LD-3: LD-2 on vitaminS (2-12Amps CC with configurable UI)
121 posts / 0 new
led4power
led4power's picture
Last seen: 3 hours 29 min ago
Useful links:
Old LD-2 thread:
http://budgetlightforum.com/node/39673
LD-3 For sale thread:
http://budgetlightforum.com/node/50425
LD-3 Reviews by BLF members:
TBA
TBA
TBA
Preliminary LD-3 datasheet link:
https://www.dropbox.com/s/4utteoho2x8pbyv/LD-3%20datasheet%20preliminary.pdf?dl=0
Highlights/summary:
  • Optimised LD-2 hardware (not much left to improve there) - very low internal resistance (sub 5mOhm), low active state current consumption (1.6mA typ.), reliable 1S-4S operation/support
  • User configurable settings/UI - max. current, mode groups, moonlight, mode memory, CC/DD on high, mode order, strobes, dual overtemp. protection with adjustable ext. threshold, cofiguration mode password
  • Adjustable current in UI - no need to change resistors to get desired current
  • Option to choose between constant current/direct drive (CC/DD) on high mode
  • Configuration mode password - prevents end users to accidentally enter into configuration mode and mess-up settings
Everything is in datasheet this time,and I think there is no need to write long, hard to read text in topic,so here are pics of datasheet:
Edited by: led4power on 11/05/2016 - 15:25
led4power
led4power's picture
Reserved.
pilotdog68
pilotdog68's picture
If you don’t mind, your pictures are showing up a little small for me. So I copied some of the important bits.
pilotdog68
I’m interested in how you achieved such a low internal resistance, but perhaps that’s a trade secret
led4power
led4power's picture
Internal resistance depends mostly on fet resistance,nothing magical there,the lower fet resistance,the better,but there is a point where potential gain (output current) is neglible,and that point is IMO about 5mOhm of driver internal resistance.
Mitko
Mitko's picture
Last seen: 3 days 7 hours ago
led4power
What about a single XML type emitter + 2S? Is it XPH35 realy?
pilotdog68
That’s what I thought, just wan’t sure how you shaved off another 5 from the “big FET” driver. Just a newer/better FET?
djozz
djozz's picture
Last seen: 1 hour 42 min ago
Led4power was so kind to send me the LD3 prototype, but I have not had enough time yet to do a proper review. But the bottomline is that the LD3 has (almost or exact?) the same hardware as the LD2 but the UI has dramatically changed: it is clicky only now, with a wagonload of useful settings and a very well functioning configuration procedure. I like it a lot sofar!
Mitko
Mitko's picture
10x djozz
M4D M4X
M4D M4X's picture
Last seen: 2 hours 18 min ago
great!
did i miss the price? Wink
find all available items in this list
i launched my new blog - all deals for members without MAP B$ Wink
find a short description about my idea here
if you want to buy a flashlight or battery for a better price: just send a mail - i will try to save you money!
DavidEF
DavidEF's picture
Last seen: 44 min 17 sec ago
Wait! djozz, did you say clicky only? I know a lot of lights are clicky, but sometimes a clicky just won’t do. Wonder why e-switch was left out! Crying
Otherwise, just from reading the page that PD zoomed in, it looks to be a very worthy upgrade for LD-2! I just hope LD-2 stays available for e-switch lights, or another alternative is offered. Wink
EDIT: I just glanced over the preliminary datasheet, and I’m amazed at the depth of configurability and functionality of this driver! Still wish it would support e-switch, but for a clicky switch driver, I don’t think there’s one out there that compares!
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
led4power
led4power's picture
@pilotdog
Note <10mohm for DD drivers,that means just that,less than 10mohm.Since there are a lot of different DD drivers and even more different FETs used,internal resistance varies from maybe 2mohm to 10mohm,but most of them have 4-6mohm.
led4power
led4power's picture
Mitko wrote:
led4power
Sorry, I didn’t understand you?
