What did you mod today?
8693 posts / 0 new
djozz
djozz's picture
Last seen: 7 sec ago
CRX wrote:
Nice, so what’s the max these fella’s are happy at?
About 2A is the sweetspot for good output, past 3A the output goes down.
CRX
CRX's picture
Last seen: 3 hours 30 min ago
Thanks, might have to try them.
clemence
clemence's picture
Last seen: 4 hours 58 min ago
djozz wrote:
Immaculate and beautiful work again CRX, not completely sure what happened in every picture but those are some nice flashlights!
My mod today is not that lot of work but it was a special led in a special light.
I had this Olight M10 Maverick (EDC-size with 16340 battery) in my to-mod box for a year now, from a GB clearance sale, and I was looking for a host to check out one of the Nichia E21A 6500K R9080 leds that I bought from Clemence. The about 1A constant that this light is driven at on max, should be great for this led on my non-DTP 119-board. The tricky part was the reflowing, it took a while to get the led centered and there is a bit of flux-residu on the side of the phosfor, but on the bright side the board fitted snugly in the flashlight so that centering did not depend on the center piece. I still used a XP-centerpiece (not doing much centering because the hole is too large), that I sanded really thin, to seat the reflecor at the correct focus and insulate it from the solder pads.
Not perfectly centered.
But the beam looks really good: if you look for it a slight bit of brown in the center of the hotspot, not too much tint shift over the beam and in this host this led is quite throwy even.
The output is pretty good: a steady 265 lumen (the stock XM-L2 gives 350lm according to the manual).
The trees are at 25 meter. Don’t mind the tint in this picture, it is much nicer than it seems here.
So the mod was very succesful, and I hope that the dirty phosfor layer holds up over time.
But what about the goal of this mod, what does 6500K R9080 look like?: in short, amazingly good! On a white wall you see nothing special: a well balanced cold white tint, a well-chosen Cree led could look like that. But once you start illuminating things this is completely different: great colour contrast, red is very red and blue is very blue etc., and everything shows the correct colour including natural stuff like food, wood and skin. I checked with a Convoy S9 with 6500K XM-L2, the E21A sw65 R9080 blows it completely away in light quality. If you like cold white tints (I don’t, really Silly ) and care about accurate colours, these leds are little gems!
Just like you, this 6500K E21A have made me like CW again. Nice host Jos.
Note: clean your LED in a hot IPA bath and brush it with smooth toothbrush, it will look like new again.
- Clemence
virencelights
virencelights's picture
Last seen: 20 hours 15 min ago
some mention CW give you eye strain when using CW at night, so even if these are HCRI at 9080 could this still be the case, or would it be easier on the eyes with the colour rendition, or something else?.
thanks.
Virence ArmyTek Viking Pro Quadtrix 9080 E21A 6500k, Virence Skilhunt H04 RC Quadtrix 9080 E21A 5700k, Virence Jetbeam AAA 9080 E21A 5700k, Virence Jetbeam AAA Nichia HCRI Red Led.
https://www.instagram.com/p/B5szQO9jM2z/?fbclid=IwAR2iVysO9q_niBevQv35pH...
clemence
clemence's picture
HCRI9080 wrote:
some mention CW give you eye strain when using CW at night, so even if these are HCRI at 9080 could this still be the case, or would it be easier on the eyes with the colour rendition, or something else?. thanks.
No, no matter how high the CRI, cool white CCT will always strain most normal eyes more than warm white CCT. Many researches proved human eyes are more sensitive to blue and green spectrum. This will make your pupils smaller and less sensitive to the dark surroundings (tunnel effect). Warm lighting with less blue green spectrum perceived as being less intense by the eyes, so the pupils will open wider. This is why candle lit dinner is so romantic. Your partner face will looks more inviting with reddish tone and larger pupils and redder lips. Aroused, human will show slightly swollen red lips. This also why (the origin) women wear lipstick.
Now imagine how a tactical combat flashlight with high CRI and warm white CCT perceived by the enemies. LOL
- Clemence
zak.wilson
Last seen: 7 hours 40 min ago
I only have two cool-white high-CRI emitters, and they’re 5700K (a 219B and a 144A). I do notice less eye strain with these than with other cool white emitters, but 5700K is a little less cool than than most, so that might help too.
