Hi
do you think I'll got my order ?
- Order SubmittedFeb/15/2019 09:22:57
- 2Payment ConfirmedFeb/15/2019 09:23:00
- 3Order ProcessingFeb/15/2019 09:24:24
- 4Shipped
- 5Received
- No logistics info temporary.
Hi
You will probably get it but you will have to wait like me, probably wait longer because I ordered my NW on February 14th @ 5:30AM/5;30PM Hong Kong time!
Off to the trail
Primary light-TN42vn90.5000L/1.1MKcd
Secondary light: U21vn XPL PDT-1400L/260Kcd
So, I’m home.
I’ve got the data, and my eyes can’t believe it. Take the FT03 measurements with a grain of salt just in case.
maybe someone said it before but what size mcpcb does it use?
CW VERSION?
How far away did you measure?
Thanks,CAPO is howling!!..…….Gotta go,make some of u happy!
1. Yes CW version.
2. 1m as always. Did 5m, and the throw didn’t increase enough to be a significant measurement.
And yes, these are great news.
IMO, had I bought the light for myself, I would just have put in a sliced SST-20 5000k.
I would’ve loved 1200-1300m of 21700 thrower action.
I agree with this 1000%
IIRC the CW bin selected for this light was the N5, but what was the bin for the NW? Can’t seem to find it, I am hoping is just as good!
Don’t take offense to this information,I believe it to be true and so do many others,This guy “teej” is a genius, scientist/engineer!
This is what I read on Numerous threads on CPF with guys who know a lot about this. The beam needs to collimate. Measuring from 1m[actually never heard of a measurement so close] 3m/5m is NOT as accurate as measuring from 10m/15m or 20m
IE: The cd is the lux at one meter, but, measuring the lux AT one meter is almost always wrong to get the cd, because for the throwy lights, the beam may not REPRESENT the true cd until it is even 20 meters away.
For most of the lights, if measured at 20 meters for example, the beam will have formed by then. Just multiply the measured lux at 20 meters by 400 to get the lux at 1 meter (the cd).
So, if you get 250 lux at 20 meters, that means the light has a cd of 100,000, and so forth.
For your lux meter, generally, it will be most accurate at the central part of its range/range with best resolution…so, typically, a more distant reading will reduce the measured lux to the meter’s best resolution.
Much more in thread below: SEE POST 20/30 and 56. the guy “teej” was one of the smartest guys on there,he simplifies his explanation so your average Joe[me]…can understand
Wow… so that would be almost 1km of throw?
That’s why I provided a max and min measurement. Minimum measurement was done at 1m, and maximum measurement was done at 5m.
I’m sorry, but I didn’t have much time yesterday to make a lot of measurements, since I had to give the light to my friend as said before, and I had a ton of work related to the springs and my job, so can’t do too much stuff at once.
I did want to make a 10m measurement, but didn’t have the time. Sorry again
Has anyone tested these cells? I haven’t heard of them.
Vapcell 26650 5500mah 20A
Vapcell INR26650 5900mAh 20A
Soshine 5500mah
I see HKJ tested a protected version of the Soshine 5500. Actual capacity was closer to 5300mah. The protection circuit only allows 7A for a short amount of time. Looks decent, but you can’t really tell unless the protection is removed.
Not sure what your point is. I know how to get beam distance from Cd’s
I was taught the SQUARE RT. of Cd’s * 2,You get the same results
Oh, I thought you wrote that you didn’t know how to do the math. I’ll delete it.
Looking like it’s turning out to be a pleasant surprise! Glad I ordered one at this price, although it still hasn’t shipped yet.
Late this afternoon PayPal emailed notice of refund.
That’s good, but it doesn’t explain why your order was cancelled, right? You ordered pretty early and should have dibs on a light, but instead your order is cancelled without explanation? That bites.
I’ve estimated it at about 26mm based on the photos in a GearKR review. I’m throwing a 20mm de-domed SST40 from kaidomain one in there (would be nice if they sold it with 26mm but whatever)
I think I need to get some 30Ts…
Don’t think you’ll need it.
If you can find some NCR20700As, they’ll be perfectly fine for max output.
The highest juice stuff I have is Samsung 30Qs and Keeppower 26650s (UH2652) - so I don’t think I have anything over 15A sustained…
