I wanted to start a thread where we can see all of the external mods that we do to personalize our lights . Whether it's for form or function , beautification or utility .
For example , I added a lanyard ring ( stainless steel split ring ) to my RC-G2 ( Q3-5C tint ) so I could easily detach or change lanyards . I also added a turkshead body wrap in type 1 paracord to facilitate an easier cigar grip .
Then I sprayed the lens on the inside with window frosting spray to diffuse the beam . ( I know that the RC-G2 is known as a good thrower for it's size , but I have other lights far better for this .) The frosting definitely cuts down on the light emitted but now the beam is nearly all flood with just a hint of a hotspot .
I ended up with a pocketable light with a smooth beam that is a pleasure to handle .
So what have you done to personalize your light lately ?
A friend used dishwasher to wash his aluminum anodized fork and spoon. All anodizing got lost... Dunno how and if this can be used with flashlights but that´s what happened
"Easy Off" Heavy Duty Oven Cleaner worked very quickly (10 minutes or so) in removing the anodizing from a Cabela's EPG (that's not the emitter, which was incan). It's just advertised as "anodized", nothing more specific.
I also encased an entire Mag 3D in a length of bicycle innertube - to obscene to show.
