedome (did not post about it), and although the dome came off quite ok in half an hour, also quite some phosfor came with it. The dedomed led is usable because straight on top of the die there was enough phosfor leftover, but because of the flip-chip design I do not expect much throw improvement (see EasyB’s experiments/lecture on that).
My best use of the LuxeonV sofar is in a Thorfire VG10 with FET+1 driver, over 2000lm still at 30 seconds, minutes before really overheating and a very pretty beam (the quad LuxeonV D4 was also my build btw, crazy at turbo but very versatile at lower levels).
link to djozz tests
