What did you mod today?
5497 posts / 0 new
-X3-
-X3-'s picture
Last seen: 7 hours 19 min ago
Firelight2 wrote:
Modded a blue Convoy S2+ host with metal clicky that I’ve had laying around for awhile.
  • Emitter: triple XPL-HI 5A2 4000K
  • Optic: Carclo 10507
  • Driver: DrJones H17F with lucidrv 2
I started by shortening the pill, the same way as on a previous mod: modding the convoy s2+ mini
After shortening the pill, I decided that rather than making this an 18500 light like the previous mod, for this mod I wanted the light to use 18650. I also wasn’t going to install a side-switch since the whole point of these newer S2+ was to take advantage of the superb metal clicky.
With the shortened pill, there was far too much space in the battery compartment for an 18650. Initially, I was thinking to try my hand at shortening the battery tube via the “human lathe” method. However with a bit more thought I realized there was a much easier way to shorten the light:
I pulled out the hacksaw and chopped the back of the head off. Then I filed a couple mm off the end of the screw threads at both ends of the battery tube. Result is a Convoy S2+ triple that is 12mm shorter than stock (104 mm modded compared to 118 mm stock). The modded light can also use the 18350 battery tube and an 18350 cell (total length 72 mm with 18350).
Additional work to be done on this light:
  • grind off the bottom-most threads on the head to make room for the battery tube o-ring (until this is done there’s no o-ring between the tube and head).
  • wait for illuminated switch assemblies to arrive.
  • possible remove blue anodizing and polish the bare aluminum.
Now I want to see some pictures of that !
I scratched my head multiple time to find how to shorten the S2+ and even dremat of using a 18650 with the 18350 tube Ughh
YOur solution seems to be much more doable !
"Hey -X3-, do you have a flashlight ?"   "-X3-, can I borrow one of your flashlights ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Firelight2
Firelight2's picture
Last seen: 9 hours 2 min ago
X3 wrote:
… Now I want to see some pictures of that ! I scratched my head multiple time to find how to shorten the S2+ and even dremat of using a 18650 with the 18350 tube Ughh Your solution seems to be much more doable !
I made a build-thread for the mod Shortening the Convoy S2+
With a little more work, the entire light is now 102mm long, compared to 118mm for stock. Removing 16mm really makes for a much more pocketable light. Here’s a picture:
CRX
CRX's picture
Last seen: 2 hours 16 min ago
vwpieces
vwpieces's picture
Last seen: 14 hours 6 min ago
I like that CRX.
djburkes
djburkes's picture
Last seen: 6 months 4 days ago
I replaced the XP-G2 R5 with a dedomed XP-G2 S4 2B and made it direct drive with all springs bypassed in a Lumintop Hunter T5.
Next to a Thorfire VG10
55mm Head
Before Mod XP-G2 R5
After Mod Dedomed XP-G2 S4 2B
C8 Dedomed XM-L2 U4 1A
Rufusbduck
Rufusbduck's picture
Last seen: 9 months 2 weeks ago
I made copper ugly.
Scott
giorgoskok
giorgoskok's picture
Last seen: 6 days 16 hours ago
Nice work djburkes !
I was searching this lumintop for a while but i still can’t find it near me Big Smile
Rufusbduck wrote:
I made copper ugly. !{width:100%}http://i1166.photobucket.com/albums/q619/Rufusbduck/ABDF550B-45A6-471B-A...!
What ! How ? Too much heat ?
Rufusbduck
A temporary condition fortunately and a product of the brazing process. The heat scale was easily removed along with the brazing flux.
Scott
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 32 min ago
KawiBoy1428 wrote:
Purchased some A6 tubes when I found I could re-thread them with a 7/8-20 Die and they fit the KRONOAS X6 Copper /copper triple and also the EE BLF SE X6 triple, nice full round battery tube, love it! Too bad they don’t sell the Black A6 switches, no biggy, I would rather carry these bad boys instead, so the S41’s can sit in their box for-ever! Big Smile
The full tube feels so much better on both, but specially on the heavy Copper Brute! Thumbs Up
I ask BG if they would sell the Aluminum Black S41/A6 switch cap seeing they already sold the SS and the SS Colored Cap. Well they listened…http://www.banggood.com/Astrolux-S41-Aero-Grade-Aluminum-Alloy-LED-Flash...
KB1428 “Live Life WOT”
Jerommel
Jerommel's picture
Last seen: 2 months 2 days ago
ThorFire S70S has a non-DTP copper MCPCB…
I could have ordered a DTP one from Banggood, but didn’t want to wait another 4 weeks, so:
The white paint didn’t cover the mess all too well, but who cares.
Protruding bits for thermal path to reflector.
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
djozz
djozz's picture
Last seen: 5 hours 23 min ago
Cool adaptation, Jerommel! Cool
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
Serp
Serp's picture
Last seen: 2 weeks 1 day ago
Shocked It’s better than from the store
-X3-
-X3-'s picture
Wow, really impressive !
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 9 hours 56 min ago
I modded my BLF A6 with a SMO reflector and Dedomed the LED its throws okay now. It can easily been seen past 100 meters.
Also put an XPL with direct drive into my BLF D80.
