[GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)]
1609 posts / 0 new
clemence
clemence's picture
Last seen: 1 hour 45 min ago
AEDe wrote:
Wieselflinkpro wrote:
Here are some But you need to scratch the pads a little bigger.
And make spacer 0.6mm, and applay 2 layers of thermal paste. So it not for 144 and not 1.6mm.
Place the spacer for optics on top of it rather than using two layers of thermal paste or solder.
djozz
djozz's picture
Last seen: 6 min 4 sec ago
That is a great idea, scratch the solder mask off the entire two traces of the board and solder two 0.6mm copper plates on top covering (most of) them (triangles will do the job). It will give you an almost (or entire) DTP performance. It will be a pain to solder the wires then, so make sure that you already apply solder blobs on the wire-pads during reflow!
clemence
clemence's picture
Don’t forget to apply pressure while soldering those two copper plates. Thicker is better (if no optics involved). If you use aluminum reflector you can connect one of them to the reflector to get double sided cooling (isolate the other one)
AEDe
AEDe's picture
Last seen: 9 hours 29 min ago
djozz, clemence thank you for your ideas! I will try to find suitable spacer, of course. But now xhp50 with native H03 copper mcmcb is more cheap and convenient. Although a bit worse in CRI and r9
Texas_Ace
Texas_Ace's picture
Last seen: 1 hour 17 min ago
clemence wrote:
The gain decrease in lumen from 2,5A to 10A and to 16A is amazingly steep. I imagine the heat they create must be more than 60C at the body
Oh, they get WAY more then 60C. I desoldered the wires from the mcpcb when doing a turbo test on my first triple in less then 90 seconds.
Now days I use thin wires to reduce the current and I use S2 instead of the S2+ since it has a thicker spacer.
With 10A and the S2 or S8 host with a copper spacer I can generally get around 60 seconds before it gets too hot and starts thermal regulation.
I tested a few other tube lights today for more comparisons to the earlier numbers:
Triple XP-G3 mixed tint 85CRI did 1150 lumens @ 2.5A with 100m of throw, Turbo was 2900 lumens with 170m of throw all with the 15011 optic in order to get rid of the tint shift issues. With a high drain cell and 14A on turbo lumens jumped to 3400 and a bit more throw.
I have a single XP-L HI with an S6 reflector that makes got 220M of throw at 2.5A and 260m of throw on turbo at ~6A. The best EDC thrower I have.
The best overall setup if you are not worried about CRI is the triple XP-L HI with ~175m of throw on turbo (driver didn’t have the regulated low mode) and ~3000 lumens @ 11A. Sadly the CRI sucks on it.
I am swapping EDC lights out daily right now to see which light works the best for me.
The ultimate setup would be an XHP50.2 or the 144A with a thermal pad and wired for 3V operation with no dome. I would totally rock that setup even if it costs $15 or $20 for the LED as long as it didn’t have tint shift issues and 90+ CRI.
clemence
clemence's picture
You’ll have it soon then Wink
Texas_Ace
Texas_Ace's picture
clemence wrote:
Texas_Ace wrote:
The ultimate setup would be an XHP50.2 or the 144A with a thermal pad and wired for 3V operation with no dome. I would totally rock that setup even if it costs $15 for the LED as long as it didn’t have tint shift issues and 90+ CRI.
Did I miss something or do you have something to share?
clemence
clemence's picture
You miss something and I have something Smile
Texas_Ace
Texas_Ace's picture
lol, mind making it easy for me, got a link to the said thing? I have been super busy recently and have not ready the last many pages of this thread nor any other thread posted on here recently.
You can PM me if you want, you have my attention that is for sure.
Jerommel
Jerommel's picture
… ? ? ! ? Smile
clemence
clemence's picture
LATEST INVENTORY STOCK [170325, 09:15 GMT +8]
  LED Type CCT Available/STOCK*1
1 NVSL219B-V1 SW45K [4500K ANSI BBL] SOLD OUT
2 NVSL219CT SM273  [2700K 3 steps MacAdams] 119
3 NVSL219CT SM303  [3000K 3 steps MacAdams] 150
4 NVSL219CT SM353  [3500K 3 steps MacAdams]  103
5 NVSL219CT SM403  [4000K 3 steps MacAdams]  SOLD OUT
6 NVSW219CT SM503  [5000K 3 steps MacAdams]  SOLD OUT
7 NVWL219CT SM573  [5700K 3 steps MacAdams]  147
8 NVSW319ATE  SM655  [6500K 5 steps MacAdams]  73
9 NVSL319ATE  SM305  [3000K 5 steps MacAdams]  65
10 NVSL319ATE  SM505  [5000K 5 steps MacAdams]  6
11 NV4L144AM SM453  [4500K 3 steps MacAdams]   64
12 NV4W144AM  SM503  [5000K 3 steps MacAdams]   81
13 NV4W144AM  SM573  [5700K 3 steps MacAdams]   85
14 VirEnce S3030 CDTP board   20
Texas_Ace
Texas_Ace's picture
I have some extra 5000k 219C and 319A I could sell for the right price if anyone is interested. Ended up with a few more then I had planned on now that all of my lights are modded already. Only way to use them is to replace existing mods lol.
PM me if you want some of them.
Gunga
Gunga's picture
Last seen: 8 hours 21 min ago
There’s a chance I’ll need the 100 3500K 219C. Maybe more. This is all speculating until I start talking to a few people. I’m in Canada but the LEDS would be needed in the states. Again, currently speculating.
clemence
clemence's picture
FYI,
I got the 219B sw45k and sw40. But unfortunately in slightly lower bin and said to be from different reels, this time. My rep got me whatever he could find.
