Headlamp/headlight recommendations wanted
I've changed my mind about the Lumintop HL3A.
The brightest model is only about 500 lumens over any significant length of time, according to this review:
https://zeroair.org/2020/03/18/lumintop-hl3a-flashlight-review/
(The "2800 lumens" doesn't last very long at all.)
The Wuben H1 keeps on looking better for my needs.
It's only about 500 lumens as well, but somewhat cheaper (on American Amazon.)
Wuben H1 have no warm led, if you dont need warm led you can just get D10 for 10$ ;))
Quadrupel wrote:
".. but if you want to have really hi cri – warm white – efficient – stabilized mode – light weight (<50g ) headlamp you have to DIY . There is no cheap solution on market. Aspiration Zebralight or better ( i do not know better, except few custom builds like H04 with E21A) ;))"
(Sorry, but I cannot quote your post properly for some reason...)
I don't care about high CRI.
EDIT:
I am not sure if I want a 5700K headlamp.
(I didn't realize that was cool white.)
Looks good, but for few dollars more you can get H04 :wink:
I cannot find a lumens runtime graph for the H04 XM-L2, which comes in neutral white.
For about the same price, I can get the Lumintop HL3A, which I can find a lumens runtime graph for, which also comes in neutral white.
I'd rather have warm white, but I might have to settle.
h04 run time
its not that impressive, i think it depends on how much you need. if you need consistent 450-500lm ish, then wuben is the way to go, however, if you’re ok with maybe 200-300lm, then sp40 is much better
The sp40 may be the only headlight available with 3000k (shipped from china). No moonlight but a simple UI and micro USB. Can’t keep the clip on while in the headlight strap and that applies to most headlights. The Wowtac a2s is a strong contender at 30 bucks. I think the Armytek pro series including the brand new C2 has got to be the best all around headlight and with the clip on the tail end you can keep it on in the head strap. The UI sounds impossible when you read it but once you’ve done it a few times it’s very simple. We don’t know for sure that the new one is high CRI but it likely is. “Warm” and “white” labels/options. 3 moonlights, 3 turbos, 3 in the middle. 3500mah high drain battery. Magnetic charging, magnetic base. Wide smooth beam pattern. Plus other things that you don’t get in others. I don’t know what more you could ask for.
Sir, you comparing hi-cri with crap-cri ? What is Osram P6? I cant find data sheet for it even.
RC says that CRI doesn’t matter for this application. And some of us can’t tell 70 CRI apart from 95 CRI (myself included).
Why must we care about cri all the time? Im not colour blind, i know what its supposed to be, i aint trying to paint in the dark, just need to see what things are where
Thanks for the great advice! I just went on Acebeam’s site and saw the H60 FULL SPECTRUM HEADLAMP:
“ Acebeam H60 utilizes the new SunLike TRI-R technology for high CRI (>97) and TLCL ratings with spectral distribution as close to the sunlight as possible”
Ha those are crazy looking. Daddy want
goddamn those spider eyes…
I bet at some point someone will have a LEP headlamp. Like the Acebeam W30 flashlight
that would be pretty dope…
…if you’re a Dalek.
If you don’t have a D-10 Boruit .... my only question is why not?
im new here but is boruit a good brand? i have their 4000mah 18650…seems kinda sus
It’s a great light and it’s ten bucks
punches way above it’s weight class
Great budget lights for the money are the reason the forum exists
take the time to read what a 100 members who have one think about the light.
I wouldn’t trust that battery, since they definitely just grabbed a cheap Chinese cell and wrapped their name around it.
But in terms of flashlights, Boruit’s a decent budget brand - lots of features for a low price. They’re the same manufacturer that makes the D25S and S11C lights that Sofirn sells, in case you wanted other examples to look up.
