What did you mod today?
9291 posts / 0 new
EasyB
Last seen: 2 hours 51 min ago
Djozz, very nice pocket thrower. Is that using a 18500 cell?
Is that 5A linear driver the one discussed here?
http://budgetlightforum.com/node/68416
How do you like it?
djozz
djozz's picture
Last seen: 3 hours 10 min ago
How do you like it?
It uses a 18350 cell, the longer reflector of the S5 makes it 4mm longer than a S2+ shorty.
Almost that driver, it is the 5 amp version, but it looks the same. I like that it is cheap, that current is regulated and that it has 4 well-spaced modes and the low is a nice low-low. I do not like the memory it has because I need my lights to behave predictable.
gchart
gchart's picture
Last seen: 6 min 42 sec ago
I’ve tried to identify the regulator chip on Simon’s new driver, but no success. It appears to be labelled “SVA11” or something to that effect. I’ve used the QX7138 in a similar fashion, but it’s limited to 3A. You guys have any idea?
ifratos
ifratos's picture
djozz wrote:
^Nice charger build. I wonder if a readymade li-charger is actually more expensive but it is also the fun of building it. Smile
The pleasure to mod is priceless ! Smile
And God said, Let there be light: and there was light.( Gen.1:3)
jon_slider
jon_slider's picture
Last seen: 2 hours 39 min ago
modded two original RRT-01 to sw40 9080, w kaidomain reflector and centering ring, xp star, and lubricated control ring w Nyogel 767a for very firm resistance, then fine tuned with a bit of nano oil to get the right “feel”.
Agro
Agro's picture
Last seen: 17 hours 19 min ago
Over the last couple of weeks I modified UI of my Emisar D4S.
Of the interesting changes I made lockout mode much more prominent.
  • after power is connected the light starts locked out rather than off
  • 3 clicks from off goes to lockout
  • 3 clicks from on goes to lockout as well
  • 3 clicks from lockout goes to off
Some time ago I requested mode memory that doesn’t last too long. Now I implemented a variant of that:
  • mode memory is reset upon lockout
TODO: autolockout after 10 minutes or so
TODO: exiting lockout starts the light (how? depends on the exact click sequence)
It’s too early to tell whether that’s comfortable. Actually I may prefer something even shorter than 3-clock, but that’s for later experimentation.
djozz
djozz's picture
Keep on experimenting Agro. Nothing beats a physical design that prevents unwanted activation, but a very convenient software solution is the next best thing.
Mike C
Mike C's picture
Last seen: 3 months 6 days ago
I’d like to know too. I have a quick go at identifying it but just as you I’ve come up short.
djozz
djozz's picture
I can make some good pics of the driver tonight if that helps?
Mike C
Mike C's picture
That could engage more people in the hunt, please do!
djozz
djozz's picture
In return for the good pics ( Silly ) can someone point to how to remove memory on this driver, maybe as simple as a pencil trick on one of the caps? (there are too many caps on this driver Tired ).
EasyB
Can’t help with the memory removal, but have you looked at the other linear driver from Simon? It has an interesting UI that allows brightness configuration of each mode, and does not have memory.
Regarding that regulation chip, I’m curious how it works. My understanding is that the FET is dissipating the heat to regulate the current. Is that regulator chip sensing the current and driving the FET gate?
djozz
djozz's picture
I bought 5 of these drivers with memory, I liked the simple and clear operation, while the other type came with very confusing information on the Convoy site. In the meantime that one may have proven to be better for me, but I still have 4 drivers to go… Facepalm
Agro
Agro's picture
I agree…and at the same time I don’t.
The only mechanical lockout that worked for me with complete reliability was clicky switches. Even twisties would turn on by themselves from time to time.
Clickies work reliably because of the long switch travel – and that long travel makes them bulky.
For most of my use cases the bulk is a larger issue than a more involved startup procedure.
I love Nitecore TINI host (but hate UI). It’s extremely potent for the size. The buttons are easy to find and operate single-handedly. There’s no any physical protection – and with the right UI such protection wouldn’t be needed.
The real game changer for me is the momentary mode while locked out. Many times it enables me to avoid the involved startup procedure.
That, coupled with a number of nice tweaks (memory reset, aux LEDs signalling “hey I’m unlocked”) makes me want to explore avoiding physical lock out.
So far I used to have lights in 3 states:
  • physically locked out
  • off
  • on
off would really be only a temporary state and I would most often shut the light down by cutting the power.
I’d like to experiment with soft lockout because:
  • it enables aux LEDs working as locator light (and looking cool at the same time)
  • it can be more reliable in most hosts
  • it enables more host designs (i.e. TINI- or Aurora- like)
  • it gives more possibilities for state change. Physical can do only locked-out -> (one whatever mode, typically off). Soft can have direct shortcuts to multiple modes
BTW I experimented with entering the locked out state by the means of cutting the power; quickly twisting the tube back and forth can be less involved than a 3-click. It works reliably when the main LEDs are on, even at moonlight, but not at all with AUX, even when they are bright. Actually on -> locked-out transition is the one I care more about and I’m happy to see it working.
gchart
gchart's picture
Yeah, I think that’s the gist of it.
