What did you mod today?
9511 posts / 0 new
vinte77
Last seen: 18 hours 43 min ago
contactcr wrote:
Looks good. How is the output relative to a FET triple?
I didn’t have a chance to compare, but the light is quite bright. I spec’ed the driver to 4.2a output and 10.5a input, and ran the light on a Sony VTC6. I think that puts the light at around 2000 lumens, so I don’t think it puts out as much lumens as you can from a high output FET triple if you’re only concerned about the lumens. However, there’s nice things you get from so many lumens from a single led. I will say that the light gets hot pretty fast. One word of warning, just make sure you work out the length of your battery in relation to your switch spring and battery tube since the driver comes with a brass button for contact. I crushed one of my batteries a little while testing.
contactcr
Last seen: 1 hour 6 min ago
Crushed because it was a longer button top or crushed because you had a long/stiff bypassed tail spring?
BlueSwordM
BlueSwordM's picture
Last seen: 2 weeks 2 hours ago
Crushed because there is a solid button which can’t deform under load.
That either meant having a longer cell like contactcr said, or perhaps he dropped the light, and that can easily result in a damaged positive electrode.
kikkoman
kikkoman's picture
Finally upgraded the old beaten up TK35 clone with a Luxeon V (4000K) running at 6A and a LM3409 buck driver with Anduril. Should be around 2000lm on turbo with a comfortable 2.6A battery draw.
Very nice beam with the smooth stock reflector. Good tint.
Not exactly a looker, I know. Neither on the inside nor on the outside. LOL And you haven’t even seen the ugly bits.
Works like a charm though. Better than new.
contactcr
what did you use for your centering ring?
kikkoman
kikkoman's picture
A piece of acrylic, turned on the lathe. It’s mostly for visual guidance during centering though, I only had a 16mm star where a 20mm would be the right size, so that was a bit tedious.
It doesn’t have to bear any load since the LED pill rests against the reflector flange.
It also helps keeping any dirt from getting inside.
vinte77
My switch spring was a bit stiff and a bit long. Plus when I was testing out the light, I put the battery in through the head side and screwed in the head. I found that my flat top of my battery was crushed a little bit. I don’t think it’s something to be alarmed about but nevertheless it’s deformed a little bit, fortunately it’s only cosmetic. However, I can see if you have a long stiff spring on the tail side that it would be easy to crush the battery a little bit if you’re not careful.
goshdogit
goshdogit's picture
Last seen: 41 min 1 sec ago
I modded my Emisar D1S into a single-mode light! Facepalm
Since I was reflashing Andúril onto the GT mini that arrived today, I opened the D1S to update it, too.
I tested it before reinstalling the reflector, and all was well. After reassembling the front end, it wouldn’t power on.
It turns out my emitter board solder joints were slightly too large and positioned too far toward center. Both shorted against the reflector.
With the reflector removed, the light comes on when power is applied. I got it to ramp up and down slightly a couple of times, but it’s now a single-mode driver.
I hooked it back up to the PC and the ATtiny85 is still responsive. I reflashed Andúril in case it was corrupted but that hasn’t helped.
It seems to be stuck at a moderate output level, not turbo.
I’ve already emailed Hank asking how to order a replacement driver, but does anyone knows what component(s) I’ve damaged?
KawiBoy1428
KawiBoy1428's picture
Last seen: 8 hours 46 min ago
Replace the FET. It’s an Infineon Mosfet. https://www.digikey.com/product-detail/en/infineon-technologies/BSC009NE...
KB1428 “Live Life WOT
goshdogit
goshdogit's picture
Thanks, KB! Thumbs Up
Looks like I’ll be putting together a Digi-Key order… Big Smile
EDIT: Or, maybe not. They’re on backorder at DK. Mouser too.
KawiBoy1428
Do you live in the U.S? I have plenty of them!
You can use these too, just as good, and cheaper..https://www.arrow.com/en/products/psmn1r7-25yldx/nexperia I have plenty of them too… yeah I roast a few now and again…
It’s up to you…. Wink
goshdogit
goshdogit's picture
That’s very nice of you, especially since I still owe you for the 70.2 MCPCB you sent me! Big Smile
I see that the FET you linked from Arrow is a ’4-pin and tab’ layout.
Is that a suitable replacement for the 8-pin one on the Emisar driver? What orientation would I mount it in?
