What did you mod today?
8537 posts / 0 new
KawiBoy1428
KawiBoy1428's picture
Last seen: 47 min 48 sec ago
EasyB wrote:
KawiBoy1428 wrote:
Cool good too see the Lux and Output numbers… the L2 has a smaller reflector than the FT03 so I’m not that low on my Lux numbers… try a 30T in it if you have one, should boost it a bit.
I was hoping for a little bit more but I’m not disappointed. You saw 22.5A with the 30T? Apparently the K75 driver pushes 28A. Not sure how we can boost the current with direct drive mods; a few VTC5A in parallel? I was thinking a amutorch AM30 with its 3× 18650 in parallel would be a good host for this LED.
Yep me too, I was expecting more cd , but I look at it (now) like a de-domed SST40 (throw) on steroids, so it will do… It’s an impressive, tough, hungry, heat generating LED
. I saw 22.5A with a 30T and on an Ohm RUN 21700. I suspect it’s all the stock FT03 driver can give, (didn’t change the FET I do have plenty of Infineon and SIR800 though) with 18awg bypassed springs and 18awg leads….I messed a bit with shimming but it was a minor gain..
. I would like to try it in a Lumintop SD75 just need to come up with a 4P carrier… I sent Victor a e-mail… see what he can do…. maybe get me a couple whole kit (s) like for the GT?
KB1428 “Live Life WOT
SK1LL
SK1LL's picture
Last seen: 5 hours 10 min ago
after reading of darkening domes I decided to open up and check my Jaxman U1 nichia. All was good behind the UV pass glass so….
The mod: NERFED the driver down to a single 7135 cleaned and reassembled. Cool Now I have to use it more!
- Paul
EasyB
Last seen: 1 hour 19 min ago
Put a 3V XHP50.2 in an emisar D1.
The D1 host is a handy little mini thrower, but its reflector has held it back. The center section of the reflector deviates from parabolicity so it’s impossible to completely focus smaller emitters like the 2mm WF or even the stock XPL HI. This results in decreased throw since not all of the reflecting surface is used for the hotspot.
So I put in a sliced XHP50.2. The emitting surface is large enough to get better focus of the reflector. I usually have a hard time deciding what emitter to put in what light (because most of my lights don’t have actual uses, just theoretical uses Big Smile ). So in this case it was nice to have the decision made easier by the reflector.
With stock springs and a VTC5A it pulled 16A at turn on and did 46kcd at about 5s. From my ceiling bounce I estimate 3300 lumens.
Edit: in fact partly because of the better utilization of the reflector area, this mod about equals the throw of the stock XPL HI, but with 3x the lumens. LOL
http://budgetlightforum.com/comment/1458705#comment-1458705
NeutralFan
NeutralFan's picture
Last seen: 4 hours 16 min ago
EasyB wrote:
An amazing pic EasyB!
I’d rather use my flashlight around the house than turn on the lights.
EasyB
Thanks. There is diffuse sun light doing a bit of phosphor excitation and my phone camera does a HDR thing which makes pics look real good.
Yokiamy
Yokiamy's picture
Last seen: 17 min 58 sec ago
Not really a mod, but it might give inspiration
I made a double flashlight tripod mount from a 1U server rack cover, the plan is to make beamshots and flashlight comparisons.
  BLF
shirnask
shirnask's picture
Last seen: 2 hours 17 min ago
Good idea. – I wont say what my first thought was… Blushing
Yokiamy
Yokiamy's picture
A dirty mind is a joy forever Wink
  BLF
MRsDNF
MRsDNF's picture
Last seen: 57 sec ago
Broom holder?
lumenzilla
lumenzilla's picture
Last seen: 11 hours 47 min ago
hahahaha
Mike C
Mike C's picture
Last seen: 1 day 4 hours ago
Modded an empty bottle of my favorite rum into some X-mas lighting.
Henk4U2
Henk4U2's picture
Last seen: 3 hours 19 min ago
Put a lighted tailcap on my brandnew Panda White Lumintop Tool AA 2.0 HM.
And made this light available in my 3k post GAW.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
The_Fat_Controller
The_Fat_Controller's picture
Last seen: 3 hours 20 min ago
Fitted a 5a 2s mantaray driver into a jax Z1 with a nice 80 CRI MT-G2 for the ultimate flooder
DB Custom
DB Custom's picture
Last seen: 6 hours 47 min ago
Love seeing the MT-G2 getting some attention! Sweet!
jon_slider
jon_slider's picture
Last seen: 18 min 24 sec ago
Copper Tool
installed E21a 3500k and fully captive clip
due to a series of mishaps, and unanticipated outcomes,
the clip now fits in my preferred hat lamp orientation
HenrysCat
HenrysCat's picture
Last seen: 1 week 1 day ago
2 cheap eBay lights with 2 cheap eBay LED's, yes I was bored.