Chatika vas Paus
Last seen: 2 hours 32 min ago
Not really mod. Today I found 3 pcbs for TA fet+1 in my box with junk and decided to solder them. Actually don’t know what to use them for ¯\_(ツ)_/¯ Suggestions?
Lightbringer
Lightbringer's picture
Last seen: 6 min 51 sec ago
In a flashlight? Unno.
Yokiamy
Yokiamy's picture
Last seen: 2 hours 15 min ago
Wow! very nice and clean job! Awesome drivers
gchart
gchart's picture
Naw, too obvious. What else needs a driver… a car? A printer?
Lightbringer
Wellp, I like the pretty purple… earrings for the missus? LOL
djozz
djozz's picture
Convoy 17mm 5A lineair driver
Yokiamy
Yokiamy's picture
With temp protection Wink remove the NTC to get rid of it.
Swapping/stacking sense resistors allows you to play with current output
Mike C
Mike C's picture
Wow, those where darn good pics, thanks! Beer Sorry I can’t help you with the memory issue.
It looks like it has two Alpha & Omega AON7520 “AlphaMOS” mosfets. I might be wrong on the precise model but that symbol on them is definitely Alpha & Omega.
It would be nice to know what that SVA11 / SVAII thingy is.
djozz
djozz's picture
At the risk of exposing my lack of electronics knowledge: could those all be FETS? In which case, together with the two big ones, for each power setting a separate channel with FET is used (so no PWM) ?
gchart
gchart's picture
The two large squares in the center are the primary FETs running in parallel for redundancy / heat spreading / etc. The medium sized three legged chip is the smaller FET that Mike mentioned, usually used for signal control or power under 2 amps. The 10 legged chip is a PIC-style MCU. It’s that 5 legged (SOT23-5 footprint) that runs the FET control show. It’s got to either be a current controller/regulator or op amp. I’m still mildly new to those. I’ve searched for hours to try and identify it, but no luck yet.
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 21 hours 55 min ago
I did a lot of mods, upgrades, etc. this last weekend. One of my favorites is to this SK98 I've had sitting around for a while.
I 'helped' TA get rid of some LEDs and I used this 219C, 5000K on a 20mm DTP MCPCB to replace the XM-L.
I replaced an UltraFire 5 mode (H,M,L,Flash,SOS w/memory), 17mm FET driver in a C2 with a Convoy SST40 5A and used the old C2 driver in this 98.  Sorry, no picture of that driver but I opened up the hole on a Nanj 20mm contact board, extended the driver's cheap spring, added another (from a bad SP32A driver) as a spacer, soldered the negative outer rings and then by-passed all that resistance. It can pull 6.7A with a Molicel P26A, ouch!
I found out that an S2+, lit switch fits and works fine with the Ultrafire driver.  I don't want to burn it all out so I'm using 35Es (~5A).
And the 90+ CRI, 5000K tint is beautiful! with an 'almost' sharp-focused projection of the die.
EDC
FW3A, SST20 4000K || S21A, Crescendo Mtn20DD, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, LH351D 4000K | L2 w/Mtn17DD Zener Guppydrv, XHP-50 | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | SK Zoomie Nichia 5000k, C2 driver | EagleTac clip | Ultrafire C2 w/5A 17mm & XM-L2 | Nichia 219C 2700K with gray S6 |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3)
Mike C
Mike C's picture
Correction: I didn’t mention the three legged chip, I only mentioned the two primary FETs (Alpha & Omega AON7520) and the SOT23-5 chip (SVA11/SVAII).
KawiBoy1428
KawiBoy1428's picture
Last seen: 24 min 52 sec ago
A couple Surefire 6P mods.. (I got bored)
. 6P machined for 18650, kiriba-ru copper triple/quad hand fit to press fit pills, Lexel aux board/Mtn/Dragon board both with Dragon drivers…
Left 5Mega/Surefire Defender head, red/orange Lexel board.. Right Surefire 6P fully loaded… Fully Loaded 6 Tritium tubes… Fully Loaded Glow Tape.. Fully Loaded Dragon Secndary/Aux LED’s Low… Fully Loaded Dragon Secondary/Aux High.. Red/Orange Dragon Sec/Aux on High…
KB1428 “Live Life WOT
MRsDNF
MRsDNF's picture
Last seen: 19 hours 23 min ago
Nachtfeuerzeug wrote:
I ‘helped’ TA
I love reading about one member helping out another. Nice work Nachtfeuerzeug. Smile
Natewar
Natewar's picture
Last seen: 1 month 1 week ago
Convoy m21a xhp50.2 6500k 18.5 amps with a Samsung 30t 5,000lm cold 4,800lm at 30 secs
