What did you mod today?
9496 posts / 0 new
ZozzV6
ZozzV6's picture
Last seen: 3 weeks 4 hours ago
TIP cover
STLSTLSTLSTL
I hope the link works.
KawiBoy1428
KawiBoy1428's picture
Last seen: 6 hours 16 min ago
MRsDNF wrote:
Did you use some sort of formula with the knurling or just go for it?
No going for it didn’t work, those single post swivel head knurling tools wouldn’t get it for me either, here is a vid I found a couple years ago. I have the same set-up and tool post. It still took a couple tries before all was good! Facepalm
https://youtu.be/nsCiVpi6qAk
KB1428 “Live Life WOT
XXX-Man
XXX-Man's picture
Last seen: 1 day 18 hours ago
ZozzV6 wrote:
TIP cover
STLSTLSTLSTL
Great, thank you Smile
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
kikkoman
kikkoman's picture
18650 extension tube for that dreadful Astrolux E01. It’s a E02 now. Almost.
pic
Cutting square threads isn’t that much of a nightmare actually.
pic
Since I wanted to make this light usable, I cooked up an an attiny85 driver with [1×7135]+[2×7135]+[1×7136@2.5A]***
(*** instead of a FET since I wanted to have _some _regulation on turbo; plus no room for stacking 7135s)
and put Anduril (in FW3A config) on it.
Some tweaking required , now it’s fantastic. 1A is plenty for my EDC tasks and that should stay in regulation down to ~3.2V.
Lowest usable moon draws 2.4mA, quiescent current is 15µA. Not bad.
It still has the stock XP-L @4000k in it. I got a few LH351D’s and Luxeon V’s on the way to see how they compare ( (both 4000K, CRI ~70 vs 90+…. choices…. Flat Stare … any ideas?)
No knurling yet (as I don’t have the proper tools) but I kind of like it this simple. Maybe I’ll pattern etch it, maybe it gets a rubber cover. We’ll see how this holds up anyway, it’s only AW-2007 aluminium which isn’t very corrosion resistant.
pinkpanda3310
pinkpanda3310's picture
Last seen: 3 hours 8 min ago
@kikkoman what tool did you use for the square threads? …and why is the EO1 dreadful?
Nice mod anyway Beer
kikkoman
kikkoman's picture
A hand-dremeled carbide insert (started out as a 11ER 60°), squared the end & sides, narrowed it down to ~.65mm, ground large side & end relief angles and put a tiny radius at the tip.
Could have started with a HSS blank too, I just figured grinding this would be quicker.
From there on it was just manual threading, 100rpm, 0.1mm depth of cut. That AW-2007 machines nicely.
Why dreadful? The driver, mainly. Terrible mode spacing (one mode low, the next three between 350 and ~1000 lm IIRC). No LVP either.
The UI wasn’t that bad (nice and simple) , good form factor too but the modes killed it.
Thanks! Beer Beer Beer
pinkpanda3310
kikkoman wrote:
A hand-dremeled carbide insert.
Nice tip. I’ll try that one day. Thumbs Up Beer
g_damian
g_damian's picture
Last seen: 5 hours 57 min ago
Today I’ve tried Optisolis quad in AT40: http://budgetlightforum.com/node/61852
DB Custom
DB Custom's picture
Last seen: 3 weeks 6 days ago
I got the pair of Eagle Eye X6 hosts in the mail today, already had the quad board from Noctigon loaded with Samsungs and waiting, so I made a nice thick 36×12mm copper spacer/heat sink to fit the 33mm Noctigon board and Ledil Angie into the head of the X6. Worked out really nice, need to build a driver so when a new thermal compound get’s here Monday I’ll be ready to assemble it. Smile
Edit: I went ahead and built a 17mm driver with Bistro and assembled the X6 Quad, after polishing up the top surface of the copper sink. Didn’t use any thermal paste or glue in the sink as I am waiting on Arctic Alumina Thermal Adhesive and a new synthetic diamond thermal paste that will be here Monday. A quick initial test with the light dry assembled showed some 3400 lumens on an LG HE4.
Edit II: The epoxy came early, went ahead and re-flowed the 33mm MCPCB to the copper sink then glued the assembly into the X6 head with the Arctic Alumina Thermal Adhesive and assembled it all….