I’ll hold them for you, but please confirm ASAP.
Gunga
Gunga's picture
I’ll do my best. Don’t want to waste your time if this falls through
Jerommel
Jerommel's picture
clemence wrote:
FYI,
Awesome!
chouster
Last seen: 8 months 2 days ago
Jerommel wrote:
clemence wrote:
FYI,
Awesome!
Nice!
Justintoxicated
Justintoxicated's picture
Last seen: 1 year 8 months ago
Texas_Ace wrote:
I just used up the last of my 219B's. I built a quad VG-10 with them and it is amazing. Around ~2100 lumens but a truly amazing tint. Nice and floody as well (although less floody then I expected) and perfect for a photo light. Already used it to great success for some extra lighting for some pictures. In a quad setup with a TA driver and 20AWG wires it only pulls around ~10A on a HE2 battery, I expected more but glad at the results due to the heat of almost 40W being a bit more then the VG-10 can handle. Now to wait for some more of these. I was doing some experiments last night with my EDC options. All LED's have the dome on. A single 219C 4000k will do ~775 lumens and 143m of throw at 2.5A and ~1100 lumens with 182m of throw on turbo with 6A. A triple 219C 4000k will do ~875 lumens and ~92m of throw (84m of throw with a 15011 optic but more flood) at 2.5A. Going to 2100 lumens and 140m of throw (133m with 15011 optic) on turbo at ~16A (didn't measure it but I think it was around here). A triple 219B 9080 does ~800 lumens and ~96m of throw at 2.5A going to ~1750 lumens and 144m of throw on turbo at ~10A. Based on these results I am not seeing any reason to not use the 219B triple as my EDC as it gives me the best of both throw and lumens. Now to decide if it is worth ripping apart 2 lights to build a EDC triple 219B now or wait for the next batch to become available and build a new light then.....
I am Considering replacing the 219c 4000k in my rey ti with the 219b's.
Or building my second rey-ti with 219b's  (Although that one was supposed to be a single since I already bought LD3 driver for it).
Gunga
Gunga's picture
Looking forward to 4000K 219B 9080.
Btw, no need to hold the 3500K 219C for me. Not getting any traction.
clemence
clemence's picture
LATEST INVENTORY STOCK [170402, 05:40 GMT +8]
7 NVWL219CT SM573  [5700K 3 steps MacAdams]  SOLD OUT
clemence
clemence's picture
Hi my fellow BLFers,
It’s been a very busy month for me, so I haven’t online in BLF for a while until today. I also got an unexpected bad news.
I bought thousands of new Nichias supposed to be ready for you guys this month. But the custom officer called me and said that all my stuff will be held there until I renew my import license. There was a new government regulation just a week before my stuff arrived!
This glitch affected many uninformed Indonesian importers. And I’ve been running around here and there to take care of it. And the to-do-list bureaucrazy got it so much more complicated than on paper. My fellow Indonesian should familiar with this kind of hassles here.
The hardest part is to get the legal company location validation as my current company location is different from what it was on the previous license. And the officer was on tour of duty outside his office without having any replacement, crazy huh? And that’s just one of many small little troubles I faced.
So, for those already put their money to me for the bulk orders, please be patient, I’m on it. The progress even though slow, is near completion within this week.
Thanks for your understanding,
- Clemence
TBone
Last seen: 1 month 1 day ago
clemence, I feel your pain. Fighting bureaucracy is only for the bravest of heart and I hope you do not loose faith.
You have done a tremendous job on the last group buy and I envy your energy and commitment.
Do not worry about us who just earn the fruits of your work. If the next group buy takes more time so be it.
Thanks for all the great work you do for us. Thumbs Up
zak.wilson
Last seen: 11 hours 28 min ago
A pox upon the bureaucrats. Thanks for putting up with that crap (at least in part) for our benefit.
Ceilingbounce – flashlight testing and runtime graphs for Android
virencelights
virencelights's picture
Last seen: 1 day 6 hours ago
Thank you….xx
Virence Custom Built; ArmyTek Viking Pro E21A 6500k 9080 Quadtrix, Jetbeam AAA 9080 E21A 9080 5700k, Jetbeam AAA Nichia HCRI Red Led.
Jerommel
Jerommel's picture
Good luck fighting the pencil pushers.
Looking forward to the next collection.
maukka
maukka's picture
Last seen: 22 hours 6 min ago
I finally had time to put together an X6 triple using three 219C R9050 sm403 emitters and the result is beautiful. Using the Ledil optic I get absolutely perfect tint. Depending on the output tint deviation i.e. Duv is anywhere from -0.0008 to 0.0019. So practically no noticeable shift either way. CCT is 3970-4022 K. CRI Ra 91-94 R9 63-76, again better on the lower modes.
Here’s the max mode with dr.jones h17f.
mattlward
mattlward's picture
Last seen: 1 month 3 days ago
Oh no… all that fine Nichia goodness sitting in a crate not getting to move. Just within reach, yet so far away. I need a bunch of the 219B 9080’s when the break loose.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Jensen567
Last seen: 1 year 1 month ago
Excited to see what’s in store when the nichias are finally free. I would like to play with some more nichia emitters.
mattlward
mattlward's picture
The 9080 B’s have an amazing tint. Very unique with the spike in the red band.,,
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
Gunga
Gunga's picture
Looking forward to 9080 at 4000K.