Ceilingbounce – flashlight testing and runtime graphs for Android
KawiBoy1428
KawiBoy1428's picture
Last seen: 8 min 10 sec ago
- Clemence
I wonder how the enemy would perceive this CCT? Think his lips would get redder? I bet his eyes would get Bigger and his back door would slam shut! Wink
KB1428 “Live Life WOT
cera@1967
Last seen: 3 hours 20 min ago
 Djozz , it is the first time when I saw a " downgraded " light , made by you !!! From 350 Lm to 265 Lm , almost 30%...There is a new trend I don't know about ? <img src= " />
I was joking , I'm sure that you had your reason , maybe the tint or the CRI..! . On my Maverick M10 , I'd just dedomed the XM-L2 , in order to make it a little more throwy , thinking that the SMO reflector will help , added a bit of quality thermal paste , a small but strong magnet on the clip ( with shrinking tube ) . May I call that an " upgrade" ..? Hardly.., but , except the tint shift ( just a little bit on the yellow side) it seems that worked ! The beam is narrower and more brighter , overall it looks like is better than before ( my wife has an M10 also , and now she is trying to make a trade with mine...   <img src= " />  ) Should I go for it ?...tongue-out
Adrian
djozz
djozz's picture
cera@1967 wrote:
 Djozz , it is the first time when I saw a “ downgraded “ light , made by you !!! From 350 Lm to 265 Lm , almost 30%…There is a new trend I don’t know about ? <img src= " />
I was joking , I’m sure that you had your reason , maybe the tint or the CRI..! . On my Maverick M10 , I’d just dedomed the XM-L2 , in order to make it a little more throwy , thinking that the SMO reflector will help , added a bit of quality thermal paste , a small but strong magnet on the clip ( with shrinking tube ) . May I call that an “ upgrade” ..? Hardly.., but , except the tint shift ( just a little bit on the yellow side) it seems that worked ! The beam is narrower and more brighter , overall it looks like is better than before ( my wife has an M10 also , and now she is trying to make a trade with mine…   <img src= " />  ) Should I go for it ?…tongue-out
It is not the first light that I downgraded in favor of CRI but it always hurts to loose lumens! The throw has increased quite some btw.
I downgraded the M10 a bit further today Innocent , made it a lot less ‘tactical’ : foybezeledtm the front end and swapped the long forward switch for a small Omten 1288 reverse clicky, and a flatter switch cover.
cera@1967
 The blue boot is looking very " manly" ..., may I have one in pink ... (for my wife... )...? <img src= " />
Subtle minor changes , but great effect..! <img src= " /> ! <img src= " />
Adrian
Yokiamy
Yokiamy's picture
Last seen: 6 min 24 sec ago
Wow, nice Foybezel™ Jos!
I will try to make my first foybezel as soon as the SS C8 bezel arrives
skinny_tie
skinny_tie's picture
Last seen: 1 hour 29 min ago
Nothing fancy, but today I completed my first mods.
I put Texas Avenger Bistro OTSM drivers into a Convoy L2 (XM-L2 T6 4C) and a silver Convoy C8 (XP-L HI U6 4B), plus Convoy lighted tail switches with spring bypasses.
I used 18 AWG wire for everything and it was a pain to work with. I’m wondering whether it’s overkill.
It wasn’t all good. I put a BLF X5/X6 driver in my Convoy M2 and I think I fried the emitter, and I overheated the switch in my BLF A6 when I fixed its broken leg so its a bit sensitive.
Replacement parts have been ordered and I’m looking forward to my next mod!
djozz
djozz's picture
You are well underway modding skinny_tie, leaving a tailing of fried parts Big Smile
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 2 hours 29 min ago
Changed batteries in an 9 Year old Batterypack. Its an Ferm Premium Power 18V Batterie with 2P5S 18650.
I used Samsung 30q. It doubled the Capacity. Old Cells had former 1500mAh, I measured around 1000mAh with a High Resistance between 200 and 300 Ohms.
Edit: Thats my Post #500! Party
Yokiamy
Yokiamy's picture
Nice work Wieselflink, happen to have any pictures?
Wieselflinkpro
Yes!
Old Batteries with 1500mAh each:
New with Samsung 30Q:
Not jet changed, another old battery-back with Sony 18650VT and 1100mAh each:
More Pictures: http://www.taschenlampen-forum.de/media/albums/akkupack-ferm-premium-pow...
Yokiamy
Yokiamy's picture
Thank Wieselflink! Very nice to see, might have to do the same sometime for my cordless drill!
Wieselflinkpro
I got the battery-connections off with only little damage. Than pre-tinned the batteries and after cooling the batteries I soldered the connections to the new batteries.
djozz
djozz's picture
Did my first Syniosbuild today. I build one in a small 14500 zoomie and unfortunately it underperformed. In this same zoomie I got a dedomed XP-G2 S3 3D perform up to 54kcd, so I hoped for at least 80kcd with the Synios led. Instead it was just 48kcd, and an uglier hotspot. Of course I can think of a few reasons for the underperformance, of which the heat barrier from ledboard to pill is the main one, keeping the ledboard temperature too high (the board was glued onto the edge of the hollow pill with Arctic Alumina Adhesive, making it electrically insulated from the pill). But I had to re-heat the board an extra time for creating a solder connection between ledboard-core and minus-pad (could have thought of that while reflowing the led Sad ), that extra cycle at 210 degC on the heatblock could have affected the led performance as well.