Bistro was working fine on an LG HE4, but with a Sony VTC5A in place it glitches some of the time. And when it’s not glitching? How about 4616.1 lumens out the front? Big Smile
Edit II: Ok, so I applied the Bistro fix and recharged the VTC5A, now it works solidly and is really amazing…. 5171.55 lumens in Turbo at start. Pretty nice little light! Big Smile
DB Custom
DB Custom's picture
Also got my GT mini yesterday, modified it today. It now pushes 1683.6 lumens out the front on a Sanyo GA cell. Big Smile
Samsung LH351D 5000K 80CRI emitter, domed, on the stock DTP 20mm copper MCPCB. Flashed Anduril to the driver, replaced the FET with an SIR800DP and put 18ga wires on it. 18ga spring bypass on the driver. Removed the pcb in the tail cap and fitted a copper disc with the large spring that came with the light, 20 ga bypass inside the spring.
Yes, I lost some of the tightness of the beam but the color and intensity is so much nicer I can live with the trade-off.
Firelight2
Firelight2's picture
Last seen: 6 hours 54 min ago
Some revisions to one of my Sipik 58s.
Bezel and optic same style as I had previous in this light, but now redone for a cleaner look.
This is the stock lens retaining ring with the interior widened with a cylindrical grinding bit. The LED-Lenser style optic is from a $10 zoom light from OSH.
The previous bezel and optic I had in this late used the same setup, but looked much messier because I ground the inside edge of the bezel where it meets the optic back. And I’d messed up with the glue and some had run down the backside of the optic creating blindspots in the spot beam. This latest attempt looks much more professional.
Minor revisions to the interior of the tailcap.
I replaced the momentary pushbutton I had in there with a bigger one with a more noticeable click. I also replaced the post in the tailcap with a wire-bypassed spring:
Previously, I had a spring at the head of the light and a post made from 2 copper disks at the back. That setup worked, but I noticed the light dimming or flickering after a minute or two of use. the problem was a bad ground connection. Adding the second spring fixed that problem by more firmly pressing the guts of the light together.
NOTE: This particular Sipik 58 clone is very heavily modified. Modifications include:
  • All anodizing removed and bare aluminum polished up.
  • LED mounted on a laminated copper post on top of a copper Noctigon.
  • Stock 18mm aspheric lens replaced with LED-Lenser style zooming TIR optic.
  • Driver replaced with e-switch FET driver from Mountain Electronics (moppydrv firmware. If I were doing the driver today I’d go with a FET+1 driver with D4 firmware).
  • Interior of battery compartment widened to make room for a rolled up plastic sheet and brass sheet to serve as electrically isolated e-switch contact.
  • Tailcap guts rebuilt with copper structure and momentary pushbutton switch.
  • contact rings added at both ends of the battery compartment for e-switch.
  • tailcap switch boot replaced with light-green GITD boot.
  • LED replaced with XPL HI 5D
Cereal_killer
Cereal_killer's picture
Last seen: 9 months 3 weeks ago
What’s going on here?
Is that a DR. Jones RGB driver on the test stand?
Yes, yes it is!
More to come, off to ITCC finals!!!
Cereal_killer
And here it is (my ITCC event got pushed till this afternoon)!
After a stupid routing mistake cost me my $10 driver boards, and not willing to try, and wait for, boards again I switched direction on my triple Rook.
Dr Jones RGB driver! It’s his standard 17mm board with modded rgbw FW (to be 3 channel, using RGB for white). Each channel is 2× 7135.
I really like how well the flood optic works with the RGB and runtime should be ~1h on turbo “white”, though it’s more of a toy instead of a useful light so I may stack another 2 chips per channel later and sacrifice that runtime.
Yokiamy
Yokiamy's picture
Last seen: 3 hours 36 min ago
Looking sharp Dale !
That’s one good looking Quad X6.
Is that the stock lens? It looks quite thick
DB Custom
DB Custom's picture
I have the stock hosts’ clear o-ring on top of the optic and the AR glass lens on top of the o-ring. Wink
I just got the fix applied to Bistro, no more stepping down to moon from Turbo or Strobe…. the fresh charged Sony VTC5A yields a start value of 5171.55 lumens, amazing! Smile
Edit: YOu can click on the picture to open it in a new window then click it again there for a larger look. The set-up then shows itself, optic/o-ring/lens. Wink
DB Custom
DB Custom's picture
In case anyone’s wondering why I drilled the outer two holes in the base of the copper heat sink when the center hole is used, it’s to give torsional strength to the glued joint. I align the ~4mm deep holes with the original wires holes in the emitter shelf of the head so the glue has “posts” to it, really limits the ability for the whole thing to slip and twist wires.
