OK, just checked - definitely a 20 mm MCPCB. You'll have to work out the screw hole issue (smaller than normal cutouts). If it's a problem, you could always leave them out.
This is very helpful, thanks Tom! I have a drill press and variety of tools, I will assess the situation once I get down to brass tacks. Gonna find a cheap hot plate, and once I get the CULPM1 from Hank I’ll be doing my first reflow. I’m in the process of seeing if Simon has a 4040 mcpcb only for CULPM1 (that’s why I appreciate you measuring it!) Incase the polarity (?) doesn’t line up when I take off the NM1 from the ft03 mini mcpcb. Any thoughts on this? I will probably need a new mcpcb bc I’ll be going from nm1 to pm1 (3030 to 4040, if I’m thinking right) right?
Yep, you should use a 4040 MCPCB. Funny, I was emailing Hank tonight about a custom order of a CULPM1 on a 32 mm MCPCB (same as a K1). It's actually gonna be delivered tomorrow.
The FT03 Mini NM should definitely be a 3030. Hopefully they didn't use a 3535 - a 3030 on a 3535 is doable but not the best setup for the LED.
I might have 1 or 2 20 mm 4040's, not sure - can't check now.
2nd generation PM1, not 1st generation. And again, not sure of this. Actually Hank has comparative throw #’s published for these in a K1, but not sure if the amps are fir the peak throw.
ya thats where i got my impression from, cuz in the dropdown list of emitter we could choose from, i couldve sworn the 2.1 NM1 was 650kcd while 2.2 PM1 was 600kcd
Yep, you should use a 4040 MCPCB. Funny, I was emailing Hank tonight about a custom order of a CULPM1 on a 32 mm MCPCB (same as a K1). It’s actually gonna be delivered tomorrow.
The FT03 Mini NM should definitely be a 3030. Hopefully they didn’t use a 3535 - a 3030 on a 3535 is doable but not the best setup for the LED.
I might have 1 or 2 20 mm 4040’s, not sure - can’t check now.
That is a coincidence about you ordering that from Hank! And it makes me think I should’ve thought forward more and when I ordered my CULPM1 form Hank i should have asked him for one on a mcpcb… (It still surprises me just how much “custom” parts orders Hank does for us in the community, I am starting to learn to just ask him the question because usually he will do it for a modest fee). But, then again i didn’t know the size i needed at the time, and he already shipped my order… Maybe these are the mistakes people make when they’re learning all of this stuff? perhaps? maybe? LOL. Although I didn’t think about needing an appropriate sized footprint mcpcb until someone on blf mentioned it… Love this forum for all the help! Oh, and speaking of help, if you DO have an extra 20mm 4040 kicking around, i would be much obliged! I do paypal, of course :laughing: :sunglasses:
How do I get a group buy code? I’ve asked in this thread a few days ago and never heard back. I asked for an EC01 code in that group buy thread several months ago and never heard back on that one either. Am I doing something wrong?
Post again if no response. Me (and others) are probably clogging up the thread so freeme may be missing interested posts.
Just post: "Interested, thanks!". Keep it simple, repeat once a day if no response.
Interested, thanks!
Interested !
too bad about the aux leds
Group buy coupon is expired.
Which model?
Osram red beam black body.
I need to request from BG again.
No longer interested. Saw that the convoy c8+ was available with red osram so I ordered that instead. Thanks anyway.
Anyone tested the idle/parasitic drain of the FT03-Mini Osram?
I left battery inside the flashlight (I got a white/green/red) for a few weeks, and it got drained to below 3v.
In one of the FT03-Mini Osram flashlight, it killed the battery (drained to 0.0v and tried to ‘reactivate’ the battery but this time, it doesn’t get revived — this battery was a not-that-good quality battery though). On the other FT03-Mini Osram flashlight, the battery drained to 2.9v (this is a better quality battery) and in the last unit, the battery drained to 1.x volts (was able to revive this battery, it’s also a not-branded battery).
some comments:
- it looks like “poorer-quality’ batteries get drained to below 2.0v, while the better quality battery (this was an older/used-much VTC4) tested to just below 3.0v when I removed the battery from the FT03-Mini Osram flashlight.
- I measured the parasitic drain on each FT03-Mini Osram, and it tested 4mA!
(for comparison, I measured the parasitic drain of FT03-Mini SST40/XHP50.2 which uses Anduril and has lit-up aux-LEDs (set to ‘Low’), and these use around 0.1mA idle)
Yikes! 4 mA. Not surprising though. This looked like something someone created new on their own. Just by the choice of MCU made no sense because the majority of drivers we see from China use PIC's and this one is completely different.
Edit: Yep, confirmed. I measured 3975 uA on the OSRAM version, and 122 uA on the FT03 Mini SST-40 version running Anduril. Both have a switch LED on at about the same brightness, but the SST-40 is also running the LED's on around the SST-40. And of course Anduril periodically wakes up to do the LVP checks. It looks like the OSRAM version keeps that 8051 based MCU always on regular power, never sleeps.
This driver has to go.
freeme -- can you mention this to them? This driver has a major parasitic drain problem. It appears they don't put the MCU into sleep when power is OFF. We can't leave a cell in the light for any extended period of time.
A 3000 mAh cell would drain from full in 750 hours, or 31 days. If it was 1/2 drained already, then only 16 days. The FT03 Mini NM1 light drains a cell on standby about 32 times faster than the Anduril based FT03 Mini's.
:FACEPALM:
Intrested in few
Thanks
Intrested in 3.i lost my email from before.thank you
Anyone have instruction manual for the nm1 UI? I’m trying to configure the button led light brightness. Thanks in advance