Jerommel
Jerommel's picture
Dear oh dear…
Thanks for the compliments, but the success was very short lived…
I killed the XHP70…
A week ago i killed a XHP50.2
In both cases i nicked the dome and ruined the LED.. FacepalmTired
Enderman
Enderman's picture
Last seen: 7 hours 59 min ago
Jerommel wrote:
Dear oh dear…
I killed the XHP70…
How did you kill it by nicking the dome?
Did you like poke it with a knife and break a wire or something?
djozz
djozz's picture
Had this light (Ultrafire V10) waiting for a mod for ages (think it is slightly big for a 16340 light) but yesterday I modded it with lighted tail (lime, orange, red), BG bistro driver (with fix), and Nichia 219B V1 sm453 R9080 led (from the great effort of Clemence et al.) on 16mm Noctigon. The driver floating above the contact plate, lighted ring version with 3×2leds (3×5.9KOhm+5.9kOhm in series with everything).
The lighted tail needs the leds a bit more balanced in output some time, and I had to add the extra 5.9kOhm resistor to restore the user interface, so it is quite dim now (which is ok) and everything works.
The beam has a ring in it from the bezel, but nothing annoying in real life. It throws a good spot, with 450 lumen @30 seconds max (well over 3A current), and the great bistro UI takes care of all other modes. The rosy tint with total absence of yellow is not 100% my cup of tea , but the clarity and colour contrast of this led is sublime!
link to djozz tests
giorgoskok
Sweet mod right there djozz Wink
Jerommel
Jerommel's picture
Enderman wrote:
Jerommel wrote:
Dear oh dear…
I killed the XHP70…
Well…
The protruding bits turned out to protrude too much, so set out to shave some off with a dremel fixed to a bench, but the mill bit grabbed it…
So i was really dumb to not make sure the thickness was as should be before soldering the LED to the board…
Buzzing Bulb
Last seen: 1 hour 12 min ago
Changed the optic on a HC30 to a 45 degrees TIR.
Now it has a nice even spill when working outside.
Though I kept the lens, to press the O-ring down and keep it waterproof.
Serp
Serp's picture
good fit Carclo 10140
http://forum.fonarevka.ru/showthread.php?t=31892
MRsDNF
MRsDNF's picture
Last seen: 1 hour 54 min ago
Nice mod on the MCPCB Jerommel. It deserves a new led. Smile
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
CRX
CRX's picture
djozz
djozz's picture
Looks really classy CRX! I read the build thread, nice.
Today I balanced the leds in the flashlight from post #2607 a bit better. The resistors are like this now:
Looks better now, but in reality what looks green is more towards lime andcwhat looks yellow is more orange.
link to djozz tests
sedstar
Last seen: 1 year 3 days ago
i have been taking more steps towards casting my own aluminum stock… i am going to start a thread in the DIY on it…
With enough black coffee and cigarettes? all things are possible…
I am currently still shipping… REAL GENUINE CREE xp-g emitters, the classic… brace yourself? as low as 20 cents apiece!! Check out the SALES THREAD, everyone is happy… then PM me
SALES THREAD:
http://budgetlightforum.com/node/52528
if you are into reloading? this is my site… I inherited the remains of what was once arguably the best reloading site on the internet… its the “BLF” of reloading sites…
http://reloadbench.freeforums.net/
if you think night vision would be cool? It IS… this site i am a member of, and its basically the “BLF” of home made scratch-built digital night vision. They are at the leading forefront of advanced DIY for digital night vision, and thats gun mounted or handheld… builds rival and exceed commercial offerings…
http://nightvisionforumuk.com/
Erethryn
Erethryn's picture
Last seen: 2 weeks 5 days ago
A very fiddly driver spring bypass, and a rather severe grinding job on the retaining ring to increase the internal diameter:
Wired up my 219C triple…just need to attach the NTC resistor, once the silicone cures, and it’s good to go.
I wasn’t happy with the wire solder job, so I’ve since preheated the pill and resoldered the wires. It looks a bit better now.
Considering it’s my first reflow (using a clothes iron, no less…thanks lampyris!), I’m pretty damn pleased (and rather surprised) that it actually works. Big Smile
mattlward
mattlward's picture
Last seen: 8 hours 44 min ago
What driver did you use? Good job on the ring, I hate opening them up. The dremel and I always swap blood.
EDC rotation:
Convoy S2+, 6*7135, XM-L2 3D, 10 degree TIR, PilotDog lighted tailcap.
Convoy S2+, H17F, XM-L2 4C, lighted tailcap
Zebralight SC52w-L2
Olight S1A
Olight S1R
Lexel
Lexel's picture
Last seen: 8 hours 4 min ago
I can state success for the Narsil build with the E-switch plus forward switch
Tom E changed the code so that the light gets always in turbo mode when the battery is conected here
This is the same as it was in the Klarus XT11GT light.
the normal narsil is running on my mopdded Skilhunt H03R
also adjusted the thermal calibration, works perfectly
black and white goes to swich with indicator LED which is feed by pin 7 over a 4.7kOhms resistor
left with TA 21mm driver, on the right stock with TIR both with identical high drain cell
left 4.55A right 2.45A
Rufusbduck
Looks like one of led4powers drivers. LD-2
Scott
Erethryn
Erethryn's picture
Yup, it’s a 12A LD-3.