I’m a bit in over my head as far as driver design and theory is concerned. Smile
KawiBoy1428
Yes it works, solder across the back, Tab is ground. Same with the 4 pins in the rear of the Infineon, (underneath the FET) the large base is ground. It will all become clear when you remove the old FET.
goshdogit
goshdogit's picture
Thanks, I removed the old FET and see what you mean.
I also readied a piece of 30 AWG Kynar wire to replace the trace that I ripped off of the board. Facepalm It’s the one that connects the pin 1 of the FET to R3 and R4.
I’m trying my darnedest to kill this driver! I’ll report back in a couple days when a new FET arrives. Smile
Mark M
Mark M's picture
Last seen: 2 weeks 2 days ago
I reflowed Samsung LH351C emitters on my otherwise stock Emisar D4 with Nichia 219C LEDs that I managed to dedome from heat. I felt that my stock Nichia LEDs were tinted green. I thought that the Samsung LH351C would be better but they seem to have the same green tint maybe not quite as bad. Puts out 2400 lumens OTF at turn on, 2200 at 20 seconds, not very impressive and they seem to heat up just as quickly as the Nichia 219C, probably beacause of the lower forward voltage.
maukka
maukka's picture
Last seen: 3 hours 28 min ago
Do you have the original CRI80 219C or the later CRI90 219C model with reduced current?
Mark M
Mark M's picture
The later 90CRI model.
Jaded
Jaded's picture
What is the diameter of the D1S driver? Based on the picture, I’m guessing 20-22 mm?
Mark M
Mark M's picture
ToyKeeper states it is slightly over 22mm.
http://budgetlightforum.com/node/57031
Jaded
Jaded's picture
Thanks. If a replacement driver can’t be acquired from Hank, I think I’ll consider TA 22mm driver.
DominikM
Last seen: 1 day 19 hours ago
Petzl Tikka XP
Luxeon RX0HW -> Cree XP-G3 S5 tc 5000k
Enlightened member of pl.rec.rowery
Light-Test.info – bike light’s & Headlamps comparison site. – In polish but picture says everything
djozz
djozz's picture
Last seen: 2 hours 7 min ago
^ wow, 4 times the output with an emitter swap!
djozz
djozz's picture
Are those the 5000K 90CI LH351C emitters from Arrow? That is a disappointing first result from this led, at this current a lower performance than 219C and not a great tint.
Mark M
Mark M's picture
Correct, it is those same emitters.
DB Custom
DB Custom's picture
Last seen: 20 hours 36 min ago
I keep hearing about tint issues with the LH351 but the ones I got from Arrow are very consistently pleasing, no green or rosy hues. I got the D model at 5000K and 80 CRI and the 40 I’ve used have been excellent. Price was very good as well at around $2.04 each shipped.
DB Custom
DB Custom's picture
Oh, and Kawi? The large pad under the MOSFET may indeed be the negative lead to the emitter but it definitely is not ground! Let ground touch that and you’re in direct drive from the cell with no modes, bypassing the driver…
Just to be clear for those that are new to all this.
goshdogit
goshdogit's picture
I got the new FET installed on the D1S driver but it’s still one mode.
I tested the switch and it’s good, and the driver acts the same with the switch removed.
For now, I put my D1 driver into the D1S so I can do some comparisons with the GT mini. I made sure to make my MCPCB solder joints flat and toward the outside of the board.
I probed around while I had both drivers out and the connections seem ok.
My trace replacement to pin 4 also tests good. It’s not touching pin 3 as the photo might suggest.
Earlier, I incorrectly referred to the bottom right pin of the stock FET as pin 1. It is actually pin 4.
I thought the dimple in the corner of an IC was a universal marker of pin 1. Apparently not?
BTW, Hank got back to me, and it’s $6 for a replacement driver.
Lightbringer
Lightbringer's picture
Last seen: 48 min 37 sec ago
The one with the splootch of white paint? That’d be pin 1. Bottom-right would be pin 4.
They (generally; dunno any exceptions) always go ccw, so a dimple in the corner means it’s pin 1.
Mark M
Mark M's picture
Maybe check the diode?
goshdogit
goshdogit's picture
That’s the ATtiny85. I dot them with a silver Sharpie to help me align my SOIC clip.
To clarify, I thought it was nearly universal that ‘dimple = pin 1.’
I was surprised to see the Infineon FET not adhere to that.
I did some reading and it appears that it isn’t a hard rule. Some chips don’t even put pin 1 in a corner! Silly
