What did you mod today?
9496 posts / 0 new
Henk4U2
Henk4U2's picture
Last seen: 14 min 32 sec ago
Not keen on soldering in a set of high quality springs in my brand new Sofirn Q8, I decided to do an old fashioned spring bypass. Not from the top of the spring to the tailcap switch (which does not exist), instead I put in four 20AWG connections from the top of the spring to the spot where the base plate is screwed to the body. The loops are wound around the screws between the base plate and the body. Four leads may seem a bit crowed, but there is a lot of empty space between the springs. Output improved from about 90 to 93 kCd.
To compensate for the fact that the loops add an extra mm between baseplate and body, I exchanged the Ø2.5*4mm screws with longer ones from my spare parts can.
Edit: for reasons of visibility the picture shows only one bypass.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 1 year 1 month ago
I played a bit with the light and if i remove the led centering ring the pattern is gone. But without the reflector is not centered right and i loose preasure on the MCPCB.
So i live with the beam. If you hit something uv reflective the pattern is also not visible (the glow is to bright).
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
CRX
CRX's picture
Last seen: 1 month 1 week ago
Rebuilt the tail switch on my triple XP-G2 3D PK Paladin for some waterproofing and added a tritium vial.FourSevens PK Paladin Triple XP-G2 3D - FET 15+1 - 16340 - Rv Clicky Tail Sw - 1960lm.
The reverse clicky tail switch is housed in some copper tube & sheet covered with a silicone boot.
I installed a 4mm x 0.5mm green tritium vial in the titanium switch button backed with glow powder.
Carbon fibre wrap in the battery tube to stop any rattle.
Start around 1900lm DD, 928lm stepdown 30s.
Length – 64mm
Width – 24mm
Weight – 77g (with 16340 cell)
Max – 1900lmFourSevens PK Paladin Triple XP-G2 3D - FET 15+1 - 16340 - Rv Clicky Tail Sw - 1900lm..
TBone
TheOnlyDocc wrote:
Completed my BLF D80 UV Mod […]Its bright! On your skin you can feel the heat after a few seconds.
I was reading BLF Q8.
THAT would be a UV mod that heats your skin… Evil
contactcr
Last seen: 6 min 54 sec ago
A few of you guys asked me about my C8TT mod from this post:
http://budgetlightforum.com/comment/1393629#comment-1393629
Well, great news. I ordered a CUTE-4 ~20° medium optic (C10447_CUTE-4-M) instead of the smooth spot ~12° and it got rid of my donut problem entirely. You still get a slight “starburst” on the very outside of the spill but it’s noticeably less square with no donut in middle.
With direct drive enabled I only lost 200lm (4%) as well which is exactly what the datasheet claims. Also, 20 degrees is still pretty narrow so it still has a nice hotspot.
I purchased it from Allied Electronics (www.alliedelec.com) they have world wide distributors too. It sucks I had to pay as much for shipping as the optic but the beam is pretty much entirely fixed so worth it.
jon_slider
jon_slider's picture
Last seen: 8 min 25 sec ago
Just received Novatac Gold Storm, modded to N219b 4500k 9080, on right is a Novatac w stock LED (and B42 tail)
beams
lumens, on my homebrew meter
Gold Storm max 94 lumens, min 0.23 lumens w N219b
Pewter SPA max 74 lumens, min 0.08 lumens w stock LED
Under UV light (lights are Off)
SKV89
Last seen: 8 min 26 sec ago
That 4500k looks so pink. My ROT66 look nothing like that especially at lower lumen levels, it’s natural white.
jon_slider
yes in some relative comparisons the SW45 is Very pink, but that all depends on what it is being compared to, and the white balance of the photo
some examples of the N219b 4500k looking “white”, at low levels, and in full darkness
the next 2 photos look like what I saw with my dark adapted eyes
Note that photos with single beams will tend to white balance to that beam, our brain does the same thing, so in the following photos, we see no Pink, just “natural white”, as you said.