Oh well, I made pictures so I may as well report the mod:
-flattended a 16mm Noctigon well on the underside and slightly sanded the side as well to avoid anything sticking out that could short the board to the pill when later glued in.
-reflowed the Synios led on the Noctigon
-scratched an opening to the core of the board next to the minuspad and reheated the board once more to create a connection from core to minuspad with a tiny bit of wire.
-build up a simple 6×7135 MCU-less driver by stacking chips.
-soldered two pieces of copper wires around the edge of the driver board to create a press-fit connection between driver and pill.
-soldered two tiny ledwires to the ledboard and glued the ledboard into the hollow pill while my led-tester (at 10mA) was connected to led+ and pill. This way an unwanted short from ledboard to pill makes the led light up, so I could re-position the board while the glue was not hardened still.
-made a spring bypass at the driver side.
-assembled the light and tested the current. It was a nice 2A precise (should be 2.1A but those 7135 chips are not that precise).
-tested throw at 7 meter with the Mobilux luxmeter: 48kcd Sad
(for fun: stereo!)
The_Driver
The_Driver's picture
Last seen: 18 hours 2 min ago
Very nice, I especially like the last picture comparing the two LEDs.
The problem might actually be the precision of the aspheric lens. The led could be too small for it. A pre-collimator could help.
A good thing to mention might be that you are using the 0.5mm^2 Synios, there is also a smaller one.
luminarium iaculator
luminarium iaculator's picture
Last seen: 17 hours 8 min ago
Synios looks brighter so I really don’t get that 63 kcd readings. Yes of course I believe you Djozz Thumbs Up
Lenses have ultra clear projection. I don’t like size of it but it looks very nice and unusual. Well done Djozz Beer
CRX
CRX's picture
Good experimentation Thumbs Up
SpAwN
SpAwN's picture
gchart wrote:
SpAwN wrote:
Did a lighted Convoy black button mod today, some how I missed this topic, so here it goes, more information here:
http://budgetlightforum.com/comment/1277893#comment-1277893
!https://i.imgur.com/BdJr9dI.jpg!
That’s pretty sweet. I imagine it would look amazing if someone could make (3d print?) the center piece of the switch out of a clear material.
I love lit tailswitches and the metal switches, but have never been satisfied with just using the clear gasket on the metal switches. It just doesn’t let enough light through.
gchart, little late reaction but I was thinking about that too, since I don’t have a 3D printer I didn’t do anything with the idea till yesterday.
I needed a 3D print for my soldering microscope and I had to make a 3D drawing for it and found a shop in my area who could print for me, meanwhile I also make 3D model for the button, shop didn’t have clear filament so asked him to print in any color to test.
I don’t know if this is category mods, but here it goes.
EDIT added the file to: https://www.thingiverse.com/thing:2799606
I picked up today and print was not really successful the thin part where the gasket comes was a mess, it is a small object after all.
I did trim the print and it works in my S2+
The guy who printed for me asked if I could add some pillars to it so it makes the print sturdy while printing, thus I added some side supports for inner side, if it is printed I will cut those supports.
Since it is only 12 minutes print, he will wait till he has something else to print and print this afterwards.
Here is the new model:
If it goes like this, I might buy a 3D printer….
XXX-Man
XXX-Man's picture
Last seen: 11 hours 56 min ago
He should have used “add supports” in slicer to make it print right.
Can you share with me both files so I can print and test it?
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
SpAwN
SpAwN's picture
Sure XXX-Man, I don’t want to upload it somewhere since it is not fully tested, but I will PM you right now so we can exchange email addresses.
XXX-Man
XXX-Man's picture
You have PM Smile
I will print it as soon as I get files Smile
My reviews:
SpAwN
SpAwN's picture
You have got mail with files Wink
XXX-Man
XXX-Man's picture
Here it is Smile
It fits good and on first try.
There is some work to remove supports but it’s not hard.
Settings I used:
Resolution: 0.1
Initial layer: 0.2
Infil: 20% (you should use more IMHO)
Supports: yes
Print time: about 5 minutes
You should post it on thingverse Smile
Sorry for some weird color on pictures, my phone doesn’t like white LED strips Smile
My reviews:
djozz
djozz's picture
That is fast XXX-Man! Good work guys, that looks marvelous!
SpAwN
SpAwN's picture
Nice, thanks for testing Smile did you print v2 with supports?
I will post on thingverse for sure, I will wait till I get mine transparent printed, so I can add some photo’s.
Meanwhile if anyone with 3D printer want the file let me know please.
Thanks djozz Smile now I am almost sure to get a 3D printer in month or 2…
