D3 on the 2019 board is missing on the 2020 version.
Its a resistor that changes value with temperature.
You can read about it here.
It could be using a thermistor and a resistor (the two foghorne circled) to create a voltage divider like described in section “Hardware linearization solution”.
Its missing from the battery side of the board. It could be that it was relocated on the other side of the battery pcb, which we dont have a view of.
Its a two piece stacked pcb driver.
moderator007, can you say from the changes you see in the components what the purpose may be? Would the design dim the light to maintain a max temperature or will it work as a safeguard to shut it off if a temperature is reached?
If it is a thermistor it only gives the mcu a way to measure the temp. The code that compares the reading would determine where and when step down or shut down would happen. It was all up to the designer and coder as to the features.
So there is a possiblity the hardware is there but the code to take advantage of it is not.
I did turn on 2 TC-R1 lights, one with the 2019 and one with the 2020 driver and put them side by side on the table until they got fairly hot, but I did not push it because I have had a 2019 driver die on my a few days after I used the light for an actual emergency where I had to repair my girlfriends home lights that shorted. so the light was on top of a wardrobe on max until the battery almost died, while I was repairing the lights. It got quite hot but kept working and as the battery was depleted, output and temperature were lower and the light cooled off and kept working. A few days later, the light would suddenly not turn on. Replacing the driver fixed it. It looks like temperature killed the driver but not on the spot. In any case I am since reluctant to repeat the experiment and was excited to hear the 2020 driver may have some kind of thermal regulation / protection, but my short trial did not show it has. Maybe it needs to be tested for longer.
I would want an IR thermometer, to track temperature… or some fancy autologger like I see in some reviews
trust but verify
regarding the 2020 RRT-01:
what is the parasitic drain when the dial is turned to minimum?
the 2012 has a drain of 55uA (selbuilt)
the 2019 has a drain of 27uA (djozz)
the 2020 has a drain of ~28uA (pol77)
I believe that those values are due to the different working of the drivers.
The one of the 2020 version is to be used along with a tailswitch closes the circuit energy, hence preventing the drain.
The 2012 and 2019 will probably act more like an e-switch that doesn’t completely shut down the energy circulation.
So, in my head, the 2020 driver version is probably projected differently than the ones of the previous versions, which are supposed to reduce the drain once the rotary ring acts as the switch itself.
Also in my head, it doesn’t seem to make much sense to use the 2020 version with the tailswitch ON and then only use the rotary ring.
It makes sense to dial a “level” through the rotary ring and then just turn the light ON/OFF, acting as a single mode light. Having a forward clicky switch is even better (for me), as it allows momentary on for the lowest modes without full clicking
the question has come up repeatedly from people wanting to know if they can use the 2020 model on standby
edit
turns out, thanks to a test by pol77, that the standby drain on 2019 and 2020 RRT-01 is the same, I dont know if there is working thermal protection in the 2020 as claimed
Yup, looking at those values, it surely would be a downgrade as the originals would be more suitable for the lights than the “new” one.
I am not familiar with the new lights, I was only absorbing and reinforcing (althought without data) what you wrote before.
It really doesn’t make sense using the light that way nor modding other lights with a different driver, be it due the thermal sensor or not
Thanks for the explanation on this
and thank you for starting a wonderfully informative thread
My first reason to replace an RRT-01 driver, was because I destroyed one when disassembling the light incorrectly.
I have also intentionally upgraded from a 2012 driver to 2019 driver, in order to obtain the Strobe function
this is a good upgrade
the 2019 light also claims a 950 lumen output, whereas the 2012 driver claimed 600 lumens
that might lead some of us to hope that the 2019 driver will be brighter. Im not sure that is true, as I think the main difference is in the LED… but I dont have solid data
but here are the driver options I have seen Jetbeam use:
2011, no strobe, driver label says RRT-01
2012, no strobe, driver label says Eye10
2012, yes strobe, driver label says Eye10 (serial number on body is different format)
2019, yes strobe, driver label says Eye10
2020, yes strobe, driver label says Eye10
2020, yes strobe, unverified thermal protection, driver label says RRT-01
driver feature progression
original 20212 rrt-01, no strobe
2019 model, yes strobe, possible higher output
2020 model, yes strobe, plus claimed thermal protection
I just ordered a couple of spare 2019 RRT-01 drivers.
Where did you buy the drivers?
Here is the partslist for a 2012 RRT-01 mod
includes driver source, and reflector source thanks to moderator007
more discussion about the 2019 driver
eyecandy thanks to Geuzzz:
Thanks for reminding me Jon.
I still have a nib 2012 version that I want to mod into a more throwy light. 2700k sst-20, reflector mod and 2019 driver.
Time to order some parts.
your mods are an inspiration:
if you get a chance to offer the links to the lens and O ring you used, would be appreciated
a beamshot on a wall would be welcome too
The oring was just a fat +–20mm one out of my junk parts box. IIRC I used this ‘’convoy’’ lens:
https://nl.aliexpress.com/item/1577614278.html?spm=a2g0z.12010612.8148356.13.3c2f42e11mvX8y
How bad is this parasitic drain on the 2020? Is the driver pretty much the same besides that?
welcome to the discussion oGnavigator
edit
the 2020 parasitic on standby is the same as the 2019 (thanks to new info from pol77 below)
at slightly less than 30 micro amps per hour, an 1100mAh 18350 should last more than 4 years (someone check my math?)
Measuring weak currents is not simple or easy. It depends who is doing it, how he is doing it and what equipment is being used. For instance, trying to use a cheap clamp meter for it, is - sorry for my bluntness - a joke.
Most of all, unless all of the above conditions are near perfect, comparisons between measurements from different people are worthless.
So, in service to the community that has helped me so much on my road to becoming a Torchaholic (I live in London, we call them torches here), here is my method and measurements.
I used a Calibrated Brymen BM869s and a fully charged KeepPower 18350 1200mAh. A rubber band held the battery and probes in place. I measured each light for 13 minutes, as when measuring weak currents, more time gives more accuracy. I took a measurement every minute.
The lights measured were:
RRT01 2019 model, with the driver it came with
RRT01 2020 model, with the driver it came with (verified 2020 driver inside)
TC-R1 with 2019 driver, sourced from Jetbeam
TC-R1 with 2020 driver, sourced from Jetbeam
Here is my measuring setup:
And here are the results:
As you can see, there is no difference in the drain current between the 2019 and 2020 drivers, both the ones that came inside lights and the ones I sourced from Jetbeam.
jon_slider, if you still want the 2020 driver out of your home, I will be happy to have it
Disclaimer: No torches were harmed during these measurements.