here is that same sw45 shining on a ceiling next to a 3000k Incandescent, as you can see, it does not look pink at all… the white balance is essentially set to the 3000k incandescent. My brain does that too. So the 4500k looks relatively cool, by comparison.
the above photo actually looks very close to what I see with my eyes. I have been sitting under that 3000k light for more than an hour, my eyes now see it as white light.. even though during the day it looks rather “orange”, at Daylight white balance of 5500k.
in some cases, the sw45 photographs as violet, but that is not how my eyes see it
left to right, N219b 4000k 9050, 4000k XP-L, N219b 4500k 9080
“white” is relative to White Balance, iow, the Color temperature that our brain, or camera, is set to.
White Balance will drastically change the apparent color and tint of an LED. That is why I always include more than one beam in my photos, so people can make a Relative Comparison of tints.
in the case of the SW45, I agree it definitely looks “white” when compared to warmer CCTs, it can even look relatively Blue
otoh, during the day, when my brain is adapted to Sunlight, the SW45 definitely has more Pink Tint than Sunlight..
in fact, the SW45 is one of the most “Pink” LEDs I have (furthest below the BBL), it simply has some of the highest R9 of any LED I own.. I absolutely LOVE its versatility as an EDC.. Not too warm during the day, and no hint of Yellow (which I love to hate). I find the SW40 9050 “too” yellow, during the day, but the SW45 9080 does not have that “problem”..
one more example of Relative Tint and Color:
what the camera sees is not necessarily what my eyes see, it depends on what ambient light my brain is adapted to, and that is certainly not necessarily the same as what the camera sees.. The auto white balance tends to bias itself to the coolest and or brightest light in a photo. In the photo above, the auto white balance is setting itself to the light on the right, a 6000k XP-L…. Tint is relative to the white balance of the brain of the beholder.
goshdogit
goshdogit's picture
Last seen: 2 min 5 sec ago
I created a ‘Rosy Rotary’ by swapping a Nichia 219B R9080 sw45k into my new Sunwayman V11R.
It’s the newest member of ‘Team Rosy.’ Party
EDIT: Correction, the Eagle Eye X1R is the newest member of ‘Team Rosy.’
It just arrived and had a 219B swap, but was too late for the group photo. We’ll have a re-take when the ROT66 arrives next week. Wink
CRX
CRX's picture
Bob_McBob
Last seen: 6 hours 55 min ago
I did SC64c #3 last night. Also I am bad at sticking on labels.
chops728
Last seen: 1 month 3 days ago
I made a couple adapters for my chargers—I have a few D cells i wanted to test and some 21700—- I used Teflon wire , a little stiff for the small magnets I used— with these you can also test your chargers output— there seems to be a little resistance—might be the galv screws I used—any way they serve their purpose—Hook to the battery first—Don’t want to short your charger
goshdogit
goshdogit's picture
That’s a cool idea, chops! Thumbs Up
JaredM
JaredM's picture
Last seen: 1 hour 55 min ago
Well I tried to mod something today.. after a long time in shipment, my Virence order arrived. First time handling the e21a. Attempted a quad reflow. All went well the first try. No extra solder, alignment reasonably good. Go to the power supply to test them.. 2 work, two don’t. One must’ve rotated on me. Back to try mounting them again.. lifted the suspect emitter with a pair of tweezers and.. flick.. there she goes. Few minutes later after resorting to the UV light, I found it in the floor. Chipped the edgeand exposed the blue chip.. Crying
This dummy only bought 4. Anybody stateside have 2 sm453’s they can part with?
M4D M4X
M4D M4X's picture
Last seen: 53 min 5 sec ago
just some S43S Lego Wink
 all new deals are also posted here: deals.m4dm4x.com
if you do not find what you are looking for :
ask MARTIN@M4DM4X.COM - i will save you money!