KawiBoy1428
KawiBoy1428's picture
Last seen: 44 min 38 sec ago
Wow Neven nice job on this one! Configurable current setting, brilliant! Wink I’ll take 4 please! Thumbs Up
KB1428 “Live Life WOT”
Mitko
Mitko's picture
Well, i was always wanted an Eu source for a good drivers like yours that are suitable to drive a single XML emitter type with 2( or more) 18650s, especialy in the 17/20mm form factor cause atm we have only MNT ones
Also a good driver for XHP35 in the same form factor driven by 4 Liions
Clicky one? Good for me
pinkpanda3310
pinkpanda3310's picture
Last seen: 23 hours 12 min ago
COOL! UI adjusted current levels! Crown
led4power
led4power's picture
I run out of ROM space in uC bacause of configurable settings. There will be e-switch version,but not sure when.
DavidEF
DavidEF's picture
Thanks! After I saw the datasheet, I figured that was the case. This really does look to be an awesome driver! Good job! I wouldn’t have thought there would be much room for improvement after LD-2. Hardware-wise, it seems I was right, but the UI of the LD-3 is incredible!
-Ayn Rand
giorgoskok
giorgoskok's picture
Last seen: 13 hours 15 min ago
As far as i know from LD-2 :
1)This driver is compatible with 4x Li-ions for use with xhp35
2)It isn’t a buck driver , it needs 1 cell for 3V leds , and 2 cells for 6V leds
will34
will34's picture
Last seen: 1 week 2 days ago
Nice! The configurable modes and possibility to have CC in lower modes and DD in high modes is a killer feature.
EasyB
Last seen: 1 hour 52 min ago
So in direct drive mode it is not limited to 12A, correct? It would behave just like an ordinary DD?
led4power
led4power's picture
There will be 4 versions of LD-3 available. 3A,6A,9A and 12Amps. DD feature on high is firmware regulation override,and there are some theoretical limits for DD current because of that,as shown in graph:
mapache
mapache's picture
Last seen: 9 hours 46 min ago
Looks very good.
Is there a typo in the data sheet? The Current set sub-menu text states that the 12A version can be reduced to 9A, but the chart indicates that it can be reduced to 8A?
DB Custom
DB Custom's picture
Last seen: 1 hour 12 min ago
I will definitely need some of these, probably 10-12 of them. Sometimes the side e-switch is a nice plus, in a smaller light, but I don’t have a problem waiting for that one to come out.
Please let us know the price and availability of these as I sure don’t want to miss out. Smile
Dale
Bribo
Bribo's picture
Last seen: 5 days 21 hours ago
Great work, LD-2 is my go to driver for all of my lights that I’m going to use myself. Looking forward to resistor free LD3 !
kicken_bright
Last seen: 2 hours 25 min ago
I was just thinking about building some lights again. I’ve got money ready! Thanks for all your work.
led4power
led4power's picture
mapache wrote:
Looks very good.
Max. Current setting in UI is different thing,for 12A driver you could set it anywhere between 8 – 12A;all modes will be scaled down by same percentage. Graph shows max. theoretical DD currents on high mode (if you choose DD in settings). For example,if you want to build triple xp-l,you should choose 12A version;with good battery max. Current on high could be 13-14A with DD activated. It’s important that this “predicted” current is lower than max. DD current from graph. It would be bad to choose 6A for driving triple xp-l,since its max. DD current is lower than those 13-14Amps;driver would limit current to value from graph (9.2A at 4.2V and lower than that at lower voltages).
mapache
mapache's picture
^ PM sent.
pilotdog68
So since I won, could I use this to drive at 11amps from 4S cells? It’s only clicky switch right now though, not e-switch?
led4power
led4power's picture
4x XHP35?
This would generate too much heat for little 17mm driver with typ. batteries and leds (output power is ~175W). With enabled DD on high – maybe, but for these big bad setups you should wait for LD-M3 to do that job. Yes, for now only clicky switch is supported.
pilotdog68
Yes, 4 XHP35 is what I was thinking.