Bored
The_Fat_Controller
Pretty vintage led now . but i still prefer it to the Bill Gates summoning Xhp70.2, im not sure what the lumen count is at 5 amps but it certainly lights a nice area
DB Custom
DB Custom's picture
I still have multiple lights with MT-G2, including a triple that I built from scratch. Love the tint this big emitter makes and surprisingly enough it can have a nice beam profile in the right reflector. Wink Also have an old BTU Shocker that I fitted with MT-G2’s, in this light there is a defined hot spot that is surprisingly small… really do love em! Big Smile
Edit: Was forgetting about the massive TrustFire TR-J20 that I built a huge heat sink for and fitted with 4 MT-G2’s… it’s making almost 15,000 lumens while the other two big ones are in the 10,000 to 12,000 range. Yup, really do love the MT-G2 and like seeing it being put to use. Wink
Edit II:
I have 19 MT-G2’s in use, in (I think) 12 flashlights. Probably forgetting something…
The_Fat_Controller
DB Custom wrote:
Edit II:
Very nice work, I bet they really kick it out!! I like the 5k 80cri it really isnt far behind the xhp70 when driven hard but the tint is just so much nicer almost like real daylight
DB Custom
DB Custom's picture
I have the MT-G2 in a lot of very different lights, such as the Nitecore TM-03, a 2D Maglite with a fiber optic battery indicator, a Lucky Sun D80, Solarforce K3, S2200, M8, and C2000 , as well as my DBC-05 triple, the BTU Shocker, and the TR-J20. Also have a hybrid TIR over an MT-G2 in an L6. And of course, I have an X6 with the fat MT-G2 and an extension tube. Smile
One of the major differences is the array status of the big emitter, it’s almost like a COB really. So the quality of the light is due to the 72 small die surfaces most likely. When I was building the M8 I didn’t have a suitable driver back then so I ran it literally direct drive, it would pull just over 16A at about 4300 lumens. Ah, the good ol days! lol
Chatika vas Paus
Last seen: 4 min 18 sec ago
Probably funny questions, but I’m still too young here.
DB Custom wrote:
I have the MT-G2 in a lot of very different lights, such as Solarforce K3
I have this flashlight disassembled for a long time because I don’t know how to do heat dissipation well. Do you have any great solution or did you leave it as is?
There was an extension tube for X6?
DB Custom
DB Custom's picture
I made a heat sink for the K3.
I was one of the team on the X6 group buy, there were a few extension tubes made for the team. They missed the length but I have worked around that… interestingly enough that was another Neal failure, not only was the length wrong but the MT-G2’s he sent for me to build team lights were also wrong… he sent 9V instead of 6V MT-G2’s.
chops728
Last seen: 6 hours 54 sec ago
Yep—- MT-G2 is Really Nice— I have several lights myself—-one of my oldie but goodies — Supbeam K40M with a 4k
The_Fat_Controller
Ooo those 4k jobs are like rocking horse poop these days! cant find them anywhere
SK1LL
SK1LL's picture
Tired With frustrations of the W1 not staying centered in my D1S. It recieved a SST-20 3500k. Biting my nails waiting for a K1 to arrive anyway.
- Paul
Yacob29
I’ve had this light forever. I like the host, but the multi led head wasn’t cutting it for me. I’d been thinking about modding it and happened to realize one day that it was really darn close to fitting a P60. So a cheap P60 from mtn electronics with a 8×7135 driver and a Nichia 219c were made to fit. Had to do some filing on the reflector, but it works beautifully now.
NeutralFan
Snap-on would be jealous of your new and improved flashlight! Nice job Yacob29.
Yacob29
I definitely enjoyed the irony of improving a snap on product!
BobbyMK
BobbyMK's picture
Last seen: 34 sec ago
Modified two cheapo lights with better leds, they both came with XPE leds (at least they look like it, they maybe clones but who cares they are out now) and they were with very angry blue tint, probably 7000k.
Considering the price the build quality is okay, the lens are plastic and there is no shelf but it does not matter, after all it is cheap AAA light with probably 50ish lumens at best.
One of them got Cree XP-G2 S3 3D that i had laying around from my Noctigon Meteor and the other one received Nichia 219c 2700k 90cri led, yeah i know that Nichia is worth more money than the light itself lol.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
SammysHP
SammysHP's picture
Last seen: 2 hours 52 min ago
In a previous post about my Olight S1R Baton II aux LED mod I complained about the protruding center charging contact that drains the battery when placed on a flat, metal surface and also affects the tailstand stability. Today I took this “light that I do not want” and tried to fix this issue.
To my surprise the tailcap/end of the flashlight was relatively easy to disassemble. I didn’t expect this from a shiny, bling-bling, mass market, “premium” flashlight. But I have to say that the flashlight is engineered really well. They could have made a really awesome flashlight with just a high CRI LED.
Here are the parts of the tailcap/end laid out:
From left to right we have:
  • Plastic (!) retaining ring that keeps everything at the right place
  • PCB with the outer spring and central contact on the back; a curved spring washer contact on the front which makes contact with the tube. Also the riveted central pin that is visible from the outside. (Wait – that pin in negative, but the center of the battery is positive! This means that the rivet and the ring shaped inner contact, that are less than 1 mm apart from each other, have different polarity! But it should be protected by the circuit.) There are also two chips and a few resistors.
  • O-ring that sits around the central pin
  • A plastic spacer that is slid over the contact and o-ring
  • The magnet that sits around the plastic spacer
  • Another o-ring that seals the top of the plastic spacer with the hole in the flashlight case
The two chips are labeled “2408 LV15” (probably a AON2408 n-channel MOSFET in DFN package) and “12B” (don’t know what it is). The traces are not visible under the black solder mask.
And now to the fix for the protruding contact: I made a plastic washer, inner diameter 5 mm, outer diameter 8 mm and a thickness of 0.4 mm. This washer is placed around the riveted pin, then everything else is put on top. The o-ring seal should still work, but the contact does not protrude as much as before anymore. 0.6 mm might have been better (it still makes contact with a flat surface, but is at the same height as the outer, silver ring). To put everything back in the tube I used a PVC pipe. This also helps to press the retaining ring far enough.
