Sofirn 21700 5000mAh (Review)
18 posts / 0 new
Funtastic
Funtastic's picture
Last seen: 1 day 20 hours ago
Sofirn sent me their new 5000mAh 21700 cell for testing. I used the West Mountain Radio CBA IV Pro.
This is a rewrapped Lishen LR2170SD
Specs I was given
Diameter: 21,7mm ± 0,2mm
Length: 70,9mm ± 0,2mm
Weight: 72g ± 4g
Nominal capacity: 5000mAh at 0.2C discharge current
Minimum voltage: 2.50V
Maximum voltage: 4.20V ± 0.03V
Standard charge current: 0.2C (1A)
Maximum charge current: 0.7C (3.5mA)
Maximum discharge current: 2C (9.6A)
Initial internal impedance: ≤ 30mΩ
Slightly risen allowing it to be used in series
Capacity test at 1A (0.2C) tested 4,975 mAh from 4.20v down to 2.50v
5A = 4,837 mAh
10A = 4,781 mAh
15A = 4,740 mAh
Showing the 20A discharge was too much reaching 80°C, which is where I stopped the test.
Sofirn 21700 5000mAh vs Sofirn 21700 4000mAh at 15A
5000mAh – Black / 4000mAh – Red
Sofirn 21700 5000mAh vs Samsung INR21700-50E
Sofirn 5A – Solid Black / Samsung 5A – Solid Blue
Sofirn 10A – Dotted Black / Samsung 10A – Dotted Blue
Conclusion: Very decent performing high capacity 21700 cell that can handle up to 15A.
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
Edited by: Funtastic on 07/14/2021 - 21:29
zoulas
zoulas's picture
Last seen: 14 hours 30 min ago
I would not go out of my way to buy Sofirn batteries, I do like when they charge you $2-$3 and include one with the light you are buying.
Funtastic
Funtastic's picture
Sure, you can do better, but it’s a very decent cell Sofirn are bundling for cheap. I’m impressed tbh
Lux-Perpetua
Lux-Perpetua's picture
Thanks for the great review, Jacob.
Quote:
This is a rewrapped Lishen cell, not sure of the model name.
Lishen LR2170SD, see my review of Sofirn‘s SF47T here:
https://budgetlightforum.com/node/76446
This battery can also be found in the Wurkkos TS30S and some bundles of the TS30. While this battery is great for lights like SF47T and SP35, it is not the best option for FET/DD lights like TS30 or TS30S taking advantage of high drain cells like a Samsung 30T/40T/50S or Molicel P42A.
I agree with Jacob that it’s a very decent and cheap alternative to Samsung’s 50E/G. Most of Sofirn‘s 21700 4000mAh batteries seem to be a Lishen LS2170SA. There are some with a recessed ring and some without, so there’s some variation in there.
zoulas
zoulas's picture
Thats what I meant, I like it and I normally add one to my order.
Funtastic
Funtastic's picture
Lux-Perpetua wrote:
Thank you.
Yes, that was a mistake to be sold with the TS30/TS30S. Here’s a comparison at 20A against the 40T. No idea whether they’ll change it, but I can imagine it’ll ruin reviews if they use that cell, already complaints surfacing of poor performance.
Lux-Perpetua
I will not give up encouraging Sofirn and Wurkkos to reach out for better high drain batteries. My guess is they are somehow bound into a long-term liaison with Lishen and DLG but maybe they are willing to rewrap some Molicels or Samsungs for a moderate price.
Funtastic
Funtastic's picture
Lux-Perpetua wrote:
Are you certain it’s the LR2170SD? There’s a sale on 18650batterystore for cheap so might import some.
Lux-Perpetua
I was given the datasheet for LR2170SD (03BCEA5), so yes, it should be that exact model. I can mail you the datasheet if you want.
cyclops
Last seen: 12 hours 25 min ago
Funtastic wrote:
Lux-Perpetua wrote:
Thank you.
!{width:100%}[img]https://i.imgur.com/YDG75gn.png[/img]!
Did they change the bundled battery with the TS30S yet? I am looking forward to that light. I have a 30Q 18650 which maybe I can use with a sleeve to compare the performance.
Lux-Perpetua
cyclops wrote:
Did they change the bundled battery with the TS30S yet? (...)
Unlikely. They do not have anything better than Lishen LR2170SD or Sanyo/Panasonic NCR21700A. These cells work greatly up to 10A, maybe even 15A. For the TS-series you need something with more juice like Molicel P42A, Samsung 30T/40T/50S if you want to push it to the limit.
TheIntruder
Last seen: 1 week 1 day ago
Is that something you’d be willing to share with the rest of us?
Lux-Perpetua
I am not sure if that datasheet is allowed to be made public. It is from Lishen and nowhere to find on the internet (at least I did not find it after long searching Big Smile ).
TheIntruder
I won’t tell Innocent
Funtastic
Funtastic's picture
It’s not in English so all I found helpful was the charging and discharging notes
Lux-Perpetua
The most important specs:
Weight: 72g ± 4g
Standard charge current: 0.2C (1000mA)
Maximum charge current: 0.7C (3500mA)
Maximum discharge current: 2C (10000mA)
Impedance: ≤ 30mΩ
Funtastic
Funtastic's picture
Maximum discharge current is actually 9.6A Smile
TheIntruder
Weight: 72g ± 4g
Impedance: ≤ 30mΩ
Thanks. Like you, I wasn’t able to find the one for the SD, only the SA.