Kame Sennin
Kame Sennin's picture
Not that much real mods but a busy afternoon anyway :
  • Since i received my usbasp a few days ago i converted all my convoy S2 that weren't already from 3/5 modes to Biscotti firmare (had to cut the pcb on pin 5 because it was tied to ground on the old drivers)
  • While doing that i confirmed that all 7135 are not made equal. The ones i had on a 3/5 modes driver i got for GB were not working in moonlight mode. Nice i had some spare from a 8x7135 i converted to 4x7135 so it's working now ... almost working actually as the light output and current show that only 3/4 are doing their job but since the pcb is now soldered into the pill i'll invastigate that later (bad solder ? Fried 7135 ?). I was hesitating to make it 1A or 1.4A anyway Wink
  • Baked a Utorch XLP-V6 in the kitchen oven. Looks like i have to find something hotter as i got some chocolate while i was expecting "coyote" or "desert tan", not bad anyway and still better than the stock black anodization.
  • Started paper-sanding an other Utorch XPL-V6 to remove most of the black anodization (you guessed i don't like it very much Wink ). I am expecting some "worn old tool" look but the "too much sanding" is hiding nearby so who knows what i'll get
Lightbringer
Lightbringer's picture
Last seen: 1 hour 21 min ago
Hjeh. kewl!
I made “disposable” ones that way. The wires/magnets I keep, but would use those whote tubular “foam” (blown LDPE, I think) to wedge ‘em in 1-cell chargers for my 26650s when I wouldn’t want to unpack a bigger charger.
Like now, with the Cometas, I needed to charge a 26650 that I had in an F13… dug up the wires, and ♫ viola ♫, instant charger! Big Smile
Agro
Agro's picture
Last seen: 2 min 20 sec ago
!https://i.postimg.cc/DyXp0g2W/IMG-0505.jpg!
Similar pic from Vinh:
M4D M4X
M4D M4X's picture
who said the S43S is not compatible with the S42? Wink
some generation - meeting LEGO:
Micmania
Micmania's picture
I was the one who told that info on TLF. Facepalm I tested my early 2017 S42’s front bezel which only took 2 or 3 rounds and then … no way to close the gap.
So maybe the newer S42 bezels will fit .. ?
joechina
Last seen: 6 days 12 hours ago
It is not necessary connected to the production date.
When they produce with more lathes on different lines one can be off.
Or one cutting tool was worn out and they replaced or adjusted it to late.
CRX
CRX's picture
MRsDNF
MRsDNF's picture
Last seen: 2 hours 32 min ago
I’m in love. Love
M4D M4X
M4D M4X's picture
wonderful build CRX
Wieselflinkpro
Wieselflinkpro's picture
Wieselflinkpro wrote:
Finished my BLF GT yesterday.
Stock driver and Lexel XHP35HI (my LED had only 3 working Dies)
Wavien Collar
Fresnel Lens
GITD Tape in the Reflektor Housing.
Not yet checked the Lux. I will do my Report on TLF, and perhaps link it here.
Cannot wait to see this!
It looks verry powerfull outside.
Nice big sqare beam.
Yesterday I met some other flashaholics on the Rudelsburg (https://www.google.com/search?q=Rudelsburg)
I hope someone made some photos of it and add it to our album: https://www.taschenlampen-forum.de/media/albums/saxxen-th%C3%BCringen-sa...
It lasts some days, but I have written my report with some pictures:
MRsDNF
MRsDNF's picture
Nice mod Wieselflinkpro. Lots of experimenting there. Beer
djozz
djozz's picture
Last seen: 19 min 57 sec ago
Yes, nice experimenting! The hotspot actually looks really decent through the fresnel lens!
Enderman
Enderman's picture
Last seen: 17 hours 10 min ago
1.6Mcd with an XHP35, very nice.
I gotta add this to my list of most powerful flashlights Smile
SKV89
Wieselflinkpro, very impressive! Thanks for posting. Would be nice if Lumintop can actually manufacture one for mass production
Skylight
Skylight's picture
Last seen: 4 hours 47 min ago
Thank you, M4D M4X, for doing this lego. I wondered if the colored S42S tubes would fit the S43S. I'm not very pleased about the black anodisation, your colorful version looks much better and tempting!
