Reason I ask is that the solder joints are pretty close to the tail cap and touches if you (over) tighten it.
So I had to cut it flush and remove some solder
And for those wondering, the best tool to use imo, is a watch case opener
I have one of those chinesium one and it works perfect
I just need low , medium, high and off . If I was to be attacked it would be over before I could activate the strobe mode . How many people actually know what an SOS signal looks like ?
I think the average person would interpret those modes in this way.
You want to drive 40w led in tiny D10 ? But yes, this driver can be 6V or 12V. PCBs on the way, ill get it in week or two. I will write some short modding instruction how to transform D10 to ultimate hi-tech
O.K. Probably the last and ultimate Lume1 inspired, TPS63020 buck-boost, Anduril, 3V LED driver for this nice & budged friendly headlamp.
Driver can output 12W with full (4.2V) and 6W with completely depleted (2.6V) battery. Acceptable PWM . All mode stabilization . Eficiency up to 93%. Have reverse polarity and thermal protections. 1 or 2 color aux led support. Lowest mode could be lower , but its fine.
Its the most advanced and balanced driver i ever made . Mission accomplished.
PCB:
Thanks for your answer!
I was hoping a more simple solution ,maybe buying a few replacements from aliexpress.
Nope ,no internet provider ,the username it’s from an satellite chanel package https://en.kingofsat.net/pack-viasat.php .
Best Regards!
