What did you mod today?
8660 posts / 0 new
djozz
djozz's picture
Last seen: 6 hours 51 min ago
Figgy wrote:
@djozz http://prntscr.com/nj96km how did you do this to the d4s? omg
It was a 2-minute mod: I photoshopped it Innocent
DB Custom
DB Custom's picture
Last seen: 2 hours 12 min ago
I’m seriously thinking about feeding my D4S tube to a Grizzly…
Lightbringer
Lightbringer's picture
Last seen: 2 min 39 sec ago
…as a “light” snack?
DB Custom
DB Custom's picture
Sort of,
or to be more precise… this exact one…
Capital
Last seen: 1 month 1 week ago
I’ve been having some fun with the 3v XHP50.2. I flowed this one onto the MCPCB myself which I normally don’t do. Notice some odd color on moonlight. Is this normal? My other XHP50.2 light is 6v and doesn’t go as low so I can’t really compare them.
https://imgur.com/gallery/hWQ5E7S
chops728
Last seen: 30 min 55 sec ago
DB Custom wrote:
Sort of,
Is that still the table/Stand Old Lumens had built
pinkpanda3310
pinkpanda3310's picture
Last seen: 14 hours 49 min ago
Yeh, the stand looks familiar. Also it all looks quite clean…. Wink
DB Custom
DB Custom's picture
Uh, well, that was taken when I set it up. It no longer looks quite like that. Clean, it is not. Blushing
TrueRMS
Last seen: 2 months 3 days ago
I built and installed the lighted switch board for my HC30 mod. It has had the a TA driver running anduril (as FET+1 for now, till I get more of the good 7135’s), just the SW board is new from this weekend and that’s a tail clicky clear SW boot cut way down to fit.
gchart
gchart's picture
Last seen: 1 hour 54 min ago
Very cool. Not too many headlamp mods happening, it seems. Easy to take apart? Is the driver just pressed in? Was it glued? Is that one of the new lighted boards from MtnE?
ZozzV6
ZozzV6's picture
Last seen: 13 hours 29 min ago
I made today a programming key for Astrolux FT03.
TrueRMS
The sanded down 22mm TA driver is pressed in (stock driver PCB was glued but threads wernt). Overall pretty easy to mod.
The switch board is my own design, it’s 10.3mm. BTW oshpark sticker 0×19 is the best one I’ve ever seen! This is V2, originally V1 had 4 led’s and a leadless switch from sparkfun but it turned out to be super weak and I think the reflow heat was causing them to fail prematurely, I went through all 5 switches I had, each would last a few days after being soldered on. Dumped the leadless switch for this more common one, deleted 2 LED’s and moved the resistor to the back and these boards are G2G.
Next on my bench is my ArmyTek tiara C1, gonna give it the same treatment (hopefully light shines through its yellow boot).
Firelight2
Firelight2's picture
Last seen: 3 hours 11 min ago
FW3A – emitter and optic swap. Beam is pretty similar to the original beam, but maybe tiny bit tighter and has a slightly warmer tint.
  • Emitters: XPL HI: two 3D and one 5D.
  • Optic: polished the frosting off 10511 optic using jeweler’s rouge and a soft cloth.
contactcr
Last seen: 1 hour 6 min ago
Doesn’t it have a starburst spill?
Firelight2
A little bit. I haven’t checked to see if it’s any more than the frosted 10511 though. Any petals in the spill are still far less than with 10507 optic.
ZozzV6
ZozzV6's picture
Astrulux FT03 firmware replacement to Andúril:
Nichia
Last seen: 3 weeks 4 days ago
 very cool. Awesome work!
Nichia 219B
Nicolicous
Nicolicous's picture
Last seen: 57 min 40 sec ago
Hey ZozzV6
can you please do a tutorial video how to flash firmware ? your video skill is good and there is none good tutorial on youtube Smile
Nico -.-
ZozzV6
ZozzV6's picture
Nicolicous wrote:
Hey ZozzV6
Actually that was it Smile Other things you need to make before flashing is written well in this thread.
Ryzbor
Ryzbor's picture
Last seen: 15 hours 56 min ago
And did you modify the code to let the lightning storm mode hit 100% brightness? Evil
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K to be modded with FA3 SST20, super rosy 3000K E21A Tiara and super warm 2000K Wizard Pro on it's way
ZozzV6
ZozzV6's picture
Nope. I don’t use that very often.
CRX
CRX's picture
Last seen: 53 min 49 sec ago
Some brass tube & stuff.
CRX Brass 14500 elegant
M3CSL
M3CSL's picture
Cut a bit of spare MDF, put leather on it, then loaded the strop with red compound (sold as 1K grit on AliExpress).
This is a compact strop for smaller knives and more for on-to-go use in a backpack.
Need to heat up the compound more to make the wax sticky.
This is also the first time I used Shoe Goo as the binding agent between leather and MDF, it is superior to the glues I have tried before!
Convoy S2+ 219b triple, Astrolux FT02, Maglite 3D, Solarforce L2t
gchart
gchart's picture
Soldered up and programmed a new “smart” tailcap today; this one is for 14500 lights. Swapped out a friend’s Booster Tail for this one since he always uses his Sofirn SF14 with li-ions (with AA/NiMH the flashlight will still work of course, just not the tailcap now). It has 6 LEDs and uses them to display battery status.
First battery in the video was at 4.07 V, the second was at 3.55 V.
Lexel
Lexel's picture
Last seen: 1 day 6 hours ago
saved today myself 800€ getting an Upgrade Hack on my Power supplies
djozz
djozz's picture
Those smart tailcaps are fun Thumbs Up
contactcr
Did another Q8 bypass today. I always like how these turn out since there is a nice hole to feed the wire through and solder from the back. They have really good flexibility this way and just look nice and clean.
pc_light
pc_light's picture
Last seen: 34 min 23 sec ago
gchart wrote:
Soldered up and programmed a new “smart” tailcap today; …
A fuel gauge with no more counting blinkies. Nice Thumbs Up This has got to be the next “it” tailcap mod.
Seeking the light.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 11 hours 30 min ago
Convoy T2: XP-G3 5000K with BLF A6 Driver, doing 1150 Lumen at start.
old Long Range Tactical (from Banggood) with XHP50.2 5000K and F6 5A, doing 2000 Lumen.
Lightbringer
I like Luxpro lights for burning off “dead” alkaleaks, and this critter that takes 2 D cells, an LP1101V2, is a nice beefy light in most ways, but has a front “glass” that’s actually plastic. Facepalm
Wellp, I couldn’t abide that, so decided to stick in a glass replacement from FT for about a buk, and slap on some diffusion film to smooth out the XP-G3’s hideous beam.
It’s a pretty standard ⌀42mm×1.5mm glass, same size as from a C8. Drops right in (albeit a little snug getting past the threads), loads just like a S2+, pressed from behind by the reflector against an O-ring set into the front bezel.
Nice light, actually. Even if you’re not gonna use alkaleaks (ie, you’re sane), you can get a pair of 3AA-to-D adapters and drop in a bunch of eneloops in a 2S3P configuration, and you’re good to go.
That’s what I’m using to burn off moribund alkaleaks (ie, sanity’s in question), but watching them carefully and checking them frequently.
It’s not a screamer, but for a good backup light, it’s quite nice.
Hmm, I might wanna throw in a nice fat XP-L if I can find one in 4C or thereabouts… I might even have a 5A.
Will see about doing that tonight if I find one.
