Lexel
(Lexel)
December 12, 2018, 5:38pm
177
MascaratumB:
Lexel:
MascaratumB:
Lexel, can your 24mm drivers be sanded down to 23mm?
I have the Amutorch VG10 that takes a 23mm driver, and I guess one of yours would be good to fit in, if I can sand it to 23mm! BTW, will it work fine with:
a) Forward Clicky Switch
b) OSRAM KW CSLNM1.TG – 1mm2
Thanks in advance!
BTW, about the driver for the BlitzWolf BW-ET1, I will let it stay still until I get a good solution! Thanks for your answers, though
Buck driver easily sand down
the FET DD you may be careful with component side as then some are pretty close to the edge like 1mm
for 2S battery configuration a Buck regulated is possible but not yet for 1S
Hum…I guess I will want a FET DD (like the ones you sold me before), because I will use it just for one 18650 cell and clicky switch on the tail.
Am I correct in this choice?
If needed I can sand/file the host a little bit (on the inside), but there is few space. I guess using a 24mm driver will be better than using a 22 mm one, as there is not retaining ring nor “pill”.
1mm² Oslon needs regulated output or will burn
e-switch or clicky is just UI, if the LED works with battery is on DD an equasion between
battery voltage sag + conduction voltage drop
and
LED voltage
when both is equal you get a current which drops with battery charge status constantly
a battery with higher internal resistance has more sag, but this wont do the trick on an led with that low forwqard voltage and to about 4A limited max current
Th558
(Th558)
December 16, 2018, 7:48pm
178
What driver will be suitable for driving an osram cslpm1.tg at 7 amps in a convoy L2
Lexel
(Lexel)
December 16, 2018, 7:50pm
179
30mm buck as shown in first post, its listed under L6
Th558
(Th558)
December 16, 2018, 8:12pm
180
Will it fit in an L2 though or only L6?
ZozzV6
(ZozzV6)
December 16, 2018, 9:12pm
181
The L6 has 30mm driver and the L2 has 20mm. Or a very early L2 has 17mm.
Lexel
(Lexel)
December 16, 2018, 10:29pm
182
I have also a 20mm Buck driver for L2, likely retaining ring needs to be adjusted in inner diameter
polarweis
(polarweis)
December 16, 2018, 10:36pm
183
Can it be set for max 5 amp?(flat white)
i’m btw really enjoying my convoy L6 with 8amp driver. Thanks Lexel!
Lexel
(Lexel)
December 16, 2018, 10:49pm
184
Buck drivers get always set to the desired current
when I search for this LED I get only a non 3535 package found
Lexel
(Lexel)
December 20, 2018, 2:14am
185
20mm special for C8F 21700
new 1S 17mm version, for e-switch added R_ind and Ind. Pad, 209mil SOIC support
Planned
35mm Haikelite MT02 Boost driver
JasonWW
(JasonWW)
December 20, 2018, 5:28am
186
How has the progress been with the boost drivers?
Are they still planned for a future release?
I am waiting eagerly for this boost driver. Right now i order parts to make my own gxb172 but it is good to be able to buy one from you directly!
Lexel
(Lexel)
December 22, 2018, 3:41pm
188
I hope next year with the apartment finally done and settled I get enough time to do a lot testing on new driver architectures
right now I am still trying to catch up with orders getting the delivery time back to a short one
Yourrid
(Yourrid)
January 2, 2019, 2:49pm
189
I’m still holding out for a 28mm boost driver for my Haikelite SC26. :+1:
Lexel
(Lexel)
February 26, 2019, 3:54pm
190
17mm Programming Key and new LX
Lexel, I have two drivers for MF01 v1 and H03 (3V). Both have narsil, but I would like to have anduril in them. Could you send me the right files so that I can upload them myself?
ma_tumba
(ma tumba)
March 26, 2019, 12:26pm
192
What are these 12mm drivers?
Lexel
(Lexel)
March 26, 2019, 3:51pm
193
some AAA rechargeable lithium battery lights
Lexel
(Lexel)
March 27, 2019, 11:48pm
194
22 and 24mm AMC drivers for constant current LEDs like 1mm² white flat out now
2 Channel design for low moon
number of max AMCs can be chosen 10 for example are 3.5A
22mm 12+1AMCs
24mm 15+1AMCs
JasonWW
(JasonWW)
March 27, 2019, 11:17pm
195
So these are PWM like the FET drivers, but without the FET part of the circuit?
What MCU do they use?
Is it for e-switch?
Uses NarsilM/Anduril?
Lexel
(Lexel)
March 27, 2019, 11:46pm
196
Can use 209 and 150mil SOIC8 MCU
supports all firmwares including e-switch
instead a FET a certain number of 350mA AMCs is used plus a single one for moon