I love using the Arctic Alumina Thermal Adhesive as it sets up in minutes, it’s stuck in about 5 minutes and pretty much cured in 12. Another thing I like about it is that if an mcpcb just has to be removed you can heat up the board with the soldering iron and break the epoxy joint loose. Can’t do that with Arctic Silver or JB Weld, once in with those it’s just gonna stay there pretty much.
contactcr
Last seen: 31 min 5 sec ago
Looks like someone has a new favorite LED
DB Custom
DB Custom's picture
I, uh, bought a tape of 25. Blushing
$2.04 each, shipped I think.
contactcr
Which CRI and color did you pick? Same 5K 80CRI?
DB Custom
DB Custom's picture
Ayup
contactcr
Arrow stocks the 5000K 90CRI Samsung now and they do free overnight shipping.
If you are a new customer they have 30% off ending today. (may be able to create a new account and use the code, idk)
https://www.arrow.com/en/products/sphwhtl3da0gf4rts6/samsung-electronics
DB Custom
DB Custom's picture
I wanted to keep the output power bin higher, the 5000K 90CRI drops power considerably. Wink
led4power
led4power's picture
Last seen: 7 hours 31 min ago
6XP-anna mosX PCB Demo build1 - C8 6xLH351D 4000K 90CRI  (still not 100% finished):
This is how spacer will look like,a little unconventional and more complicated, but it has several advantages - build is easier once spacer is fixed and can't move, spacer is compressed with high pressure, and all wires can be soldered on driver first which is usually much easier. Hole in C8 should be ~8-8.5mm.
Driver LD-B4 18Amp for this build:
Those FR4 0.6mm thermal insulating boards are working as expected, soldering thick wires on them is very easy.
Moon mode:
I used common 1288 Omten switch and 30Q cell,so I didn't test light under full potential yet, but it's damn bright for 90CRI and it's size. Brightest 90CRI C8? Hm maybe even brightest single cell 90CRI light?
Of course big die dome led and relatively small TIR size (but much bigger than carlco optics) makes this light flooder, but it still can burn paper:)
And relatively big ALU spacer definitely works well as thermal storage because light didn't get crazy hot very fast, but it also took more time to cool down. If you are going to use this kind of light in <1min pulses with >1min pause,it is beneficial.
KawiBoy1428
Wow outstanding mech mod on that pill Neven! Beer
skinny_tie
skinny_tie's picture
Last seen: 7 hours 5 min ago
DB Custom wrote:
Ayup
Ay up? LOL
https://ayup-lights.com/
DB Custom
DB Custom's picture
I read a lot of Western’s, the term Ayup was used a lot in the hill-billy or mountain man (typical of slang from the North East US back in the mid to late 1800’s) dialect to mean Yes.
When I said that, I was in dire straits, physically, and giving a short answer before shutting down my computer.
Wieselflinkpro
Wieselflinkpro's picture
I think it could have ist origin in some german saying, perhaps a mixture of “ja” and the slang “jup”. https://www.mundmische.de/bedeutung/1508-jup
g_damian
g_damian's picture
Swib
Last seen: 6 days 11 hours ago
So you’re saying I can remove mpcb’s that I have laid out on an aluminum strip with enough heat? I have a bunch of Nichias on Noctigons that I would love to recover if possible.
If you don’t like what it looks like on the wall, take it outside.
DB Custom
DB Custom's picture
With Arctic Alumina Thermal Adhesive I have found that to be true. I typically put the soldering iron on the edge of the copper MCPCB to heat it up, the adhesive will emit an odor when it gets hot, I usually use a flat blade jewelers screwdriver and twist it to apply lateral pressure or if one of the wire holes shows the bottom of the MCPCB I will put the screwdriver against the bottom of the board and give the screwdriver a sharp rap… I actually keep a 1” wood chisel on my bench to use as a hammer for this type of situation.
I have removed glued boards many times this way.
Using Arctic Silver, or JB Weld, not gonna happen. That stuff is resilient!
